27th July 2017, 14:27 | #1 | Link |
Khameleon: bidirectional masking cleaner
For some time I have had frustrations trying to prevent certain denoisers from getting more details of an image, especially with animé/cartoon.
I came to use masks, but I noticed that even mt_edge(mode="sobel") did not fulfill for me what he wanted to achieve. One day it came to my hands DeHaloH, and I loved the way it takes the edges of the images, thanks mainly to the Camembert function, and there was no turning back. Recently I thought if you could not reverse the process, that is, only clean the inside of what delimits the edges and in this way simplify the annoying configuration of cleaning and try to retain as much detail. So I came up with a two-way (bidirectional) function, Khameleon, for its chameleon effect. Code:
# Khameleon: bidirectional masking cleaner # version 1.11, 27/05/2021 # Based in DeHaloH, thanks to the authors! # Developed by GMJCZP # # Requirements: TCannyMod, RGTools, MaskTools2, TUnsharp # SUGGESTIONS FOR CLEANING/RESTORING # - Suggestions for restoring edges: # denoised = input.neo_MiniDeen(radius=2, thrY = 10 ,thrUV = 0,u=2,v=2) (used by default by DeHaloH) # denoised = input.frfun7(1.01,3.0,0).frfun3b(s=8,T=3,tuv=7).neo_MiniDeen(radius=2, thrY = 5 ,thrUV = 0,u=2,v=2) # denoised = input.frfun7(1.01,14,0).fft3dfilter(sigma=3,sigma2=3.25,sigma3=3.5,sigma4=6).neo_MiniDeen(radius=2, thrY = 10 ,thrUV = 0,u=2,v=2) # denoised = input.fft3dfilter(sigma=3,sigma2=3.25,sigma3=3.5,sigma4=6).neo_MiniDeen(radius=2, thrY = 15 ,thrUV = 0,u=2,v=2) # - Suggestions for inner cleaning: # denoised = input.Temporalsoften(2,3,3,mode=2,scenechange=6) # denoised = input.dfttest(sigma=2, tbsize=1) Function Khameleon(clip denoised, clip input, int "DR_Radius", bool "Maska", int "mode", \ bool "edge", bool "focus", int "str_focus", float "gamma", float "cont", bool "sobel") { edge = Default(edge, true) mode = Default(mode, edge ? 0 : 1) Maska = Default(Maska, false) DR_Radius = Default(DR_Radius, 0) focus = Default(focus, false) str_focus = Default(str_focus, 40) gamma = Default(gamma, 1.0) # 2.0 for inner cleaning is interesting cont = Default(cont, 1.0) sobel = Default(sobel, false) Assert(!(edge == true && gamma <> 1.0), "Gamma values can only be varied for inner cleaning") Assert((mode == 0 || mode == 1), "Wrong value for mode") Assert(!(focus == true && edge == false), "Focus = true: only valid for edge=true") EM = mode == 0 ? input.Camembert2() : input.tweak(cont=cont).TCannyMod(sobel=sobel) input_low = 1 gamma = gamma input_high = 128 output_low = 255 output_high = 0 lmask = input.mt_lut(Yexpr = "x " +string(input_low)+ " - " +string(input_high)+ " " +string(input_low)+ " - / 1 " +string(gamma)+ \ " / ^ " +string(output_high)+ " " +string(output_low)+ " - * " +string(output_low)+ " +", U=2,V=2).invert().RemoveGrain(12)#.blur(0.5) RM = DR_Radius(EM,DR_Radius,0) full = mt_logic(RM, lmask, "and") full = edge ? full : full.Invert().mt_deflate().mt_binarize(threshold=192) # For blurring edges denoised = (edge == true && focus == true) ? denoised.spline16Resize(int(width(input)*1.5),int(height(input)*1.5)).tunsharp(str_focus,type=5).spline16Resize(width(input),height(input)) \ : denoised denoised = Maska ? denoised.Invert() : denoised return mt_merge(input, denoised, full) } Function DR_Radius(clip i, int dr_rad, int count) { return count > dr_rad ? i : DR_Radius(i.mt_expand(), dr_rad, count+1) } function Camembert2(clip input) { input a=RemoveGrain(12,-1).RemoveGrain(12,-1) mt_makediff(a,input) mt_lut("x 128 - abs 2 *") greyscale() mt_lut(Yexpr = "X 0 - 115 0 - / 1 1.0 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) mt_lut(Yexpr = "X 0 - 64 0 - / 1 0.4 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) RemoveGrain(12) mt_lut(Yexpr = "X 0 - 30 0 - / 1 1.0 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) return (last) } TCannyMod, RGTools, MaskTools2, TUnsharp * Syntax and Parameters - clip denoised Clip to which the filtering is going to apply, for example: denoised = neo_MiniDeen(radius=2, thrY = 10 ,thrUV = 0,u=2,v=2) (used by default by DeHaloH) denoised = dfttest (sigma = 2, tbsize = 1) (for inner cleaning) - clip input Original clip - int "DR_Radius" = 0 Analogous to DeHaloH, it represents the radius or detection range. - bool "Maska" = false If true, the detection mask will be displayed. - int "mode" = 0 The detection mode. By default (mode = 0) the Camembert function is used. Mode = 1 uses TcannyMod. I recommend mode = 0 for cleaning edges and mode = 1 for inner cleaning, but the decision is at the taste of each person. - bool "edge" = true Defines whether to clean the edge or the inside of the images. Now let's look at other additional parameters: a) For edge = "true" - bool "focus" = false If true, it will try to reverse the blur caused by edge cleaning. - int "str_focus" = 40 Defines the focusing force. b) For mode = 1 - float "gamma" = 1.00 By increasing this value, it can help improve edge detection to protect. - float "cont" = 1.0 As with "gamma", increasing this value may improve edge detection. - bool "sobel" = false If true, it improves edge detection. * Examples For cleaning edges: orig = last denoised = neo_MiniDeen(radius=2, thrY = 10 ,thrUV = 0,u=2,v=2) Khameleon(denoised, orig, DR_Radius=0, edge=true, focus=true, str_focus=40) For inner cleaning: orig = last denoised = dfttest(sigma=2, tbsize=1) Khameleon(denoised, orig, DR_Radius=1, mode=1, edge=false, focus=false, gamma=2.0, cont=2.0, sobel=true) * Tips for cleaning edges (for edge=true, use your favourite combo): neo_MiniDeen: is good for halos and mosquito noise. frfun7: good for general cleaning and for light aliasing. fft3dfilter: it's great for rebuilding borders and general cleaning. frfun3b: for general cleaning. (only for 8 bits!) dfttest: for general cleaning. vsDegrainMedian: may be good for random dots and mosquito noise. Last edited by GMJCZP; 9th September 2021 at 20:40. Reason: Changed to version 1.11, update information for frfun7 |
27th July 2017, 15:05 | #2 | Link |
Always looking for a good edge cleaner. I just discovered DeHaloHMod myself and was impressed at how well it removed mosquito noise and dark halos while preserving animation lines. I'll try out your solution as well.
edit: I should add that using DehaloHMod(smooth=true) inverts the mask and only cleans on the inside toward the lines. Similar to what you're trying to achieve. Last edited by SaurusX; 27th July 2017 at 16:32. |
16th February 2018, 11:35 | #4 | Link |
Khameleon 1.1:
- Now by default mode = 0 when edge = true, otherwise mode = 1 |
17th February 2018, 04:18 | #7 | Link | |
About Tunsharp x64 Groucho2004 only uploaded the x86 version. |
17th February 2018, 04:32 | #8 | Link |
I'll post a 64 bit version tomorrow.
Groucho's Avisynth Stuff |
17th February 2018, 04:37 | #9 | Link | |
# denoised = input.Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) (used by default by DeHaloH) Code:
# denoised = input.Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) (used by default by DeHaloH) |
17th February 2018, 13:19 | #10 | Link |
I do not know if I understood you, but the example would use it like this:
denoised = input.Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) |
17th February 2018, 13:45 | #11 | Link |
Code in the OP is experiencing syntax error. I have highlighted the parts that are causing avisynth to fail.
# Khameleon: bidirectional masking cleaner # Version 1.1, 16/02/2018 # Based in DeHaloH, thanks to the authors! # Developed by GMJCZP # # Requirements: TCannyMod, RGTools, MaskTools2, TUnsharp # SUGGESTIONS FOR CLEANING/RESTORING # - Suggestions for restoring edges: # denoised = input.Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) (used by default by DeHaloH) # denoised = input.frfun7(1.01,3.0,0).frfun3b(s=8,T=3,tuv=7).Deen("a2d", 2, 5 , 0, 0, 0, 0, 0) # denoised = input.frfun7(1.01,14,0).fft3dfilter (sigma=3,sigma2=3.25,sigma3=3.5,sigma4=6).Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) # denoised = input.fft3dfilter(sigma=3,sigma2=3.25,sigma3=3.5,sigma4=6).Deen ("a2d", 2, 15 , 0, 0, 0, 0, 0) # - Suggestions for inner cleaning: # denoised = input.Temporalsoften(2,3,3,mode=2,scenechange=6) # denoised = input.dfttest(sigma=2, tbsize=1) Function Khameleon(clip denoised, clip input, int "DR_Radius", bool "Maska", int "mode", \ bool "edge", bool "focus", int "str_focus", float "gamma", float "cont", bool "sobel") { edge = Default(edge, true) mode = Default(mode, edge ? 0 : 1) Maska = Default(Maska, false) DR_Radius = Default(DR_Radius, 0) focus = Default(focus, false) str_focus = Default(str_focus, 40) gamma = Default(gamma, 1.0) # 2.0 for inner cleaning is interesting cont = Default(cont, 1.0) sobel = Default(sobel, false) Assert(!(edge == true && gamma <> 1.0), "Gamma values can only be varied for inner cleaning") Assert((mode == 0 || mode == 1), "Wrong value for mode") Assert(!(focus == true && edge == false), "Focus = true: only valid for edge=true") EM = mode == 0 ? input.Camembert2() : input.tweak(cont=cont).TCannyMod (sobel=sobel) input_low = 1 gamma = gamma input_high = 128 output_low = 255 output_high = 0 lmask = input.mt_lut(Yexpr = "x " +string(input_low)+ " - " +string (input_high)+ " " +string(input_low)+ " - / 1 " +string(gamma)+ \ " / ^ " +string(output_high)+ " " +string(output_low)+ " - * " +string(output_low)+ " +", U=2,V=2).invert().RemoveGrain(12)#.blur(0.5) RM = DR_Radius(EM,DR_Radius,0) full = mt_logic(RM, lmask, "and") full = edge ? full : full.Invert().mt_deflate().mt_binarize(threshold=192) # For blurring edges denoised = (edge == true && focus == true) ? denoised.spline16Resize(int(width (input)*1.5),int(height(input)*1.5)).tunsharp(str_focus,type=5).spline16Resize (width(input),height(input)) \ : denoised denoised = Maska ? denoised.Invert() : denoised return mt_merge(input, denoised, full) } Function DR_Radius(clip i, int dr_rad, int count) { return count > dr_rad ? i : DR_Radius(i.mt_expand(), dr_rad, count+1) } function Camembert2(clip input) { input a=RemoveGrain(12,-1).RemoveGrain(12,-1) mt_makediff(a,input) #input #a=RemoveGrain(12).RemoveGrain(12) #mt_adddiff(input,mt_makediff(a,input)) mt_lut("x 128 - abs 2 *") greyscale() mt_lut(Yexpr = "X 0 - 115 0 - / 1 1.0 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) mt_lut(Yexpr = "X 0 - 64 0 - / 1 0.4 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) RemoveGrain(12) mt_lut(Yexpr = "X 0 - 30 0 - / 1 1.0 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) return (last) } Here is the corrected script: Code:
# Khameleon: bidirectional masking cleaner # Version 1.1, 16/02/2018 # Based in DeHaloH, thanks to the authors! # Developed by GMJCZP # # Requirements: TCannyMod, RGTools, MaskTools2, TUnsharp # SUGGESTIONS FOR CLEANING/RESTORING # - Suggestions for restoring edges: # denoised = input.Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) (used by default by DeHaloH) # denoised = input.frfun7(1.01,3.0,0).frfun3b(s=8,T=3,tuv=7).Deen("a2d", 2, 5 , 0, 0, 0, 0, 0) # denoised = input.frfun7(1.01,14,0).fft3dfilter(sigma=3,sigma2=3.25,sigma3=3.5,sigma4=6).Deen("a2d", 2, 10 , 0, 0, 0, 0, 0) # denoised = input.fft3dfilter(sigma=3,sigma2=3.25,sigma3=3.5,sigma4=6).Deen("a2d", 2, 15 , 0, 0, 0, 0, 0) # - Suggestions for inner cleaning: # denoised = input.Temporalsoften(2,3,3,mode=2,scenechange=6) # denoised = input.dfttest(sigma=2, tbsize=1) Function Khameleon(clip denoised, clip input, int "DR_Radius", bool "Maska", int "mode", \ bool "edge", bool "focus", int "str_focus", float "gamma", float "cont", bool "sobel") { edge = Default(edge, true) mode = Default(mode, edge ? 0 : 1) Maska = Default(Maska, false) DR_Radius = Default(DR_Radius, 0) focus = Default(focus, false) str_focus = Default(str_focus, 40) gamma = Default(gamma, 1.0) # 2.0 for inner cleaning is interesting cont = Default(cont, 1.0) sobel = Default(sobel, false) Assert(!(edge == true && gamma <> 1.0), "Gamma values can only be varied for inner cleaning") Assert((mode == 0 || mode == 1), "Wrong value for mode") Assert(!(focus == true && edge == false), "Focus = true: only valid for edge=true") EM = mode == 0 ? input.Camembert2() : input.tweak(cont=cont).TCannyMod(sobel=sobel) input_low = 1 gamma = gamma input_high = 128 output_low = 255 output_high = 0 lmask = input.mt_lut(Yexpr = "x " +string(input_low)+ " - " +string(input_high)+ " " +string(input_low)+ " - / 1 " +string(gamma)+ \ " / ^ " +string(output_high)+ " " +string(output_low)+ " - * " +string(output_low)+ " +", U=2,V=2).invert().RemoveGrain(12)#.blur(0.5) RM = DR_Radius(EM,DR_Radius,0) full = mt_logic(RM, lmask, "and") full = edge ? full : full.Invert().mt_deflate().mt_binarize(threshold=192) # For blurring edges denoised = (edge == true && focus == true) ? denoised.spline16Resize(int(width(input)*1.5),int(height(input)*1.5)).tunsharp(str_focus,type=5).spline16Resize(width(input),height(input)) \ : denoised denoised = Maska ? denoised.Invert() : denoised return mt_merge(input, denoised, full) } Function DR_Radius(clip i, int dr_rad, int count) { return count > dr_rad ? i : DR_Radius(i.mt_expand(), dr_rad, count+1) } function Camembert2(clip input) { input a=RemoveGrain(12,-1).RemoveGrain(12,-1) mt_makediff(a,input) #input #a=RemoveGrain(12).RemoveGrain(12) #mt_adddiff(input,mt_makediff(a,input)) mt_lut("x 128 - abs 2 *") greyscale() mt_lut(Yexpr = "X 0 - 115 0 - / 1 1.0 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) mt_lut(Yexpr = "X 0 - 64 0 - / 1 0.4 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) RemoveGrain(12) mt_lut(Yexpr = "X 0 - 30 0 - / 1 1.0 / ^ 255 0 - * 0 +", U=2,V=2) RemoveGrain(12) return (last) } |
30th November 2023, 02:22 | #14 | Link |
This version replaced TCannyMod with vsTCanny:
https://gitlab.com/uvz/AviSynthPlus-...ref_type=heads |
edge detection, khameleon, masking cleaner, restoring |
