#21 | Link |
Wewkiee
![]() Join Date: Feb 2002
OK.. the source is available at http://sourceforge.net/projects/batchccews/ on cvs. added is support for 2.70.x , d3s7 added a vaf option, i added stuff from revpulldown so now it can create vif files for scenarist and also avoid .5 errors on ntsc pulldown. This branch is unstable.. i'll make a binary available over the weekend but i havent tested it much (ok.. any) i'll keep you updated.
...yeah...but...why on earth would I compare apples with apples? Last edited by Trahald; 6th May 2005 at 17:01. |
#23 | Link |
Wewkiee
i compiled a unstable version. it is just the .exe . if you have time try it out. especially pal people since i cant really test that. dont use it for mission critical stuff yet. i havent had time to really test it myself. More to come. available at link above on sourceforge.net
here is the change log <0916a unstable> - Added support for cce 2.70.x - Added pan and scan and corrected ntsc .5 errors and create .vif file option (speeds up import in scenarist) by using my modifications to revpulldown - Added option to use existing vaf file - Software is now covered under the GNU General Public License - Max GOP option which picks the biggest gop size (m / n/m ) for film/pal/ntsc-video 12/15/18
...yeah...but...why on earth would I compare apples with apples? Last edited by Trahald; 14th May 2005 at 02:44. |
#24 | Link | |
Wewkiee
...yeah...but...why on earth would I compare apples with apples? |
#25 | Link |
Dutch strain
Working auto angle detection would be nice.
A somewhat more clear procedure when making changes. Now you have to press the replace button. I would rather have a dialog box or so. And keep up the good work of course !
What can I do to protect myself against the flu? By far, the single best way to prevent the flu is for individuals, especially persons at high risk for serious complications from the flu, to get a flu shot each fall. |
#26 | Link |
ScenAid
It does work.... at least w/ the Scenaid Switch
BBWoof finished it before he turned over the project.. just never released a build that had it in Trahald, what version number does this build reflect so I can update Scenaid to use the newer ccedata format w/ this? |
#27 | Link |
Wewkiee
0.9.1.6 even though youve had that for a while (bbwoofs old 0916), since it was never public i decided not to skip the number. If it would be better tho i could just as easy use 0917
...yeah...but...why on earth would I compare apples with apples? Last edited by Trahald; 14th May 2005 at 19:41. |
#29 | Link |
Wewkiee
<0916b Unstable> fixed vif creation ( i added something stupid to my revpulldown code when i brought it over to batchccews.. not sure what i was smoking) fixed now.
i started other stuff but commented it out.. i think i'll make more progress soon as summer comes. i'll work on summore of the suggestions in this post.
#30 | Link | |
Wewkiee
i'll comment out the double stuff ( i imagine some of it is stuff that isnt in 2.50 ecls but is in later versions.. but maybe not) the code isnt commented with a reason.
