9th March 2011, 22:05 | #863 | Link | |
I also don't have a concrete interface yet, but that should come up in the next days/week too. Its not that big of a project, i should be able to get it done somewhere in between.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 9th March 2011 at 22:07. |
9th March 2011, 22:39 | #865 | Link |
Most of the time you can just copy the new version over, but some things, like the Merit change in 0.18, require you to re-register the filter. Same goes when adding new formats to either the splitter or decoder.. In general, its always safer to just re-register it. -- btw, uninstalling is usually never required, just running install again is fine.
9th March 2011, 23:04 | #867 | Link | |
I'll try to remember to add that.
9th March 2011, 23:16 | #868 | Link |
Guys,
does anybody know how I can check the file version of .ax files on Windows 7? In Windows XP it was as simple as clicking properties in Windows Explorer but this doesn't work in Win 7 for .ax files. On other hand it does work for .dll files and .exe files. Any ideas why is that? Am I messing something up? |
9th March 2011, 23:21 | #870 | Link |
Well, it's not only that.
Try checking the same on other .ax files - it won't work. At least it doesn't for me. If I rename the same file to .dll it will show it's version. Of course for LAV filters it's an empty field but at least there is a field "Product version", while on .ax files there is no such field. |
9th March 2011, 23:29 | #872 | Link |
I still need frame time correction with the cyberlink vc-1 decoder from powerdvd 10, using mpc hc, and lav splitter .18, all 32 bit.
note the disparity between ftc off and on with this sample: http://www.mediafire.com/?89rtj5yxn9hrkz1 i dont really mind using ftc, so its not a big deal. also, this change of merit for lav splitter, what does it mean practically for users? Last edited by mindbomb; 10th March 2011 at 02:17. |
10th March 2011, 02:26 | #874 | Link | |
for h264 and mpeg 2, i prefer the microsoft dtv-dvd video decoder that comes with win 7 though. |
10th March 2011, 03:00 | #875 | Link |
I'll have to play around with it all when I get a chance. For my main machine, not a problem as I use software decoding. But for that machine, I need some DXVA going on. I'll figure it out.
10th March 2011, 05:19 | #877 | Link | |
Edit - found it. Rendered settings.
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 10th March 2011 at 05:21. |
10th March 2011, 07:53 | #879 | Link | |
In any case, I'm not sure if i can solve that, apparently DXVA screws with the timestamps for some reason, so running with FTC might be the easiest solution.
10th March 2011, 13:17 | #880 | Link |
Could you perhaps implement a "Automatic FTC" in MPC-HC? The idea is as follows:
- Let the renderer enumerate the filters/pins - check if a VC-1 mediatype is present, and if so check if there is a combination of source filter and decoder that needs FTC, and if so enable FTC - Remove the manual FTC option
MPC-HC 2.1.7.2 |
