Old 25th October 2004, 13:58   #21  |  Link
Sirber
retired developer
Sirber's Avatar
You should use EHQ85. Not sure EHQ100 brings more quality for the time spent.
Detritus Software
Sirber is offline   Reply With Quote
Old 26th October 2004, 01:05   #22  |  Link
karl_lillevold
karl_lillevold's Avatar
Hi, I posted a small update:
** 2004-10-25: added option <chromaModeDecision>
This option takes chrominance (or color) into
account when choosing the best encoding modes.
Fix: encodeAllFrames and rcBestPSNRMode would always
be ON if included in audience, if if set to 'false'
Fix: long standing bug where if Constant Quality less than 20-30
and EHQ greater than 70, bitstream could not be decoded. Thanks
to Satsuki for discovering the problem.
With option chromaModeDecision, for a chroma intensive anime test clip I measured +0.25 dB improvement in Overall PSNR for UV, and 0.04 dB for YUV. No change in Luma PSNR.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 26th October 2004, 01:11   #23  |  Link
Sirber
retired developer
Sirber's Avatar
woot woot!
gonna release RealAnime 2.25 in 24h.
Detritus Software
Old 29th October 2004, 00:07   #24  |  Link
karl_lillevold
** 2004-10-28: fix for chromaModeDecision on
single CPU systems (no hyper-threading or multi-proc)
- chromaModeDecision always ON for EHQ 100
Old 31st October 2004, 19:10   #25  |  Link
Krismen
Vacuum tube addict
Krismen's Avatar
I've updated Real Producer Basic 10 with 2004-10-28 patch and I can't get it to work (application crashes on start). My CPU dosen't have HT tech. (AXP1700+). Luckly for me I made a backup of "erv4.dll".
130F02041B18AB "... a gdybym był młotkowym, w fabryce z młotkiem szalał..."
Krismen is offline   Reply With Quote
Old 31st October 2004, 19:53   #26  |  Link
Sirber
retired developer
Sirber's Avatar
WFM here, on a 2000+, but with cmdline producer. Could you try RealAnime if it works for you?
Detritus Software
Old 1st November 2004, 04:31   #27  |  Link
karl_lillevold
I am not sure what could be wrong. I /think/, but am not sure the new erv4 will work in both RealProducer 10 Pro and Basic. However, you can not really enable the new features except via the registry. I would suggest one of the other GUIs, like RealAnime or AutoRV10.
Old 1st November 2004, 08:49   #28  |  Link
Krismen
Vacuum tube addict
Krismen's Avatar
Thank you guys. I'll try AutoRV10 soon.
EDIT:
Problem with patch & RMP Basic 10 solved by deleting backup file (erv4.bak) from codecs dir.
Old 7th November 2004, 02:00   #29  |  Link
gavo
intel codec family
gavo's Avatar
ok I have ehq at 100 for best quatily, but I wondering what should 1st pass compelixty be on.
You can take away my SIG but you can't take away my pride as a NOOBIE!
gavo is offline   Reply With Quote
Old 7th November 2004, 03:26   #30  |  Link
Sirber
retired developer
Sirber's Avatar
50
Detritus Software
Old 7th November 2004, 18:08   #31  |  Link
karl_lillevold
It seems no one is using EHQ Medium (75), which is good, because then you would have noticed that it can create blocky (broken) video in this release. I will post a fix tomorrow. No reason to update if you use EHQ High (85) or higher.
Old 7th November 2004, 18:23   #32  |  Link
Sirber
retired developer
Sirber's Avatar
Never heard there was a "75" setting before
Detritus Software
Old 7th November 2004, 20:29   #33  |  Link
gavo
intel codec family
gavo's Avatar
so going over 85 wont make a difference at all? or going over with 1 pass complexity?
Old 7th November 2004, 21:08   #34  |  Link
Sirber
retired developer
Sirber's Avatar
over 85 for encoding pass won't have mych quality gain
over 50 for analisis pass won't have much quality gain
Detritus Software
Old 8th November 2004, 06:40   #35  |  Link
gavo
intel codec family
gavo's Avatar
but it still a gain.. what the max for 1st pass 100?
Old 8th November 2004, 06:41   #36  |  Link
gavo
intel codec family
gavo's Avatar
[QUOTE]Originally posted by gavo
[B]but it still a gain.. what the max for 1st pass 100 and ehq?
Old 8th November 2004, 13:08   #37  |  Link
Sirber
retired developer
Sirber's Avatar
Guess...
Dude, EHQ numbers are written everywhere.
Rules:
1) Read up before asking! There are tons of guides, FAQs and each forum has a dedicated Q&A thread with additional info.
1a) Use the search function before posting. Chances are your question has already been answered.
Next time I will report to the moderator.
Detritus Software
Old 8th November 2004, 13:41   #38  |  Link
hubereevez
Star member
hubereevez's Avatar
pffffffff
( Gavo , tu nous gaves )
You have your answer here.
Moreover, stop acting like this or you'll be ban ! Because of people like you, Modos and users (like Karl_super user) are tired. And when these guys get tired, they do not respond so quickly to good question !!!!!!!!
So read the f*ù*^$^rules and use the search button !!!!!!!!
hubereevez is offline   Reply With Quote
Old 8th November 2004, 13:42   #39  |  Link
Sirber
retired developer
Sirber's Avatar
Detritus Software
Old 8th November 2004, 15:53   #40  |  Link
Shinobu
Satsuki'S Softs Maker
Shinobu's Avatar
test it yourself, after that if you think ehq 100/100 can be usefull, use it.
to my mind:
ehq 50/85 is enought for common encoding.
ehq 65/100 is usefull for very difficult encoding.
ehq 100/100 is realy useless.
Shinobu is offline   Reply With Quote
