Old 21st November 2009, 13:56   #10581  |  Link
Steveo08
Originally Posted by matthew_eli View Post
I'm using Intel g45 (X4500MHD) graphic card
thank, are any other graphiccards with film grain on dxva?
Steveo08 is offline
Old 21st November 2009, 16:48   #10582  |  Link
matthew_eli
Mmmmhh maybe ATI, but I'm not sure...
this is the video that generates the problem on g45, sec 16 (about):
http://uploading.com/files/a3a56d3d/test1_a.mkv/
matthew_eli is offline
Old 21st November 2009, 21:00   #10583  |  Link
Snowknight26
I haven't looked at the sample you provided, but if its a video encoded with x264 and weightp was used, then that's why DXVA is broken on your GPU.
Snowknight26 is offline
Old 22nd November 2009, 02:38   #10584  |  Link
snyders6dogrecipe
I have a bug to report. This doesn't occur with all my files, though: When I have an mkv file with a dts track on, every now and then the video will freeze for a split second. If the alternate ac3 track is selected, it won't freeze. I've dealt with this problem by converting the problematic dts tracks to FLAC. But I'd still like it if this were fixed, since FLAC takes up twice the space.
snyders6dogrecipe is offline
Old 22nd November 2009, 08:43   #10585  |  Link
avivahl
Guys, I compiled a small (~4MB) chm file of the current/latest DirectShow documentation from MSDN. Might be useful/helpful for quickly looking up stuff. (I used "Package This!" together w/ HTML Help Workshop)
Here you go: http://rapidshare.com/files/310473891/DirectShow.rar
avivahl is offline
Old 22nd November 2009, 14:58   #10586  |  Link
Mercury_22
@ Casimir
You have broken PGS Subtitles detection in rev 1338 (or 1339 ?) cause after 1337 I can't find all PGS Subtitles in m2ts files e.g with 1337 I have 19 subtitles and the same file with 1339 has only 2 PGS Subtitles
Can you please fix it ?
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline
Old 22nd November 2009, 17:08   #10587  |  Link
xtdsm
Has there been any progress with regard to solving the slow loading bug that people are experiencing on Windows 7 when using EVR CP? Some people are getting delays up to 30 seconds.
I am having the exact same problem, any solutions yet?
thanks
xtdsm is offline
Old 22nd November 2009, 19:33   #10588  |  Link
tetsuo55
MPC-HC Project Manager
works fine on my X4500HD with latest driver, mpc-hc and windows 7 x64
tetsuo55 is offline
Old 22nd November 2009, 22:17   #10589  |  Link
anybody
I did some digging on this, because i've always suffered from corruptions when using DXVA on the GMA 4500MHD contained in the Intel GS45 Chipset my Laptop is based on.
I'm also using Win7 x64 and the drivers are dated October 30th and version 8.15.10.1986, which according to the Intel Download Site for the 4 Series Graphics Driver is currently the latest version.
As it turns out, this sample produces the usual decoding artifacts on my GMA4500 around second 16-17, but only until build 1326. Starting with build 1327, the problem is gone.
The changelog says:
Revision 1327 - Directory Listing
Modified Wed Nov 4 10:29:29 2009 UTC (2 weeks, 4 days ago) by Aleksoid
fix : ref_num check for non Nvidia card;
anybody is offline
Old 22nd November 2009, 22:20   #10590  |  Link
Abradoks
Do you have any antivirus installed?
Abradoks is offline
Old 22nd November 2009, 22:45   #10591  |  Link
Polcius
What does "Alternative Vsync" do? Why is it recommended to use it?
Polcius is offline
Old 22nd November 2009, 22:53   #10592  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Very often, this problem occurs when using Kaspersky Anti-virus. The problem is precisely Kaspersky Anti-virus, rather than mpc-HC. If you add mpc-hc exception list, it does not help. Only helps you to reinstall your antivirus.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline
Old 22nd November 2009, 23:58   #10593  |  Link
XhmikosR
Kaspersky has released a new version that's supposed to fix that problem. But there is another problem that has nothing to do with KAV.
http://forum.doom9.org/showthread.ph...84#post1345984
My Specs
XhmikosR is offline
Old 23rd November 2009, 04:30   #10594  |  Link
Xorp
Originally Posted by Mercury_22 View Post
@ Casimir
Ya sub language detection is completely broken after 1.3.1337
Xorp is offline
Old 23rd November 2009, 07:06   #10595  |  Link
Lincoln Burrows
Lincoln Burrows's Avatar
Somehow I messed with M2TS subtitles that now I can't get them to work even after reinstalling/uninstalling MPC. I think that happened after I added this filter: "DirectVobSub (auto-loading)" and then removed from the external filters list.
They were working before, and being recognized, along with VMR9-renderless. What should I do?
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things."
Lincoln Burrows is offline
Old 23rd November 2009, 12:51   #10596  |  Link
xtdsm
Kaspersky causing the player itself to load slow, so I uninstalled that and tried MPC-HC and the player loads fast that the actual movie will play in 3-4 seconds. this only happens with EVR-cp. this issue is not present with player 1.2.902 andthing newer than that and the problem occurs.
thanks
xtdsm is offline
Old 23rd November 2009, 12:56   #10597  |  Link
XhmikosR
There are two loading problems.
The first one is that the actual MPC-HC window takes a few seconds to open. That's caused by Kaspersky.
The second one is that the actual MPC-HC window opens instantly but the video takes a few seconds to actually play. This only happens with EVR Custom on Win7 and it's not caused by Kaspersky. The solution is to either use only the internal filters and splitters or if you want to use external ones, set them as preferred in the external filters window. Alternatively, you can always use another renderer like Haali, and the problem will not appear.
BTW, Kaspersky has released a patch2 of version 9.0.0.736. http://www.kaspersky.com/kav_latest_versions
Please Note! Only versions 9.0.0.736 (Critical Fix 2) and higher are compatible with Windows 7.
My Specs
XhmikosR is offline
Old 23rd November 2009, 12:59   #10598  |  Link
tetsuo55
thanks
Can you pinpoint the exact breaking revision more exactly? a lot of commits after 902 are not related to graph building at all.
tetsuo55 is offline
Old 23rd November 2009, 13:56   #10599  |  Link
MatMaul
I already bisect the problem, it appears with belyaal code merge (and doesn't appear with ar-jar branch but I already said that ^^)
MatMaul is offline
Old 23rd November 2009, 13:59   #10600  |  Link
Mercury_22
Strange I don't have this problem (second one) and I'm using Windows 7's + Nero's VC-1 & DTS-HD decoders !
But I don't have Haali (or had ) installed nor any other "codecs" or splitters on my system
So i'm not the only one with PGS subtitle detection problems after svn 1337
dxva, h264, home cinema, media player classic, mpc-hc
