Old 24th August 2018, 22:05   #52181  |  Link
direxx
If you can't get this working, you can output from madVR at 10-bits Full and RGB 8-bit Full from the GPU and still get HDR passthrough. There is another conversion step (10-bits to 8-bits), but chroma upscaling is maintained.
Nice, this is working.
I always assumed that when I set my GPU to 8 bit I also need to set MadVR to 8 Bit, but with MadVR@10 Bit I get HDR passthrough - even though my GPU is set to RGB Full@8Bit. And the cool thing is that with anything below 30Hz MadVR/the GPU automatically switches to RGB@10Bit. Very nice.
direxx is offline   Reply With Quote
Old 24th August 2018, 22:33   #52182  |  Link
what ever madVR outputs is not the same to what the GPU outputs.
match bit deep is not wrong here and nvidia will gladly send 8 bit HDR.
Old 25th August 2018, 07:03   #52183  |  Link
foobar2000
folks, I have a question, usually our monitors are set to 60hz, while watching 24fps movies, does madvr convert to 60fps since our monitors is 60hz? (monitor faster than the content)
what if, if someone uses Intel's built-in video output, which only supports 4k/24fps through HDMI 1.4, and he's watching 4k 24fps videos, does he get smooth motion, all in all the monitor itself supports 60hz but Intel makes his display stick for 24hz right now (monitor faster than the content, but monitor set to the same fps like the content does)
foobar2000 is offline   Reply With Quote
Old 25th August 2018, 07:57   #52184  |  Link
madVR does not convert to 60 HZ does not always produce a perfect 3:2 judder since his last statement. that's why madVR has smoothmotion to convert it to "60hz" well ~48 hz but what ever to simulate an output that looks like true 24 HZ.
if you are using an HDMI 1.4 limited GPU and you try to use it on a UHD screen that does not support 24 HZ it will not be able to send a signal and will just stay blank.
Old 25th August 2018, 19:49   #52185  |  Link
mv
Guys, what possibly could cause presentation glitches (both in statistics and visible by eye) in Full Screen Windowed mode once in a minute or two?
FSE with same settings (upscale and processing) works without issues. Tried changing almost all madVR settings (including processing, upscale, render queue length, DXVA), changed Nvidia driver version but glitches are still there and only in FS Windowed mode.
mv is offline   Reply With Quote
Old 25th August 2018, 21:12   #52186  |  Link
Asmodian
Windows 10 has a new "Focus Assist" feature that needs to be completely disabled. Also f.lux causes presentation glitches.
madVR options explained
Old 26th August 2018, 11:12   #52187  |  Link
el Filou
el Filou's Avatar
Basically any other application that uses the GPU can cause presentation glitches.
You can use Windows' performance monitor tool perfmon.exe to try and look for what is hogging the GPU at regular intervals.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 26th August 2018, 20:52   #52188  |  Link
XMonarchY
I hope madshi is spending some time on those Photoshop plugins. I can already imagine how awesome it would be to have a de-noise tool that does not leave any or much ringing around objects...
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809
XMonarchY is offline   Reply With Quote
Old 26th August 2018, 22:55   #52189  |  Link
mv
Thanks for hints guys!
I've sorted out that remote control software was causing those glitches (even in standby mode with no connected clients). After switching to another software glitches are gone. Thanks again!
BTW
Some time ago I was asking about madvr playback freezes with unstable IPTV UDP streams by my local internet provider. I was able to avoid them by enabling UDP proxy on my router and forming new playlist with http streams instead of UDP. First few seconds of playback are still a painful spectacle with artefacts and glitches but at least it doestn't freeze now.
Old 27th August 2018, 16:57   #52190  |  Link
Klaus1189
BTW
What is the name of the remote control software that caused glitches? Which one is the new software you use now that doesn't cause glitches?
Old 28th August 2018, 11:29   #52191  |  Link
BluesFanUK
Originally Posted by waldnebel View Post
madVR always puts a big smile onto my face. It's unbelievable nice what NGU (very sharp) can do to relative clean 1080p recordings upscaled to a 2160p screen. It's time to say thank you to madshi for such a nice video renderer. It looks like madshi is also the king of optimization. My 1080 GTX can do NGU doubling to 4k res in combination with edge sharpening, detail enhancement and error diffusion dithering in around 28 ms. That's enough for every 23 or 24 fps movie and even for 29 fps videos.
What is not working for me is the custom resolution functionality on Windows 10 1803.
Yeh, my 980ti can just about manage NGU High, it sounds like a aircraft though after a few mins though....
BluesFanUK is offline   Reply With Quote
Old 28th August 2018, 11:37   #52192  |  Link
mv
I was using LiteManager and switched to RAdmin for now.
Old 29th August 2018, 10:56   #52193  |  Link
mclingo
Originally Posted by BluesFanUK View Post
Yeh, my 980ti... sounds like a aircraft though after a few mins though....
noise is the biggest problem for me now with MADVR, its so bad on my RX 580 i've had to move back down to NGU Low from HIGH, have been getting high with sub 20ms rendering which is pretty good for polaris.
Thought about watercooling my card but to expensive and too much of a faff.
I've done as much soundproofing as I can, you can only go so far before you ambient temps get too high, my PC is now idling about 45 degrees which isnt great.
My previous card, RX 460 used to be very loud and could barely manage NGU LOW though so upgrading to the RX 580 was still a good buy for me as I can get NGU LOW on 40% GPU fan which is pretty much silent.
Old 29th August 2018, 12:13   #52194  |  Link
you should check benchmark to see how a card is performing in term of temps and noise.
i can't remember a card i brought that was even remotely loud.
if it was the r9 270, 760, rx 480 or my 1060 "all" where properly cooled and never good loud at all temp and not problems too.
and i don't even use a case fan...
there is no way other none reverence cooled mid range cards are that bad. try a custom fan curve and don't forget 80 degree is save for a modern GPU. or even lower the power target, under volt and/or under clock the cards.
Old 29th August 2018, 12:25   #52195  |  Link
Siso
Siso's Avatar
Regarding chroma upscaling is this true? I saw it in a guide:
"The sharpness of the algorithm used in chroma upscaling section should not exceed the sharpness of the algorithm used in the image upscaling section. It could be the same, but not exceed it."
Old 29th August 2018, 12:32   #52196  |  Link
nevcairiel
Its basically pointless to use a sharper chroma scaler then Luma. If you have processing power to spare, use a better Luma scaler instead.
Old 29th August 2018, 12:39   #52197  |  Link
Siso
Siso's Avatar
Thank you for the info. In my case I can't use anything higher than Jinc for luma upscaling.
Old 29th August 2018, 12:42   #52198  |  Link
while i totally agree that you should not use processing intensive scaler on chroma if you have to scale luma. but i disagree on the sharpness.
i personally use super XBR 125-150 on chroma and super XBR 100 on image scaling.
Old 29th August 2018, 12:44   #52199  |  Link
Siso
Siso's Avatar
I guess you use image doubling, right? I'm on 2560x1080p monitor watching 1080p movies, and I see no point in using image doubling, image upscaling imho is enough.
Old 29th August 2018, 13:00   #52200  |  Link
even on a 1440p screen doubling can be cheaper.
ngu AA low and super xbr maybe cheaper and may give you better results.
but yes i'm doubling and without doubling i personally pref super xbr 100 for chroma.
