16th March 2006, 18:21 | #82 | Link |
Ridendo Castigat Mores
@neuron2
Consider this just a retoric question... but feel free to answer Most of the encoders use "kbps" for bitrates so... I wonder... why does DGIndex gives "Mbps" results? [Isn't it funny that people that can't find BIG flaws start looking for details? ]
None is as blind as those that don't listen. www.dvdrebuilder.com RME Rockas Software |
16th March 2006, 21:24 | #83 | Link | |
16th March 2006, 22:35 | #84 | Link |
OT
I noticed that when making my calculations for target sizes when encoding and the funny stuff is that I can multiply by 1000 and it comes out fine... should the multiply be by 1024? is bitrate velues following the DVD media makers scale?
18th March 2006, 15:39 | #86 | Link |
DGMPGDec 1.4.7 beta 5
* Added a new option called Use Full Paths. When enabled,
behavior is as it always has been. When disabled, only file names (not full paths) are used as references in the D2V and generated AVS files. This makes it easier to move project files. This new option was contributed by Christian Eberl. Thank you, Chris! * Changed the exception handling in DGIndex. Previously an exception would abort the entire preview or save project operation. Now only the current picture decoding is aborted. http://neuron2.net/dgmpgdec/dgmpgdec147b5.zip Last edited by Guest; 19th March 2006 at 03:13. |
23rd March 2006, 18:51 | #87 | Link |
i think i found a bug,
here is the screenshot: http://img223.imageshack.us/img223/2526/d2v5fb.png notice the black line in the bottom? Here are the avs and the dgindex options im using, the source video is 800x600 @ 24fps, resize to 640x480 with bicubic: Code:
start /low/b/w D:\DGIndex\DGIndex.exe -IA=7 -OM=0 -IF=[%~1] -OF=[%~dpn1] -exit Code:
loadplugin("D:\DGIndex\DGDecode.dll") mpeg2source("D:lapis_pvs.d2v").BicubicResize(640,480, 0, 0.5) its only happen when 800x600 mpeg1 video clips resized to any resolution. Last edited by Guest; 24th March 2006 at 01:51. |
24th March 2006, 07:05 | #89 | Link |
Here is the link...
http://www.mytempdir.com/540138 Last edited by Yong; 24th March 2006 at 13:36. |
24th March 2006, 18:45 | #91 | Link |
Sorry man, i dont know how to cut the mpeg file,
so i use mkvtoolnix... its the original mpeg1 stream with mpeg layer 2 audio. i didnt test carefully, the mkvextract doesnt support extract mpeg1 stream... i tried remux to mpeg contrainer with mencoder and it works, i think you should try it too... |
24th March 2006, 19:14 | #93 | Link |
Life's clearer in 4K UHD
Hi Yong,
You could have used AVI-Mux to demux the the RAW (.m1v) stream out of the .MKV container. And MPEG Multiplexer to mux that stream into the .MPG container... Cheers
24th March 2006, 22:09 | #95 | Link |
The raw MPEG-1 stream does not appear to contain much header information.... When you load it into Gspot all you see is this: -
Cheers
25th March 2006, 01:35 | #96 | Link | |
Anyway, don't bother. You have to crop in your Avisynth script. |
26th March 2006, 10:32 | #98 | Link | |
tried this last night and loved the option to create an avs script with the clips name.
looked through this thread and the included read me's and couldnt see if there was an option to do the same with the ac3 if used as a source in the AVS script? hopefully the same with the audio delay info i.e. Quote:
if this is not possible at the mo, any chance of making it a feature request for future versions? would save time when doing a lot of scripts EDIT ---- just found the __aud__ option - must have missed that one last time. hopefully will find an option somewhere for the delay also Last edited by tomos; 26th March 2006 at 12:51. |
15th April 2006, 01:33 | #99 | Link |
Version 1.4.7 beta 6
This beta adds an option to enable/disable use of the DirectDraw overlay.
http://neuron2.net/dgmpgdec/dgmpgdec147b6.zip |
15th April 2006, 21:58 | #100 | Link |
Thanks for your excellent work, neuron!
I have a feature request - when a .ts file is opened by dragging it over the window and dropping, the File List requester is shown. However, when using Open With in the context menu, DGIndex is launched but fails to open the file. Apparently windows calls the app with "appname.exe" "%1" where %1 is the filename. |
