24th May 2010, 19:54 | #8301 | Link |
I've been getting a lot of these lately, not just with this movie but it already happened with Couples Retreat, Red Cliff, etc. Seems to be the same error where if fails to re-encode extras, trailers or menu items. I've gotten passed this problem by replacing those files with clips from other movies so it's definitely an issue with certain files that BR doesn't like. Vid_141 happens to be the same clip that failed in Couples Retreat, its a black screen 5 second video that says "Universal Studios, all rights reserved" at the bottom. I wonder if just deleting those will cause a problem with "Full Back-up" Is there a way to blank it instead?
PS. When I right-click Vid_141 and select "Preview this Item" I get an error that says: "Resize: Source image too small for this resize method (Q:\MPC_View.AVS, Line 3)". I wonder if that has anything to do with the re-encoding problem, Vid_151 re-encoded fine and I was able to preview it... hmm. [14:40:49] BD Rebuilder v0.33.09 (beta) - Source: ING_BASTERDS - Input BD size: 44.51 GB - Approximate total content: [04:04:27.419] - Target BD size: 23.78 GB - Windows Version: 6.0 [6002] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [14:40:49] PHASE ONE, Encoding - [14:40:49] Extracting A/V streams [VID_00151] - [14:40:50] Reencoding: VID_00151 (1 of 18) - [14:40:50] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 151 frames - [14:40:50] Reencoding: VID_00151, Pass 1 of 1 - [14:40:53] Video Encode complete - [14:40:53] Reencoding audio tracks (if req'd) - [14:40:54] Multiplexing M2TS - [14:40:54] Extracting A/V streams [VID_00141] - [14:40:55] Reencoding: VID_00141 (2 of 18) - [14:40:55] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 121 frames - [14:40:55] Reencoding: VID_00141, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.09 (beta) - Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.7.0, Ok [14:41:28] - Failed video encode, aborted Last edited by JohnnyB.Good; 24th May 2010 at 20:04. |
24th May 2010, 21:04 | #8302 | Link |
My Best Friend's Girl
Any1 have success with (My Best Friend's Girl) title02 101 min. version
UPC Code: 031398104216 No problem with Clown_BD(movie-only) note: produced french AC3 track size is (472 833 ko) (& by BD Rebuilder = 472 870 ko) No problem with DVDFab(movie-only) but stay a multi-m2ts Same problem with AVCHDCoder(movie-only) out of sync Same problem with MakeMKV(movie-only) out of sync prob. #1 less than 20GB & BD rebuilder re-encode anyway !!! "not keeping video" prob. #2 audio on french track out of sync late in the movie !!! (just for testing audio prob.) When i try to demux this title with tsmuxer i get error's message style (AC3 stream (track 2): overlapped frame detected at position 00:00:22,047. Remove frame.) & many other place "if may help" update: tested demux ac3 5.1 french with eac3to used by Clown_BD & overwrite ac3 file in working dir of BD Rebuilder before remux & all is ok (SYNC perfectly). I joint txmuxer log & eac3to log In tsmuxer log we can see (REMOVE FRAME) may be this is the answer ? BTW BD Rebuilder finish process normally with v3304 v3305 v3309 & inspect is OK too all my setup is OK after duplicate 73 BD,s with no prob. any idea ? THANKS jdobbs for your excellent pmg. p.s. sorry for my very very very bad English Last edited by Elvis Gratton; 25th May 2010 at 20:53. |
25th May 2010, 00:03 | #8303 | Link |
JohnnyB.Good, I've never had a problems with BDRebuilder yet except for out of sync audio on deleted scenes from the air I breathe. I did couples retreat full backup to BD25 without any problems and I always watch my backup (I have an oppo BDP-83) before I delete it off the computer to make sure that it's ok since this is beta software. I've done ~50 full backups and have yet to have a problem. The only time that I have a problem is from a bad rip. I just did Daybreakers and couldn't wait to watch it. Well 3 mins into the movie I get a lot of static and breakups in the audio and then the audio goes waaayyy out of sync. I played back my rip and it did the same thing. I had a bad rip and have to do the process all over again. I'm a little mad because it took 13 hours to encode plus I wasted a disc but it wasn't BDRebuilders fault.
Long story short, you have a bad rip! What I don't get is that I've never had a bad rip from a DVD?!?!? Then again I use an old Plextor PX-716sa for my dvd rips and burns so that might have something to do with it. |
25th May 2010, 00:30 | #8304 | Link | |
Ripped 4 time 2 w DVDFab & 2 w AnyDVD & the result is the same. note: The copy made with DVDFab & Clown_BD work very well. Last edited by Elvis Gratton; 25th May 2010 at 00:42. |
25th May 2010, 01:28 | #8305 | Link |
Then the only thing that I can say is that may you have a bad disc. I recently had a very bad problem with Big Trouble In little China. It took me 3 discs before I got one that worked. All I'm saying is that I backed up couples retreats without any problem. That was a few BDRebuilder versions ago as well.
So far I've only had two problems with discs. Big Trouble In Little China and Daybreakers. |
25th May 2010, 01:53 | #8306 | Link |
Jdobbs, I have an error detecting request.
I just fully backed up Daybreakers (took me 13 hours) without any problems but there was indeed a problem. Daybreakers didn't rip correctly onto my hard drive and has several problems. I'm messing around with clown_BD which found the problems right away during demuxing. Could you incorporate some sort of error detection that would prompt the user that it found an error and ask if you would like to continue? I think adding something like that in the setup to enable/disable it would be ideal for people that would like to use it for a reference. To me there's nothing worse than wasting all the encoding time and the blank discs to then sit down to watch the movie and find out that there's an error in the ripping and that you have to do it all over again. If we could find out that there's a problem from the start it would save us a lot of time and money. Here's my clown_BD log as a reference. Sorry I didn't know how to properly insert the log file like everyone else. Last edited by Audiophile1178; 25th May 2010 at 02:55. |
25th May 2010, 02:02 | #8307 | Link |
@Elvis Gratton,
If you want me to try and help you -- it would be more helpful if you didn't post logs that are unrelated to BD-RB, as they really don't give me the information I need. EAC3TO isn't even involved in a BD-RB encode. How about posting the BD-RB log and INF instead? It also doesn't help to say other programs work either (like Clown BD or MakeMKV)... they are completely unrelated and don't do anything even remotely similar to BD-RB. The "source image too small" means that BD-RB is being fed garbage -- and that's why it is failing. My guess would be (without any info to help me) that you might have a "Codec Pack" or some other package that is attempting to decode instead of FFDSHOW -- and it isn't doing a very good job. Last edited by jdobbs; 25th May 2010 at 02:09. |
25th May 2010, 09:01 | #8308 | Link |
Wrong size - BUDDENBROOKS
The iso is 14.2 GB instead of 7.72 GB. Region B
[16:48:58] BD Rebuilder v0.33.09 (beta) - Source: BUDDENBROOKS - Input BD size: 26,00 GB - Approximate total content: [02:25:16.680] - Target BD size: 7,72 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [16:49:03] PHASE ONE, Encoding - [16:49:03] Extracting A/V streams [VID_00005] - [17:00:15] Reencoding: VID_00005 (1 of 1) - [17:00:15] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 217*917 frames - Convert: 1280x720, 50,000fps, 435*834 frames - Bitrate: 6*308 Kbs - [17:00:15] Reencoding: VID_00005, Pass 1 of 2 - [18:52:34] Reencoding: VID_00005, Pass 2 of 2 - [23:42:56] Video Encode complete - [23:42:56] Reencoding audio tracks (if req'd) - [23:47:43] Multiplexing M2TS [23:54:41]PHASE ONE complete [23:54:41]PHASE TWO - Rebuild Started - [23:54:41] Rebuilding AVCHD file Structure [00:04:01] - Encode and Rebuild complete [00:04:02] Writing BD structure to ISO file - ImgBurn completed successfully [00:15:15]JOB: BUDDENBROOKS finished. - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.33.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [Options] MODE=1 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 QUICK_EXTRAS=0 TARGET_SIZE=7910 AUTO_BURN=2 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=1 DEINTERLACE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 FULL_AVCHD=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=D:\xxxxxxxxxxxxxxxxxxxxxxxxxxxxx\BUDDENBROOKS\ WORKING_PATH=C:\WINDOWS\TEMP\ |
25th May 2010, 09:36 | #8309 | Link | |
- Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set "disabled", WMP11, Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.33.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok ----------------------- [21:27:40] BD Rebuilder v0.33.09 (beta) - Source: MYBESTFRIENDSGIRL - Input BD size: 24,06 GB - Approximate total content: [01:40:52.254] - Target BD size: 22,66 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), One Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:27:40] PHASE ONE, Encoding - [21:27:40] Extracting A/V streams [VID_00001] - [21:42:23] Reencoding: VID_00001 (1 of 25) - [21:42:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 528 frames - Bitrate: 26*714 Kbs - [21:42:23] Reencoding: VID_00001, Pass 1 of 1 - [21:42:40] Video Encode complete - [21:42:40] Reencoding audio tracks (if req'd) - [21:42:40] Multiplexing M2TS - [21:42:41] Extracting A/V streams [VID_00026] - [21:43:13] Reencoding: VID_00026 (2 of 25) - [21:43:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5*982 frames - Bitrate: 24*200 Kbs - [21:43:13] Reencoding: VID_00026, Pass 1 of 1 - [21:46:13] Video Encode complete - [21:46:13] Multiplexing M2TS - [21:46:18] Extracting A/V streams [VID_00003] - [21:47:20] Reencoding: VID_00003 (3 of 25) - [21:47:20] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9*295 frames - Bitrate: 30*000 Kbs - [21:47:20] Reencoding: VID_00003, Pass 1 of 1 - [21:52:42] Video Encode complete - [21:52:43] Multiplexing M2TS - [21:52:59] Extracting A/V streams [VID_00027] - [21:53:08] Reencoding: VID_00027 (4 of 25) - [21:53:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*441 frames - Bitrate: 28*732 Kbs - [21:53:08] Reencoding: VID_00027, Pass 1 of 1 - [21:53:57] Video Encode complete - [21:53:57] Multiplexing M2TS - [21:53:59] Extracting A/V streams [VID_00028] - [21:54:19] Reencoding: VID_00028 (5 of 25) - [21:54:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*407 frames - Bitrate: 30*000 Kbs - [21:54:19] Reencoding: VID_00028, Pass 1 of 1 - [21:55:59] Video Encode complete - [21:55:59] Multiplexing M2TS - [21:56:02] Extracting A/V streams [VID_00006] - [21:56:23] Reencoding: VID_00006 (6 of 25) - [21:56:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3*001 frames - Bitrate: 30*000 Kbs - [21:56:23] Reencoding: VID_00006, Pass 1 of 1 - [21:58:11] Video Encode complete - [21:58:11] Multiplexing M2TS - [21:58:14] Extracting A/V streams [VID_00029] - [21:58:25] Reencoding: VID_00029 (7 of 25) - [21:58:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*113 frames - Bitrate: 22*481 Kbs - [21:58:25] Reencoding: VID_00029, Pass 1 of 1 - [21:59:27] Video Encode complete - [21:59:27] Multiplexing M2TS - [21:59:29] Extracting A/V streams [VID_00008] - [22:00:03] Reencoding: VID_00008 (8 of 25) - [22:00:03] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4*762 frames - Bitrate: 30*000 Kbs - [22:00:03] Reencoding: VID_00008, Pass 1 of 1 - [22:02:55] Video Encode complete - [22:02:55] Multiplexing M2TS - [22:03:00] Extracting A/V streams [VID_00030] - [22:03:02] Reencoding: VID_00030 (9 of 25) - [22:03:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 219 frames - Bitrate: 30*000 Kbs - [22:03:02] Reencoding: VID_00030, Pass 1 of 1 - [22:03:11] Video Encode complete - [22:03:11] Multiplexing M2TS - [22:03:12] Extracting A/V streams [VID_00010] - [22:04:31] Reencoding: VID_00010 (10 of 25) - [22:04:31] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 11*070 frames - Bitrate: 30*000 Kbs - [22:04:31] Reencoding: VID_00010, Pass 1 of 1 - [22:11:06] Video Encode complete - [22:11:06] Multiplexing M2TS - [22:11:26] Extracting A/V streams [VID_00031] - [22:11:35] Reencoding: VID_00031 (11 of 25) - [22:11:35] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*004 frames - Bitrate: 20*790 Kbs - [22:11:35] Reencoding: VID_00031, Pass 1 of 1 - [22:12:32] Video Encode complete - [22:12:32] Multiplexing M2TS - [22:12:34] Extracting A/V streams [VID_00012] - [22:13:49] Reencoding: VID_00012 (12 of 25) - [22:13:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 10*897 frames - Bitrate: 30*000 Kbs - [22:13:49] Reencoding: VID_00012, Pass 1 of 1 - [22:20:25] Video Encode complete - [22:20:25] Multiplexing M2TS - [22:21:14] Extracting A/V streams [VID_00032] - [22:21:18] Reencoding: VID_00032 (13 of 25) - [22:21:18] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 718 frames - Bitrate: 22*964 Kbs - [22:21:18] Reencoding: VID_00032, Pass 1 of 1 - [22:21:41] Video Encode complete - [22:21:41] Multiplexing M2TS - [22:21:42] Extracting A/V streams [VID_00014] - [22:22:42] Reencoding: VID_00014 (14 of 25) - [22:22:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8*909 frames - Bitrate: 30*000 Kbs - [22:22:42] Reencoding: VID_00014, Pass 1 of 1 - [22:28:00] Video Encode complete - [22:28:00] Multiplexing M2TS - [22:28:14] Extracting A/V streams [VID_00033] - [22:28:33] Reencoding: VID_00033 (15 of 25) - [22:28:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*817 frames - Bitrate: 30*000 Kbs - [22:28:33] Reencoding: VID_00033, Pass 1 of 1 - [22:30:13] Video Encode complete - [22:30:13] Multiplexing M2TS - [22:30:17] Extracting A/V streams [VID_00016] - [22:31:19] Reencoding: VID_00016 (16 of 25) - [22:31:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9*359 frames - Bitrate: 29*993 Kbs - [22:31:19] Reencoding: VID_00016, Pass 1 of 1 - [22:36:57] Video Encode complete - [22:36:57] Multiplexing M2TS - [22:37:14] Extracting A/V streams [VID_00034] - [22:37:49] Reencoding: VID_00034 (17 of 25) - [22:37:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6*154 frames - Bitrate: 26*374 Kbs - [22:37:49] Reencoding: VID_00034, Pass 1 of 1 - [22:41:05] Video Encode complete - [22:41:05] Multiplexing M2TS - [22:41:10] Extracting A/V streams [VID_00035] - [22:41:36] Reencoding: VID_00035 (18 of 25) - [22:41:36] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3*418 frames - Bitrate: 30*000 Kbs - [22:41:36] Reencoding: VID_00035, Pass 1 of 1 - [22:43:46] Video Encode complete - [22:43:46] Multiplexing M2TS - [22:43:50] Extracting A/V streams [VID_00019] - [22:45:13] Reencoding: VID_00019 (19 of 25) - [22:45:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 12*298 frames - Bitrate: 30*000 Kbs - [22:45:13] Reencoding: VID_00019, Pass 1 of 1 - [22:52:15] Video Encode complete - [22:52:15] Multiplexing M2TS - [22:52:39] Extracting A/V streams [VID_00036] - [22:52:41] Reencoding: VID_00036 (20 of 25) - [22:52:41] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 219 frames - Bitrate: 25*086 Kbs - [22:52:41] Reencoding: VID_00036, Pass 1 of 1 - [22:52:48] Video Encode complete - [22:52:48] Multiplexing M2TS - [22:52:49] Extracting A/V streams [VID_00037] - [22:53:04] Reencoding: VID_00037 (21 of 25) - [22:53:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*130 frames - Bitrate: 30*000 Kbs - [22:53:04] Reencoding: VID_00037, Pass 1 of 1 - [22:54:22] Video Encode complete - [22:54:22] Multiplexing M2TS - [22:54:25] Extracting A/V streams [VID_00022] - [22:55:10] Reencoding: VID_00022 (22 of 25) - [22:55:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 7*795 frames - Bitrate: 26*465 Kbs - [22:55:10] Reencoding: VID_00022, Pass 1 of 1 - [22:59:21] Video Encode complete - [22:59:21] Multiplexing M2TS - [22:59:29] Extracting A/V streams [VID_00038] - [23:00:28] Reencoding: VID_00038 (23 of 25) - [23:00:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8*748 frames - Bitrate: 30*000 Kbs - [23:00:28] Reencoding: VID_00038, Pass 1 of 1 - [23:05:39] Video Encode complete - [23:05:39] Multiplexing M2TS - [23:05:52] Extracting A/V streams [VID_00039] - [23:06:13] Reencoding: VID_00039 (24 of 25) - [23:06:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*910 frames - Bitrate: 30*000 Kbs - [23:06:13] Reencoding: VID_00039, Pass 1 of 1 - [23:08:01] Video Encode complete - [23:08:01] Multiplexing M2TS - [23:08:05] Extracting A/V streams [VID_00025] - [23:10:27] Reencoding: VID_00025 (25 of 25) - [23:10:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 25*915 frames - Bitrate: 25*055 Kbs - [23:10:27] Reencoding: VID_00025, Pass 1 of 1 - [23:22:50] Video Encode complete - [23:22:50] Multiplexing M2TS [23:23:43]PHASE ONE complete [23:23:43]PHASE TWO - Rebuild Started - [23:23:43] Rebuilding BD file Structure [23:30:51] - Encode and Rebuild complete [23:30:51]JOB: MYBESTFRIENDSGIRL finished. [Status] LABEL=MYBESTFRIENDSGIRL VERSION=v0.33.09 (beta) SOURCE_SIZE=25830082560 SOURCE_VIDEO_SIZE=25830082560 TARGET_SIZE=24326963200 REDUCTION=.941807411706546 RESIZE_1080=0 AUDIO_TO_KEEP=eng;fra;fre; SUBS_TO_KEEP=eng;fra;fre; BACKUP_MODE=1 MOVIEONLY_TYPE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=25 REBUILD_COMPLETE=1 [00001] AUDIO=1111 PGS=110 M2TS_TARGET=81236178 RATE=26714 NSIZE=73052160 FLINK=-1 MLINK=0 [00026] M2TS_TARGET=833731199 RATE=24200 AUDIO=1111 NSIZE=798793728 FLINK=-1 MLINK=0 [00003] M2TS_TARGET=1626476868 RATE=30000 AUDIO=1111 NSIZE=1522937856 FLINK=-1 MLINK=0 [00027] M2TS_TARGET=238448639 RATE=28732 AUDIO=1111 NSIZE=227401728 FLINK=-1 MLINK=0 [00028] M2TS_TARGET=527424688 RATE=30000 AUDIO=1111 NSIZE=397295616 FLINK=-1 MLINK=0 [00006] M2TS_TARGET=523154277 RATE=30000 AUDIO=1111 NSIZE=491649024 FLINK=-1 MLINK=0 [00029] M2TS_TARGET=273584053 RATE=22481 AUDIO=1111 NSIZE=258490368 FLINK=-1 MLINK=0 [00008] M2TS_TARGET=877123898 RATE=30000 AUDIO=1111 NSIZE=779298816 FLINK=-1 MLINK=0 [00030] M2TS_TARGET=39110715 RATE=30000 AUDIO=1111 NSIZE=37570560 FLINK=-1 MLINK=0 [00010] M2TS_TARGET=2078665941 RATE=30000 AUDIO=1111 NSIZE=1813364736 FLINK=-1 MLINK=0 [00031] M2TS_TARGET=239947333 RATE=20790 AUDIO=1111 NSIZE=227026944 FLINK=-1 MLINK=0 [00012] M2TS_TARGET=1962010812 RATE=30000 AUDIO=1111 NSIZE=1785090048 FLINK=-1 MLINK=0 [00032] M2TS_TARGET=94961673 RATE=22964 AUDIO=1111 NSIZE=88080384 FLINK=-1 MLINK=0 [00014] M2TS_TARGET=1572413928 RATE=30000 AUDIO=1111 NSIZE=1459617792 FLINK=-1 MLINK=0 [00033] M2TS_TARGET=496496034 RATE=30000 AUDIO=1111 NSIZE=460474368 FLINK=-1 MLINK=0 [00016] M2TS_TARGET=1616686169 RATE=29993 AUDIO=1111 NSIZE=1531398144 FLINK=-1 MLINK=0 [00034] M2TS_TARGET=934757087 RATE=26374 AUDIO=1111 NSIZE=887697408 FLINK=-1 MLINK=0 [00035] M2TS_TARGET=673087365 RATE=30000 AUDIO=1111 NSIZE=559288320 FLINK=-1 MLINK=0 [00019] M2TS_TARGET=2187237379 RATE=30000 AUDIO=1111 NSIZE=2013419520 FLINK=-1 MLINK=0 [00036] M2TS_TARGET=31640389 RATE=25086 AUDIO=1111 NSIZE=30111744 FLINK=-1 MLINK=0 [00037] M2TS_TARGET=382444814 RATE=30000 AUDIO=1111 NSIZE=350767104 FLINK=-1 MLINK=0 [00022] M2TS_TARGET=1188134805 RATE=26465 AUDIO=1111 NSIZE=1124278272 FLINK=-1 MLINK=0 [00038] M2TS_TARGET=1551952988 RATE=30000 AUDIO=1111 NSIZE=1432915968 FLINK=-1 MLINK=0 [00039] M2TS_TARGET=556738918 RATE=30000 AUDIO=1111 NSIZE=476448768 FLINK=-1 MLINK=0 [00025] M2TS_TARGET=3739497050 RATE=25055 AUDIO=0100 NSIZE=3485239296 FLINK=0 MLINK=0 [Options] MODE=1 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 QUICK_EXTRAS=0 TARGET_SIZE=23200 AUDIO_TO_KEEP=eng;fra;fre; SUBS_TO_KEEP=eng;fra;fre; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 FULL_AVCHD=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 [Paths] WORKING_PATH=D:\WORKING\ SOURCE_PATH=J:\ Tanks
DVD Rebuilder user Last edited by jdobbs; 25th May 2010 at 14:32. |
25th May 2010, 13:45 | #8310 | Link |
why i can't encode File VC-1
D Rebuilder v0.33.07 (beta) - Source: THE_ISLAND_2005_1080P_BLU-RAY_CEE_VC-1_DD_5.1_-_EIMI - Input BD size: 23.84 GB - Approximate total content: [02:37:39.074] - Target BD size: 2.34 GB - Windows Version: 6.1 [7600] - Auto Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=448 [19:41:20] PHASE ONE, Encoding - [19:41:20] Extracting A/V streams [VID_00003] - [19:41:22] Reencoding: VID_00003 (1 of 5) - [19:41:22] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 286 frames - [19:41:22] Reencoding: VID_00003, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.07 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Isn't recommended version - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [19:41:24] - Failed video encode, aborted How i can fix this thank you |
25th May 2010, 14:43 | #8312 | Link | ||
25th May 2010, 14:53 | #8313 | Link |
@Elvis Gratton
That one is a multi-part encode. Since the sections are extracted one-at-a-time there is lots of chance for missing the chance to "extract" rather than encode. Also, they would have to all be small enough to fit (you can't just encode one section, or the quality would not be consistent). I'll look at it and see if I can come up with a better way to project size on muli-part sources. As for the sync problem -- I think that was probably fixed with v0.33.09. It turns out that using the internal FFMS in X264 for frame-serving on multi-part sources wasn't as great an idea as I originally thought -- but encoding from the demuxed source rather than the original M2TS seems to have fixed it. Last edited by jdobbs; 25th May 2010 at 14:58. |
25th May 2010, 18:06 | #8315 | Link |
Did an alternate output run last night with 03307, not knowing there was a new version out. Source was a playlist of a 90-minute documentary, encoded with MPEG-2 and it has a resolution of 720x480@29.97fps. Inspect reports OK for everything. I had ticked "Resize 1080p to 720p enabled", but "Convert SD to HD (720p)" was not enabled.
Two things went wrong: 1) 720x480 got upconverted to 1280x720, even though "Convert SD to HD (720p)" was disabled. 2) The resulting .mkv looks... odd. Here's a screencap from MPC-HC: http://yfrog.com/1gsnap194640j As you can see, there's a wide green bar at the top of the image and colour (look at the faces and hands) is misplaced. update: Image looks fine in VLC, but not in Windows Media Player. I suspect this has something to do with FFDShow. update: It was caused by DXVA. Once I disabled DXVA support in FFDShow, the image cleared right up. D'oh. Odd how an episode of a TV show I viewed earlier today on MPC-HC looked fine with DXVA enabled. Hmmh. Last edited by colinhunt; 25th May 2010 at 18:23. |
25th May 2010, 19:28 | #8316 | Link | ||
Yeah, I did notice that there were only two MKV output options, 1080p and 720p, but I sorta kinda thought it would use original resolution if that was lower than 720p and the "Convert SD to HD" was not enabled. Felt logical, you know? Last edited by colinhunt; 25th May 2010 at 19:35. |
25th May 2010, 19:35 | #8317 | Link | |
The flags in the SETUP dialog would contradict the purpose of the ALTERNATE output... for example, if I paid attention to the resizing instructions I could end up eith iPod output that wouldn't play on an iPod. |
25th May 2010, 20:45 | #8320 | Link | |
update: MYBESTFRIENDSGIRL
After doing some other test ie: edit MUX_MOVIEONLY.meta file to replace tsmuxer_track.ac3 with eac3to_track.ac3 & set the custom size to 40GB to eliminate reencode & speedup, + remux (audio sync was perfect). jdobbs Can you tel me, in this expression: AC3 stream (track 1): overlapped frame detected at position 00:00:22,047. Remove frame. what wants to say: (Remove frame) it is an information or an action ? maybe these cause of my troubles if audio frame are missing ! i'm not an expert of tsmuxer ... Again, sorry for my bad English. thank you for answering
DVD Rebuilder user Last edited by Elvis Gratton; 25th May 2010 at 21:13. |
