Old 17th May 2019, 09:24   #6821  |  Link
filler56789
SuperVirus
filler56789's Avatar
x265.exe 3.0_Au+25-39b35ea86283
(x64, multilib, GCC 7.4.0)
http://www.mediafire.com/file/ezp7c7...9b35ea86283.7z
filler56789 is offline   Reply With Quote
Old 21st May 2019, 14:29   #6822  |  Link
Barough
Barough's Avatar
x265 v3.0_Au+27-3f4fb9a2ac68 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
https://bitbucket.org/multicoreware/x265/commits/branch/default
Old 24th May 2019, 16:09   #6823  |  Link
Barough
Barough's Avatar
x265 v3.0_Au+30-b9bef1a4c34a (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
Old 28th May 2019, 00:03   #6824  |  Link
Barough
Barough's Avatar
x265 v3.0_Au+31-4583000db964 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
Old 28th May 2019, 12:14   #6825  |  Link
stax76
stax76's Avatar
@Barough
Thanks for the new built. Is there a change log somewhere?
Old 28th May 2019, 13:47   #6826  |  Link
Barough
Barough's Avatar
Originally Posted by stax76 View Post
@Barough
YW stax76
You need 2 check the commits comments on the Bitbucket URL above. There is only a changelog available for the v3.0 Stable version.
Old 28th May 2019, 14:16   #6827  |  Link
stax76
stax76's Avatar
@Barough
Thanks, I found it now.
@Wolfberry
avs input is still not working for me:
[avs2 @ 0000000004623380] Format avs2 detected only with low score of 1, misdetection possible!
[avs2 @ 0000000004623380] Could not find codec parameters for stream 0 (Video: avs2, none): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[NULL @ 0000000004635340] No codec provided to avcodec_open2()
lavf [error]: could not find decoder for video stream
x265 [error]: unable to open input file <C:\Users\john&janedoe\Daten\Samples\test_temp\test.avs>
Old 28th May 2019, 14:30   #6828  |  Link
Barough
Barough's Avatar
x265 v3.0_Au+32-a46ded2c1411 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
Old 28th May 2019, 23:21   #6829  |  Link
benwaggoner
Some interesting checkins in the last couple of weeks, with new parameters!
Has anyone played with the --fades command? As described, it sounds like a useful always-on feature to improve quality/efficiency of fades. x265 didn't seem to have a particular issue with those, but fades are a special case where efficiency and random access can be improved via the described mode.
Ben Waggoner
My Compression Book
Old 29th May 2019, 10:14   #6830  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
I did not build ffmpeg with avisynth support in that build.
Try this build
x265 [info]: HEVC encoder version 3.0+2-b4b1d84566d7
x265 [info]: build info [Windows][GCC 9.1.1][64 bit] 8bit+10bit+12bit
x265 [info]: (libavcodec  58.52.102)
x265 [info]: (libavformat 58.27.103)
x265 [info]: (libavutil   56.28.100)
x265 [info]: (lsmash       2.16.1)
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 31st May 2019, 05:40   #6831  |  Link
stax76
stax76's Avatar
@Wolfberry
Works perfectly, awesome!
@everybody
There was a built that did show the estimated output file size and people have posted positive feedback about this feature, I like it too. Sadly I don't remember from where I got that built.
Old 31st May 2019, 08:20   #6832  |  Link
vanden
Sorry, I may not be in the right forum ...
Here is my problem, I have 2 rip bluray 2160p and the problem is that it must miss some info.
Blade Runner 2049:
Do not pass with "madMeasureDynamicClipping", I rename the file .measurements.incomplete in .measurements and I open it with "madMeasureDynamicClipping":
************** Texte de l'exception **************
System.OverflowException: The arithmetic operation caused an overflow.
à madMeasureDynamicClipping.FrmMain.ImportData()
à madMeasureDynamicClipping.FrmMain.StartAnalysis()
à System.Windows.Forms.Control.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnClick(EventArgs e)
à System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.ButtonBase.WndProc(Message& m)
à System.Windows.Forms.Button.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Reading it with "madMeasureDynamicClipping" I get this :
By removing all the .measurements.incomplete and .measurements files, I get this :
Pass in "Tone map HDR MadVR" :
Sully:
Do not pass with "madMeasureDynamicClipping" :
Do you have a solution ?
T2 Trainspotting everything is ok :
Ok avec "madMeasureDynamicClipping" :
By removing all the .measurements files, I get this :
vanden is offline   Reply With Quote
Old 31st May 2019, 11:22   #6833  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
The feature you are referring to is probably this commit: Cosmetic: x264-r2204 style progress indicator
@MeteorRain's signature contains the link to the x265 binaries built from the Yuuki / Asuna branch of https://github.com/msg7086/x265-Yuuki-Asuna.
Monochrome Anomaly
Old 31st May 2019, 14:56   #6834  |  Link
stax76
stax76's Avatar
The zones feature is broken in 3.0+2, it encodes to the end but returns an error code, cmd/batch users normally don't check for the exit code, so they don't notice the problem but staxrip treats this a fatal and aborts further processing.
ffmpeg -i test.avs -f yuv4mpegpipe - | x265 --crf 22 --output-depth 10 --zones 0,200,b=1.2 --frames 300 --y4m --output test.hevc -
echo %ERRORLEVEL%
pause
Video encoding using x265 3.0+2 Wolfberry failed with exit code: -1073740940 (0xC0000374)
The exit code might be a system error code: A heap has been corrupted.
Probably yes, thanks.
Old 1st June 2019, 08:43   #6835  |  Link
Jamaika
I have a question.
Is it possible to use tune vmaf in x265 v3.1?
x265 has 5 tune modes (psnr, ssim, grain, zero-latency, animation) whereas SVT-HEVC
has only 3 tune modes (0 - visual quality, 1 - PSNR / SSIM and 2 - VMAF). Below
table shows the mapping of tune modes,
| x265 Tune Modes       | SVT-HEVC Tune Modes       |
| vmaf                  | 2                         |
| psnr                  | 1                         |
| ssim                  | 1                         |
| grain                 | 0                         |
| fastdecode            | 0                         |
| zerolatency           | 0                         |
| animation             | 0                         |
If so how to initiate it?
api->param_default_preset(p, preset, "vmaf");
Jamaika is offline   Reply With Quote
Old 7th June 2019, 14:50   #6836  |  Link
Barough
Barough's Avatar
x265 v3.1_RC1+1-10decf67c077 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.1.0)
https://bitbucket.org/multicoreware/x265/commits/branch/Release_3.1
Old 11th June 2019, 11:11   #6837  |  Link
Natty
Noob
Originally Posted by MeteorRain View Post
Did you say you make .yuv raw using ffv1 lossless? So would that be an AVI file instead?
i love your yuuki x265 mod, i used the latest 3.1 version, but observed that it hides encoding settings in mediainfo. i didn't change any encoding setting while using your mod..
hoping to get regular gcc 9.1 build updates from you.
Natty is offline   Reply With Quote
Old 11th June 2019, 19:20   #6838  |  Link
MeteorRain
結城有紀
Natty,
Thank you for the kind word. I have fixed the issue and slip-streamed to the same file.
I intentionally downgraded to gcc 8.3 as I expect a performance regression on newer gcc. But I might change my mind and upgrade to gcc 9.1 on final build. Suggestions welcome.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 12th June 2019, 16:25   #6839  |  Link
Natty
Noob
Natty,
it working fine
Old 14th June 2019, 18:36   #6840  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
Has the meaning of CRF wildly changed since version 2.4?
I'm encoding the same source video using 2.4 and 3.0 using absolutely the same options ( -preset veryslow -x265-params keyint=600:min-keyint=30:bframes=16:crf=22:no-sao=1 - it's relatively static which is why keyint is so high) and 3.0 produces the file which is significantly heavier.
104,103,181 bytes for v2.4
128,682,330 bytes for v3.0
Also encoding has become significantly slower:
2.4: encoded 10656 frames in  6302.40s (1.69 fps), 2229.94 kb/s, Avg QP:27.68
3.0: encoded 10656 frames in 11981.75s (0.89 fps), 2780.38 kb/s, Avg QP:27.30
Full output for 2.4:
x265 [info]: HEVC encoder version 2.4
x265 [info]: build info [Linux][GCC 6.3.1][64 bit] 8bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x265 [info]: Main profile, Level-3.1 (Main tier)
x265 [info]: Thread pool created using 4 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 2 / wpp(12 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 3 inter / 3 intra
x265 [info]: ME / range / subpel / merge         : star / 57 / 4 / 4
x265 [info]: Keyframe min / max / scenecut / bias: 30 / 600 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 40 / 16 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 1
x265 [info]: References / ref-limit  cu / depth  : 5 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress            : CRF-22.0 / 0.60
x265 [info]: tools: rect amp limit-modes rd=6 psy-rd=2.00 rdoq=2 psy-rdoq=1.00
x265 [info]: tools: rskip limit-tu=4 signhide tmvp b-intra
x265 [info]: tools: strong-intra-smoothing deblock
Output #0, matroska, to '265.mkv':
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    encoder         : Lavf57.71.100
    Stream #0:0(eng): Video: hevc (libx265), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 29.83 fps, 1k tbn, 29.83 tbc (default)
    Metadata:
      handler_name    : VideoHandler
      encoder         : Lavc57.89.100 libx265
    Stream #0:1(eng): Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, mono, fltp, 96 kb/s (default)
    Metadata:
      handler_name    : SoundHandler
frame=10656 fps=1.7 q=-0.0 Lsize=  101663kB time=00:05:57.24 bitrate=2331.2kbits/s speed=0.0567x
video:97282kB audio:4187kB subtitle:0kB other streams:0kB global headers:2kB muxing overhead: 0.192047%
x265 [info]: frame I:     20, Avg QP:20.80  kb/s: 13832.49
x265 [info]: frame P:   2322, Avg QP:22.77  kb/s: 6661.60
x265 [info]: frame B:   8314, Avg QP:29.07  kb/s: 964.32
x265 [info]: Weighted P-Frames: Y:11.9% UV:9.3%
x265 [info]: Weighted B-Frames: Y:6.8% UV:4.4%
x265 [info]: consecutive B-frames: 7.3% 5.3% 8.5% 30.1% 16.4% 21.8% 6.9% 3.2% 0.2% 0.2% 0.1% 0.0% 0.0% 0.0% 0.0% 0.0% 0.0%
Full output for 3.0:
x265 [info]: build info [Linux][GCC 9.1.1][64 bit] 8bit+10bit+12bit
x265 [info]: ME / range / subpel / merge         : star / 57 / 4 / 5
x265 [info]: References / ref-limit  cu / depth  : 5 / off / off
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 2 / 1.0 / 32 / 1
x265 [info]: tools: rect amp rd=6 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 rskip
x265 [info]: tools: signhide tmvp b-intra strong-intra-smoothing deblock
  Metadata:
    major_brand     : mp42
    minor_version   : 0
    compatible_brands: isommp42
    com.android.version: 6.0
    encoder         : Lavf58.20.100
    Metadata:
      encoder         : Lavc58.35.100 libx265
    Metadata:
frame=10656 fps=0.9 q=-0.0 Lsize=  125666kB time=00:05:57.24 bitrate=2881.6kbits/s speed=0.0298x
video:121284kB audio:4187kB subtitle:0kB other streams:0kB global headers:2kB muxing overhead: 0.155674%
x265 [info]: frame I:     20, Avg QP:20.69  kb/s: 16303.41
x265 [info]: frame P:   2322, Avg QP:22.30  kb/s: 8450.15
x265 [info]: frame B:   8314, Avg QP:28.71  kb/s: 1164.35
birdie is offline   Reply With Quote
