Old 15th September 2018, 12:18   #4261  |  Link
Richard1485
When converting from 10bit to 8bit with the following script...
LWLibavVideoSource("bla.mkv", stacked=true, format="YUV420P10")
ConvertFromStacked(bits=10)
ConvertBits(bits=8, dither=0)
... the luma range goes from looking like this...
to looking like this...
Have I overlooked something? When previewing in VirtualDub2, the video doesn't look obviously wrong, but I've never seen a histogram look like that unless there's a problem of some kind.
Richard1485 is offline   Reply With Quote
Old 15th September 2018, 12:20   #4262  |  Link
Selur
Selur's Avatar
what happens when us use: dither = -1 ?
int dither = -1
If -1 (default), do not add dither;
If 0, add ordered dither;
If 1, add error diffusion (Floyd-Steinberg) dither doom9
Cu Selur
Old 15th September 2018, 12:27   #4263  |  Link
Richard1485
Yeah, I tried that. The resulting histogram still looks like the second one that I posted above.
Old 15th September 2018, 13:50   #4264  |  Link
davidhorman
I'm the Doctor
At what point in the script did you call histogram to get the first image?
It looks to me like histogram has got its levels mixed up. The graph is ostensibly the same, but there are parts where it looks like the values being plotted have overflowed - the same pattern of pixels is seen as in the "correct" image but in dark grey instead of light grey.
In fact that is exactly how it looks - if you darken the image to 0-128, then add 128 to the "blacked-out" areas, it seems to take on the correct range when comparing it to the "correct" image.
So it's like a 9-bit graph output truncated to 8-bits.
davidhorman is offline   Reply With Quote
Old 15th September 2018, 14:05   #4265  |  Link
Richard1485
I called Histogram() when returning the video. But the first one looks fine to me. It's the second one that looks messed up.
EDIT: It's working now. I'm not sure what went wrong, but there you go.
Old 29th September 2018, 23:29   #4266  |  Link
StvG
ConvertBits(8) gives a big difference compared to z_ConvertFormat(pixel_type="YV12") and DitherPost(mode=-1). Is that an expected behavior?
ImageSource()
Interleave(ShowRed("y8"), ShowGreen("y8"), ShowBlue("y8")).Dither_convert_8_to_16()
Dither_convert_rgb_to_yuv (
\ SelectEvery (3, 0), SelectEvery (3, 1), SelectEvery (3, 2),
\ matrix="709", noring=true, output="YV12", tv_range=true, chromak="spline36",
\ lsb=false, mode=6)
z_ConvertFormat(width/2,height/2,pixel_type="yuv420p16", resample_filter="spline36")
s=last
ConvertToStacked()
DitherPost(mode=-1)
a=last
s
z_ConvertFormat(pixel_type="yv12")
Compare(a, channels="yuv")
ImageSource()
s=last
ConvertToStacked()
DitherPost(mode=-1)
a=last
s
ConvertBits(8)
ImageSource()
s=last
ConvertBits(8)
a=last
s
Image source.
StvG is offline   Reply With Quote
Old 16th October 2018, 12:45   #4267  |  Link
davidhorman
I'm the Doctor
Is there any way to get a debug output of the compiled code generated when using expr()?
Old 18th October 2018, 08:57   #4268  |  Link
pinterf
No, I put a breakpoint at the entry of calling the compiled code and then changed to assembler view.
pinterf is offline   Reply With Quote
Old 18th October 2018, 10:22   #4269  |  Link
davidhorman
I'm the Doctor
Okay. Such a facility would be nice if you ever happen to be near that code again
Old 24th October 2018, 01:57   #4270  |  Link
Richard1485
I've experienced for the second time the same problem that I raised in post#4261. If I switch from the x64 version of ffms2 to the x86 one, it goes away. This must have been why the issue suddenly seemed to clear up (for which, see post#4265): both times, I switched versions (for unrelated reasons). I just didn't put two and two together. Does anyone experience this issue or is it just me?
Old 24th October 2018, 03:09   #4271  |  Link
poisondeathray
I can reproduce this.
Either ffms2 or lsmash as your earlier post
avsresize to convert bits instead of convertbits also same result
I don't have avs+ 86 installed , so I can't check that or x86 source filters . But if it "goes away" with ffms2 x86, then it suggests avisynth+ x86 histogram is not affected
vpy x64 version of histogram not affected
EDIT: I just rechecked some things and I can NOT reproduce it anymore! I have no idea what is going on but I'm sure I saw it earlier
Old 24th October 2018, 15:10   #4272  |  Link
pinterf
If my assumption is right, the problem depends on special timing conditions so it's not 100% reproducible, and is inside Avisynth.
https://github.com/pinterf/AviSynthP...gram.cpp#L1600
The brigtness lookup table may not always be initialized fully by the time it is used in another thread. I could reproduce such effect by inserting an artificial sleep
std::this_thread::sleep_for(std::chrono::milliseconds(1));
inside the for-loop of lookup (here: variable exptab) generation.
Looking at the code of the Classic histogram I noticed another problem. Since there is only a single predefined lookup table, it will be calculated for whatever bit-depth is found first.
When classic histogram appears e.g. twice for different bit-depth they won’t work properly for both instance. Just check it:
...some 8-bit clip here...
x8 = last
x16 = last.ConvertBits(16)
StackVertical(x16.Histogram().ConvertBits(8),x8.Histogram())
I'll check both problems.
Old 27th October 2018, 16:27   #4273  |  Link
Hi P, hows bout an Avisynth_+_Pinterf thread, about time you had thread control.
Just point one last post pointing at new thread (with request for no new posts unless directed at Ultim original branch).
Old 28th October 2018, 16:03   #4274  |  Link
tormento
Acid fr0g
tormento's Avatar
Strange internal filter error here.
Any hint? Latest AVS+ installed.
@turment on Telegram
Old 28th October 2018, 16:09   #4275  |  Link
LigH
LigH's Avatar
The expression "latest" is insufficient. Please tell us the exact version (e.g. via AVSMeter).
The latest release of AviSynth+ MT by pinterf is r2728-MT (20180702).
New German Gleitz board
Old 28th October 2018, 16:17   #4276  |  Link
tormento
Acid fr0g
tormento's Avatar
I use the latest release version. The one you quoted, x64 flavor.
Old 28th October 2018, 16:55   #4277  |  Link
Groucho2004
Groucho2004's Avatar
Run "avsmeter64 avsinfo" and check if that throws any error(s).
Old 28th October 2018, 17:18   #4278  |  Link
tormento
Acid fr0g
tormento's Avatar
AFAIK no error:
AVSMeter 2.8.6 (x64) - Copyright (c) 2012-2018, Groucho2004
VersionString:              AviSynth+ 0.1 (r2728, MT, x86_64)
VersionNumber:              2.60
File / Product version:     0.1.0.0 / 0.1.0.0
Interface Version:          5
Multi-threading support:    Yes
Avisynth.dll location:      C:\WINDOWS\SYSTEM32\avisynth.dll
Avisynth.dll time stamp:    2018-07-02, 12:54:16 (UTC)
PluginDir2_5 (HKLM, x64):   D:\Programmi\Media\AviSynth+\plugins64
PluginDir+   (HKLM, x64):   D:\Programmi\Media\AviSynth+\plugins64+
[CPP 2.6 Plugins (64 Bit)]
D:\Programmi\Media\AviSynth+\plugins64+\FFT3dFilter-2.5-pinterf.dll  [2.5.0.0]
D:\Programmi\Media\AviSynth+\plugins64+\GamMac-1.10.dll  [1.10.0.0]
D:\Programmi\Media\AviSynth+\plugins64+\KNLMeansCL-1.1.1.dll  [2018-01-29]
D:\Programmi\Media\AviSynth+\plugins64+\MaskTools-2.2.18-pinterf.dll  [2.2.18.0]
D:\Programmi\Media\AviSynth+\plugins64+\MVTools-2.7.32-pinterf.dll  [2.7.32.0]
D:\Programmi\Media\AviSynth+\plugins64+\RgTools-0.97-pinterf.dll  [0.97.0.0]
D:\Programmi\Media\AviSynth+\plugins64+\ZLlib-r1d-Savage.dll  [2018-03-22]
[Scripts (AVSI)]
D:\Programmi\Media\AviSynth+\plugins64\CompTest.avsi  [2010-09-05]
D:\Programmi\Media\AviSynth+\plugins64\SMDegrain-3.1.2·100.avsi  [2018-07-11]
D:\Programmi\Media\AviSynth+\plugins64\TemporalDegrain-2.1.1-ErazorTT.avsi  [2018-10-27]
[Uncategorized DLLs (64 Bit)]
D:\Programmi\Media\AviSynth+\plugins64+\libfftw3f-3.dll  [2018-10-24]
[Uncategorized files]
D:\Programmi\Media\AviSynth+\plugins64+\AviSynth-new.css  [2016-03-31]
D:\Programmi\Media\AviSynth+\plugins64+\AviSynth.css  [2016-03-31]
D:\Programmi\Media\AviSynth+\plugins64+\FFT3dFilter-2.5-pinterf.htm  [2018-07-06]
D:\Programmi\Media\AviSynth+\plugins64+\FFT3dFilter-2.5-pinterf.md  [2018-07-02]
D:\Programmi\Media\AviSynth+\plugins64+\FFT3dFilter.gif  [2005-04-04]
D:\Programmi\Media\AviSynth+\plugins64+\GamMac-1.10.txt  [2018-06-15]
D:\Programmi\Media\AviSynth+\plugins64+\KNLMeansCL-1.1.1.htm  [2018-03-10]
D:\Programmi\Media\AviSynth+\plugins64+\MaskTools-2.0a48.htm  [2010-12-31]
D:\Programmi\Media\AviSynth+\plugins64+\MaskTools-2.2.18-pinterf.md  [2018-09-05]
D:\Programmi\Media\AviSynth+\plugins64+\MVTools-2.7.32-pinterf.htm  [2018-10-18]
D:\Programmi\Media\AviSynth+\plugins64+\MVTools-2.7.32-pinterf.md  [2018-10-18]
D:\Programmi\Media\AviSynth+\plugins64+\RgTools-0.97-pinterf.md  [2018-07-02]
D:\Programmi\Media\AviSynth+\plugins64+\ZLib-r1d-Savage.md  [2016-10-30]
D:\Programmi\Media\AviSynth+\plugins64\AviSynth-new.css  [2016-03-31]
D:\Programmi\Media\AviSynth+\plugins64\AviSynth.css  [2016-03-31]
D:\Programmi\Media\AviSynth+\plugins64\SMDegrain-3.1.2d.htm  [2015-07-21]
D:\Programmi\Media\AviSynth+\plugins64\Stab-256.1.01-videoFred.7z  [2018-09-04]
Old 28th October 2018, 17:54   #4279  |  Link
No help here but get rid of all the uncategorised files from plugs, they are all not needed there, ie rubbish.
No sure if ok to have libbfft3d-3.dll where it is (think some plugs were altered to also scan same dir as plugin).
(I would probably put mine in system32, although if using both 32 and 64 bit together, then I think things change,
not sure, have to check that out when I go that way)
Old 28th October 2018, 18:33   #4280  |  Link
Groucho2004
AFAIK no error
Weird. Run the script with avsmeter64.
