Old 1st September 2019, 14:45   #1  |  Link
AlucardSama04
x264 Patch
Hi! Where can I find x264 Patches like Film Grain Optimization, TriAQ, Device, profile force, level force?
AlucardSama04 is offline   Reply With Quote
Old 2nd September 2019, 19:19   #2  |  Link
jpsdr
My github.
My github.
Old 2nd September 2019, 21:29   #3  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by jpsdr View Post
My github.
I suppose the OP was /is expecting standalone .diff files, not an already-patched repository...
filler56789 is offline   Reply With Quote
Old 3rd September 2019, 12:02   #4  |  Link
jpsdr
You can create the diff from the repository.
After, it's not realy possible with some patches to have "untouched code version" diff from each patch, because they can overlap.
So, you'll always result with "diff for patch Y is to apply after diff for patch X, because they both modify the same part of the code".
And if you have a patch for X and for Y, both to be applied on an untouched code, you'll have trouble to apply both of them.
For now, if he wants, he can create the diff files from the repository.
I don't know where standalone patches can be found, i made my repository using the t_mod repository.
My github.
fgo patch, triaq patch, x264 patches
