5th April 2002, 16:15 | #221 | Link |
At present, ive put a "Rip DVD" option in the file menu...clicking this: Authenticates the disc, finds the main movie & displays all the ifo information for. You can then select PGC, audio stream you want & where you want to save the rip to...then click rip. Its basic but is enough for most people (there is also a little combo box so you can select the other titles on the DVD other than the main one)
-Nic |
5th April 2002, 17:45 | #223 | Link | |
I hope I can get away with saying, IMHO, I do think any program like this project can suffer from feature creep if developers are not on their guard. Sure, I can see dvd2avi doing most of the divx process but not the svcd. IMO, if you guys try to make dvd2avi too simple (edit: dumbed down do it all) you will end up making it too complicated. Perhaps it would not be a good idea to change the simple interface we all know and love too much? Again, I hope I have not offended anybody. That is not my intention. Last edited by ShinerSpoon; 5th April 2002 at 20:03. |
5th April 2002, 19:09 | #224 | Link |
I agree on not changing the interface, but I can see DVD2AVI creating the MP2 Audio & the AVS Script & D2V for SVCD. (as it does all the above already in my version)
(I assume thats what you need for SVCD conversion...unfortunatly don't know anything about it ) -Nic |
5th April 2002, 19:58 | #225 | Link | |
Most would agree that project design is always about the target audience anyway. Those people that are NOT interested in hand creation but that NEEDED complex svcd structures would want to use dvd2svcd anyway. It does this well, very well actually, and automates the whole process. The point being that they would not be the target audience of this project. People that like to manually do the process and tweak (like using RobShots method) are the target as I see it. Personally, I would like to have both methods available to me. They have different purposes and would compliment each other depending on the mission. |
5th April 2002, 23:09 | #226 | Link |
Still Laughing
I detest the sendkeys and other 'hacks' of DVD2SVCD. I'm only saying I would enjoy a version of DVD2AVI that I feed vob files, and it outputs an mp2 (or two), a d2v, and an avs. I don't want it doing anything else. I don't need it to open CCE, run CCE, calculate bitrate or anything.
Of course, if someone has issues with this, I'll just make a variant and keep it to myself and the other blackhats I associate with in the other part of the 'scene' I'm not looking for ways to 'simplify' ripping, I'm looking for ways to batch rip, where I can rip multiple DVDs quicker. Just the fact that DVD2AVI will be generating my mp2 files will save me at least 10 or so minutes of just commandline typing. |
6th April 2002, 00:29 | #227 | Link | ||
6th April 2002, 20:03 | #230 | Link |
Vlad, the Buffy slayer
A little off the topic but I need help
I'm sorry, I'm a little off the topic.
When I compile the CVS of Save-oe I get strange warning about ddraw.h. I have the latest Windows SDK with only a pre-release of DirectX 8.1 SDK. I'm currently downloading another DirectX SDK to check this out (It's so slow, I think it will be finished tomorrow). Do I really need the latest DirectX SDK ?? Is there any other trick I must know ?? A last hint, I compiled Mpeg2dec.dll without any problem. Thanks in advance
Vlad59 Convolution3D for avisynth 2.0X : http://www.hellninjacommando.com/con3d Convolution3D for avisynth 2.5 : http://www.hellninjacommando.com/con3d/beta |
6th April 2002, 21:15 | #231 | Link |
Offhand, I don't remember any DirectX specific warnings. I do have it in my libraries but that is because it was already there from other projects.
For some reason VS6 seems to remember the same library for all workspaces. I don't know how to override this but wish I did. - Tom |
6th April 2002, 22:56 | #232 | Link |
I found it
I found the problem, I thought it was a Directdraw problem but it is a CPU detection problem.
At home, VS6 is installed on an old K6-400 (With MMX, 3DNow and no SSE) : when I load a vob file it crash. I tested the same exe on my laptop (P3-750 with SSE) and no crash at all. I'll check this precisely later (I have to sleep). In fact I should be the last one to have an oldy CPU like that
7th April 2002, 04:01 | #233 | Link |
I think there is a quirk in DVD2AVI about remembering what type of processor to use. If the DVD2AVI.ini file says you want SSE IDCT process then it will try to use that even if you are now on a new machine that does not support it. The fix is to delete the DVD2AVI.ini file.
- Tom |
7th April 2002, 08:43 | #234 | Link |
I don't think that's the problem
In fact IDCT_CONST_PREFETCH is called in getpic.c without checking IDCT_Flag. IDCT_CONST_PREFETCH use the prefetchnta instruction so the program don't work on my K6-400 (it has no SSE and not extended 3Dnow).
I will have to test the program on my P3-750 .
8th April 2002, 03:16 | #235 | Link |
vlad -
Yep, that's an obvious bug. I meant to fix that today and also check in mpeg2dec but other things came up. I'll try to fix them tomorrow if you haven't already. It wasn't meant to restrict either program to P3 or higher. - Tom |
8th April 2002, 08:40 | #236 | Link |
I'm sorry but I don't think I'll be able to correct the problem myself. I'm mainly a Java programmer, I can read and eventually fix C or C++ code but I'm a real newbie in MMX, SSE, 3DNow, ...
I just found (with google help) that prefetchnta was not available in K6 CPU. I'm trying to learn MMX and SSE but I begin ........ Sorry again Edit : I fact prefetch is not so hard to understand, I think I can try to fix it as soon as I come home (in about 8 hours)
Vlad59 Convolution3D for avisynth 2.0X : http://www.hellninjacommando.com/con3d Convolution3D for avisynth 2.5 : http://www.hellninjacommando.com/con3d/beta Last edited by vlad59; 8th April 2002 at 10:11. |
8th April 2002, 18:17 | #237 | Link |
vlad59 -
I did a bit of testing and that particular prefetch call did not help performance even on P4's, so I took it out of DVD2AVI & MPEG2DEC. Also it should be okay now if you load someone else's dvd2avi.ini file without trying to use sse2 code on a P2 or K6-II. The source is in Sourceforge. You can find TEST versions of both (with source) at: www.trbarry.com/DVD2AVIT3.zip and www.trbarry.com/MPEG2DEC2.zip - Tom |
8th April 2002, 21:42 | #238 | Link |
OK, no more crash. Thanks.
10th April 2002, 03:23 | #239 | Link |
Oops. Someone just contacted me and let me know that I'd left the file DVD2AVI2.exe out of the zip above. It should be there now.
It looks like I was over zealous in cleaning out intermediate files to make the zip smaller. - Tom |
10th April 2002, 09:27 | #240 | Link |
BUG ?
Hello ,
I just tested the build that TBarry posted but it crashes on my compu. After I load a mpeg2 file I get a msg "You video card cannot handle YUV display. Conversion will work, but you will not get any display in YUV mode" and when I pres ok it crashes. Im running W2K on a P3 550 with 256MB ram. /DrKnowlittle |
