Old 12th September 2018, 22:34   #52401  |  Link
Damien147
I was 8 bit full RGB 4:4:4 but some settings made me wonder.Thanks for the info.
Damien147 is offline   Reply With Quote
Old 13th September 2018, 01:42   #52402  |  Link
YGPMOLE
To keep the video signal untouched and to avoid unwanted colorspace conversion, I set the LAV Video decoder to output RGB24, madVR range at 0-255 and video driver to full RGB 4:4:4 (as from the F.A.Q.). Works fine for SD and HD 8 Bit videos WITHOUT hardware acceleration (unchecked for SD and HD files).
To watch UHD HEVC 10 Bit videos, I do need hardware acceleration, so I have to uncheck RGB24 8 Bit and output at P010 10 Bit dxva in the LAV video decoder.
In this case, does madVR the P010 -> RGB conversion? It's possible to avoid it (I mean, does exist a way to output RGB 10 Bit directly from the LAV filter)?
Best Regards! Leo!
YGPMOLE is offline   Reply With Quote
Old 13th September 2018, 02:20   #52403  |  Link
Asmodian
That is wrong. If you want to avoid unwanted color space conversion do not uncheck any options in LAV. You are forcing LAV to do a color space conversion. The video is not RGB. LAV does not do very high quality conversion to RGB either, since it should only very rarely be used. Leave LAV on defaults or even check every option (assuming you are using madVR). LAV will only do conversions if they are required (or forced by the user), otherwise it will pass the video to madVR completely untouched.
You do not want LAV to covert the P010 to RGB, let madVR do that. madVR is much better at it and this keeps all color space conversions internal to madVR, and in 16 bit.
Sorry to nitpick but "RGB 4:4:4" makes no sense and I don't think any driver has a "RGB 4:4:4" option.
madVR options explained
Old 13th September 2018, 02:20   #52404  |  Link
Clammerz
You are actually doing the opposite of what you want to achieve. You are introducing an unwanted colorspace conversion. You are forcing LAV to upscale the chroma data to match the luma resolution bypassing madVR, so your chrome setting in madVR are having no affect at all.
Leave LAV colorspace options as default.
Clammerz is offline   Reply With Quote
Old 13th September 2018, 02:21   #52405  |  Link
Megalith
I can't figure out why the 3DLUTs I get from DisplayCAL all result in a very dark picture. Source profile BT.709, destination profile default 2.2 Gamma, so it should be pretty straightforward (no HDR). The picture is easier to see on the profile without VCGT applied, though I heard that option should be checked.
Megalith is offline   Reply With Quote
Old 13th September 2018, 03:40   #52406  |  Link
Asmodian
In an effort to be on topic could you post in Display Calibration?
Old 14th September 2018, 02:37   #52407  |  Link
YGPMOLE
@ Asmodian & Clammerz
Thank you for the explaination!!! I was totally wrong thinking that the first spacecolor conversion was done by the O.S. when MPC-BE is playing the original YCbCr videos, because with LAV in default mode I got YV12 8 Bit output: instead, YV12 is the codec used to read the YCbCr information. My bad (and ignorance).
Asmodian, AMD drivers say RGB 4:4:4 Full RGB pixel format.
Best Regards! Leo!
Old 14th September 2018, 17:10   #52408  |  Link
Asmodian
Of course they do.
What are you doing AMD?
Old 14th September 2018, 17:35   #52409  |  Link
what am i missing here?
what is AMD doing wrong here?
Old 14th September 2018, 17:45   #52410  |  Link
Klaus1189
Originally Posted by Asmodian View Post
Of course they do.
agree with huhn, what is wrong?
Driver displays RGB when you force LAV to output as RGB.
So what's the matter?
Old 14th September 2018, 18:07   #52411  |  Link
Asmodian
I am simply mildly annoyed that they call RGB "RGB 4:4:4", as if there could be something like "RGB 4:2:2". Describing the chroma sampling pattern for RGB formats makes no sense.
But nothing is wrong with the image, and it does have full resolution "chroma".
Old 14th September 2018, 18:10   #52412  |  Link
AMD always did this.
and yes you can subsample RGB it simply doesn't make any sense.
Old 14th September 2018, 18:49   #52413  |  Link
nevcairiel
Not with HDMI you can't.
Old 14th September 2018, 19:15   #52414  |  Link
Razoola
In relation to the new Nvidia RTX graphic cards and the video decoding they support I read the following for those intrsted (from guru3d)...
The video processor also has had a bit of an update and offers an improved video and hardware en/decoder. HEVC 8K30 HDR real-time sees 25% bitrate savings. H.264 up to 15% bitrate savings. Turing GPUs can drive two 8K displays at 60 Hz with one cable for each display. Turing’s new display engine supports HDR processing natively in the display pipeline. Tone mapping has also been added to the HDR pipeline. Tone mapping is a technique used to approximate the look of high dynamic range images on standard dynamic range displays. Turing supports the tone mapping formula defined by the ITU-R Recommendation BT.2100 standard to avoid color shift on different HDR displays. Turing GPUs also ship with an enhanced NVENC encoder unit that adds support for H.265 (HEVC) 8K encode at 30 fps. The new NVENC encoder provides up to 25% bitrate savings for HEVC and up to 15% bitrate savings for H.264. Turing’s new NVDEC decoder has also been updated to support decoding of HEVC YUV444 10/12b HDR at 30 fps, H.264 8K, and VP9 10/12b HDR.
Old 14th September 2018, 20:15   #52415  |  Link
why should anyone sane add this.
Old 15th September 2018, 01:52   #52416  |  Link
YGPMOLE
Hi guys!
I didn't want to start a flame, just understand and learn a little bit more from who knows really more than I do!
That's my situation now: after checking every option in LAV, the output is NV12 for SD and HD 8 Bit (MPeg2 DVDs, and H264 .mkv) and P010 for HEVC 10 Bit UHD; with the same settings of before, madVR produces dropped frames: I suppose because colorspace conversion and chroma upsampling are on his shoulder, and I have to re-optimize.
If I simply enable SVP to do frame rate conversion for SD and HD, LAV changes automatically his output to YV12: I suppose to "talk" with FFDshow input, am I right?
In this situation, FFDShow output at NV12: wouldn't be better to force his output at YV12 (to avoid the YV12 - > NV12 conversion), and let madVR do directly the YV12 - > RGB conversion?
Best Regards! Leo!
Old 15th September 2018, 02:18   #52417  |  Link
yes chroma scaling cost a little bit.
nv12 and yv12 are pretty much the same thing a conversation between them is very fast and lossless.
madVR can convert pretty much everything that lavfilter outputs directly to RGB.
Old 15th September 2018, 19:22   #52418  |  Link
kostik
Will the new GPUs output RGB 12/10bit@60Hz via HDMI? or is it still limited to RGB 8Bit@60Hz\12BIT@30Hz-23Hz since the HDMI connecter is the same 'old' HDMI 2.0b?
kostik is offline   Reply With Quote
Old 15th September 2018, 19:47   #52419  |  Link
on paper they have HDMI 2.0. so no.
but the fact they can send 8k 60hz means they may be able to patch it in.
Old 15th September 2018, 20:10   #52420  |  Link
el Filou
el Filou's Avatar
They can't claim they're HDMI 2.1 yet even if the hardware has been designed to be, because they have to wait for the official certification test spec: https://www.hdmi.org/manufacturer/hdmi_2_1/ (section 'Testing and Certification FAQs')
Samsung just announced a 8K TV but when asked if it had HDMI 2.1 inputs they said they had to wait for the certification to say anything:
https://www.cnet.com/reviews/samsung-85q900fn-preview/ (search page for HDMI 2.1)
So if you absolutely want 4K 60 Hz 10/12-bit RGB, the best is to specifically ask NVIDIA if the cards support that, but not ask them if the cards will be HDMI 2.1.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
