Old 4th March 2018, 03:33   #121  |  Link
no-one
Output from TSM2UHD 1.12 on LG up970 no HDR
And when I take output from TSM2Uhd to compress uhd25G/50G by dvdfab uhdcopy. There are very mosaic and no detect hdr.
no-one is offline   Reply With Quote
Old 9th March 2018, 00:00   #122  |  Link
zamengo
Originally Posted by wolflop View Post
yes, source was the original Blu-ray structure. MKv made with makemkv.
Has someone already reported that any uhd works with the Ub 900?
same issue here, try with a ten different discs.
zamengo is offline   Reply With Quote
Old 5th April 2018, 00:51   #123  |  Link
ScorpionStingz
If anyone can figure this out it would be jdobbs.
Just when you thought you'd get out, they pull you back in!
ScorpionStingz is offline   Reply With Quote
Old 18th May 2018, 19:50   #124  |  Link
d3rd3vil
Originally Posted by iSeries View Post
Great, so this can be used for movie-only remuxes. Does it retain Dolby Vision?
Ofc not, big surprise
d3rd3vil is offline   Reply With Quote
Old 6th June 2018, 22:44   #125  |  Link
zeropc
how do you guys even manage to use tsmuxer to remux a uhd?
i get constantly error code -2 -> reading buffer overlow
for me it's currently impossible to get a proper remux with tsmuxer of a uhd
zeropc is offline   Reply With Quote
Old 7th June 2018, 00:03   #126  |  Link
LowDead
Elit Amans
Try demux first with mkvextract. Then mux with tsmuxer the separate streams.
//LD
LowDead is offline   Reply With Quote
Old 7th June 2018, 13:31   #127  |  Link
zeropc
//LD
thanks for the tip
tsm2uhd though is not working for me.
i selected the newly created uhd bdmv folder and clicked start. two hours later and the progress is still at 0%
any idea?
Old 14th July 2018, 03:42   #128  |  Link
chin8036
Encounter a problem
Hello, thanks for the effort to make this software, I follow the steps in instruction but the output blu-ray folder can't be played on my Sony UBP-X800 player.
I compare the folders, and found that the software only changed mpls, no other files, and it just used about 2 secs, so I thought it's not normal, do you have any advice or what can I do to fix this?
Thanks
chin8036 is offline   Reply With Quote
Old 13th September 2018, 10:27   #129  |  Link
staina
tsMuxeR do not work with UHD Bluray always ends with error
tsMuxeR finished with error code -2
Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: I:\BDMV\STREAM\00045.m2ts
When will have tsMuxeR full support UHD Bluray and Dolby Vision?
Thank you staina
staina is offline   Reply With Quote
Old 13th September 2018, 14:33   #130  |  Link
jdobbs
Something went wrong... the process takes about 20 mins on my system.
I've used TSMUXER on the source from UHD discs many, many times -- and have never gotten an error. The "buffer overflow" error almost always means a corrupt source (or one that hasn't been decrypted). I do always demux first (as LowDead suggested) and use the elementary streams. As for when it will have full support... probably never. But that would be up to the author. He unexpectedly provided 3D support after a long time of not hearing from him, so you never know.
Website: www.jdobbs.net
Old 30th November 2018, 02:38   #131  |  Link
Lucius Snow
Thanks jdobbs for your work.
Do you advice to burn the folders on BD-50 in UDF 2.5 or 2.6?
By the way, it would be nice to get a list of compatible / not compatible players models.
Lucius Snow is offline   Reply With Quote
Old 1st December 2018, 17:09   #132  |  Link
Ch3vr0n
Afaik UHD requires UDF 2.60, 2.50 is for standard BD's.
Ch3vr0n is offline   Reply With Quote
Old 1st December 2018, 19:57   #133  |  Link
Lucius Snow
I've just made a BD HDR Rec2020 for testing. It works on my UBP-X7000. However, I don't have any HDR screen so the device displays "SDR" on the OSD. How to know if the HDR flag is present properly using this TSM2UHD tool?
EDIT : The log during the post-compilation process says "HDR collected" so it looks OK. But I have no way to be sure...
Old 2nd December 2018, 12:40   #134  |  Link
jdobbs
Really? Is that documented somewhere? I've been using UDF 2.50 and haven't noticed any issues.
Old 2nd December 2018, 18:28   #135  |  Link
veggav
Hey nice to find this tool avalible.
I guess all those tutorials to keep blu-ray menus when adding subtitles and audio tracks with tsmuxer will also work with tsm2uhd.
I used to do this a lot with tsmuxer and later with bdfix (which is a lot easier).
I'll give that a try in a few days and test with my OPPO 203 with russian custom firmware to check if I can add some dubs to complete UHD discs and report back.
veggav is offline   Reply With Quote
Old 2nd December 2018, 20:09   #136  |  Link
Lucius Snow
I'm not sure you can build a Blu-Ray with menus and then replace the streams from H264 to HEVC to change it to Blu-Ray UHD...
Old 3rd December 2018, 15:29   #137  |  Link
veggav
Totally possible.
But as I see how TSM2UHD works you have to
1. demux audio, video and subtitle streams from original disk.
2. Make MKV file with audios and subtitles you want to add.
3. Create UHD BD compilant folder.
4. Change CPLI and playlist files with hex decimal to refer to the same clpi and playlist file the original disk uses.
It's actually quite simple.
TSMuxer used to have a blank spot so you could name your own mpls and clpi files isntead of default 00000 to be 0835 or something.
Maybe this could be added to TSM2UHD since it's just a number to be changed in the output files.
Old 5th December 2018, 17:27   #138  |  Link
Lucius Snow
Totally possible.
Thanks for this tutorial but It's not such easy for a newbie like me
In step 2 and 3, you make a Blu-Ray HD structure from TSMuxer (from HEVC video stream source) and then patch it with TSM2UHD to make it Blu-Ray UHD compliant. Is that what you mean?
In step 4, you open in a hexadecimal editor the CLPI and MPLS from the Blu-Ray UHD
And here are the CLPI and MPLS from the Blu-Ray HD I authored. There's only one video stream and one menu, so the video I want to replace refer to 00001.clpi and 0001.mpls.
What CLPI and MPLS files should i change? Those from the Blu-Ray UHD ? Which values from the hexadecimal data those should i modify exactly?
How to reintegrate the original menu (from the Blu-Ray HD) to the Blu-Ray UHD structure?
Sorry but I'm a bit lost...
Old 7th December 2018, 20:32   #139  |  Link
Lucius Snow
@jdobbs : Can you confirm this is possible? Thank you.
Old 16th December 2018, 19:07   #140  |  Link
UHD 4 Everyone
So over the past week I've been trying to use a combination of TSM2UHD, TS Muxer, ffmpeg, Adobe Encore, and hex editing to create a UHD Disc with menus (even if the menus are 1080p) I know this is probably next to impossible. But when you're making less than $200K/year being able to purchase Scenarist UHD or KITe UHD is out of the question.
Is there anyway to retain menus from a 1080p disc and replace the streams with a UHD stream?
Here's my workflow:
1. Author disc (with menus) in Encore with 1080p streams but match audio content.
2. Render UHD content into MKV containers in x265 that are UHD compliant.
3. Remux blu-ray folder structure (one per stream, except for menu) in tsmuxer using the mpls files and replace streams with uhd h265 elementary files.
4. Drop in new m2ts files into the stream folder.
5. Drop in new mpls files.
6. Re-create entry point instructions in BDEdit
7. Drop in index.bdmv and movieobject.bdmv files from one of the remuxes.
8. Re-create instructions and references of original index and movieobject files in BDEdit.
9. Run TSM2UHD against the structure.*
* When I go through this workflow, TSM2UHD does not recognize the fact that flags need to be changed in every file. I'm not sure why it's not detecting it but the output looks like this:
========Job Started========
[11:34:16] Scanning source for UHD attributes...
 - UHD attributes collected.
 - Scan completed.
[11:34:16] Checking/Adjusting MPLS file...
=========Job Ended=========
So at that point I'm obviously missing a flag somewhere. It could have been overwritten when I re-created the instructions in any of the files. Or it could be that there's still an MPEG-2 stream for the menu and TSM2UHD sees it and refuses to run.
And maybe it would help if tsmuxer could remux an m2ts stream that has a PGS.
Any suggestions on what steps to take? Or where did I make a mistake (besides wasting time attempting this haha)?
UHD 4 Everyone is offline   Reply With Quote
