8th March 2006, 04:00 | #41 | Link | |
A shut mouth gathers no foot |
9th March 2006, 07:35 | #42 | Link |
Hello,
is it possible to add to future version of DGIndex also support for DTS tracks in TS files? It is used for HighDef videos and the only program that can extract DTS from TS is ProjectX but it is written in Java and not working for me Or does anyone know any other program that can do that? Thanks in advance |
9th March 2006, 15:01 | #44 | Link | |
When saving to different filename now I have to do these unnecessary things: - specify another filename - delete new project file after saving - rename demuxed audio files (according to the name of main project) |
9th March 2006, 15:15 | #45 | Link | |
9th March 2006, 15:20 | #46 | Link | |
Life's clearer in 4K UHD
I remember mentioning the same thing as Michal before Xmas but never got around to providing a sample.... Sorry about that
9th March 2006, 17:26 | #47 | Link | |
http://neuron2.net/dgmpgdec/quantdump11.zip |
9th March 2006, 20:11 | #49 | Link | |
10th March 2006, 02:08 | #50 | Link |
DGMPGDec 1.4.7 beta 4
DGMPGDec 1.4.7 beta 4:
* The quants log now includes the frame numbers at which the matrices appear. * Fixed garbage in the file list caused when hitting the Up button with an empty list. * Fixed bug in AVS template support that caused paths with spaces to fail. http://neuron2.net/dgmpgdec/dgmpgdec147b4.zip Last edited by Guest; 10th March 2006 at 02:10. |
10th March 2006, 09:01 | #51 | Link | |
Pig on the wing
10th March 2006, 10:14 | #52 | Link | |
Command line:C:\Test\QuantDump.exe C:\Test\AbbaZappa.mpg C:\Test\AbbaZappa.txt: Working Other aspects of your tool are working great! Cheers Taurus |
10th March 2006, 10:19 | #53 | Link |
MPEG-2 with DTS .TS audio sample
Hi Donald,
I've uploaded an 80 MB .TS sample to your ftp server.... If memory serves it contains 3No audio tracks in total. 1No 6Ch AC3 stream (in English), 1No 6Ch AC3 stream (in German) and 1No 6Ch DTS stream (in English)... Cheers and thanks
10th March 2006, 10:25 | #54 | Link | |
Pig on the wing
10th March 2006, 10:50 | #55 | Link |
Ridendo Castigat Mores
@Taurus
just to complete Boulder's iformation... "C:\Test\QuantDump.exe" "C:\Test\Abba Zappa.mpg C:\Test\Abba Zappa.txt" the quotes around "C:\Test\QuantDump.exe" is not needed in your case but if you have the executable on a folder like "test app" then you really need to use them... something like: "C:\Test app\QuantDump.exe" "C:\Test\Abba Zappa.mpg C:\Test\Abba Zappa.txt"
None is as blind as those that don't listen. www.dvdrebuilder.com RME Rockas Software |
10th March 2006, 10:58 | #56 | Link | |
This was just a stupid mistake on my side. You learn something everyday @ Doom9's Forum! |
10th March 2006, 11:28 | #58 | Link |
Yes... sorry... my fault
Corrected examples: "C:\Test\QuantDump.exe" "C:\Test\Abba Zappa.mpg" "C:\Test\Abba Zappa.txt" "C:\Test app\QuantDump.exe" "C:\Test\Abba Zappa.mpg" "C:\Test\Abba Zappa.txt"
11th March 2006, 12:24 | #59 | Link |
With DVD 'The Beatles - Help!' there's a timeline navigation problem.
Here's a part of d2v project: Code:
900 6 0 229392384 9 3 72 73 d0 f1 f2 e3 f0 f1 e2 f3 f0 e1 900 6 0 229431296 9 3 72 73 d0 f1 f2 e3 f0 f1 e2 f3 f0 e1 900 6 0 229468160 9 3 72 72 d2 e2 900 6 0 229519360 10 1 d2 d00 6 0 229529600 11 1 d3 f0 f1 e2 f3 f0 e1 f2 f3 e0 900 6 0 229570560 11 1 70 70 d0 f0 f0 e0 f0 f0 e0 f0 f0 e0 900 6 0 229752832 11 1 70 70 d0 f0 f0 e0 f0 f0 e0 f0 f0 e0 When navigating backwards, it's ok -- 'vob 11', 'vob 10' and 'vob 9' are shown. I can provide a sample, but I don't know good tools for cutting VOB files.. |
11th March 2006, 12:32 | #60 | Link | |
Pig on the wing
