18th December 2008, 22:03 | #7403 | Link |
Can somebody send me sample (.m2ts or .evo) with audio overlaps? Unfortunately all my blu-rays are clean.
18th December 2008, 22:52 | #7405 | Link | |
eac3to v2.82 command line: eac3to k:\unrar\movie 1) 2: c:\bd\movie.mkv 4: c:\bd\movie.flac ------------------------------------------------------------------------------ M2TS, 2 video tracks, 4 audio tracks, 3 subtitle tracks, 2:55:45 1: Chapters, 21 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: VC-1, 480p24 /1.001 (3:2) 4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 5: DTS, French, 5.1 channels, 24 bits, 768kbps, 48khz 6: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 7: DTS Express, English, 2.0 channels, 24 bits, 192kbps, 48khz 8: Subtitle (PGS), English 9: Subtitle (PGS), Spanish 10: Subtitle (PGS), French [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [a04] Decoding with ArcSoft DTS Decoder... [a04] Encoding FLAC with libFlac... [v02] Muxing video to Matroska... [a04] Creating file "c:\bd\movie.flac"... [a04] The last DTS frame is incomplete and thus gets skipped. [a04] The original audio track has a constant bit depth of 24 bits. [a04] Audio overlaps for 10ms at playtime 0:21:43. [a04] Audio overlaps for 10ms at playtime 0:45:09. [a04] Audio overlaps for 9ms at playtime 0:46:59. [a04] Audio overlaps for 12ms at playtime 0:55:06. [a04] Audio overlaps for 9ms at playtime 1:00:39. [a04] Audio overlaps for 9ms at playtime 1:02:56. [a04] Audio overlaps for 6ms at playtime 1:03:40. [a04] Audio overlaps for 6ms at playtime 1:08:03. [a04] Audio overlaps for 8ms at playtime 1:09:37. [a04] Audio overlaps for 9ms at playtime 1:12:00. [a04] Audio overlaps for 10ms at playtime 1:14:02. [a04] Audio overlaps for 8ms at playtime 1:16:25. [a04] Audio overlaps for 13ms at playtime 1:41:02. [a04] Audio overlaps for 7ms at playtime 1:45:20. [a04] Audio overlaps for 6ms at playtime 1:47:45. [a04] Audio overlaps for 9ms at playtime 1:52:03. [a04] Audio overlaps for 7ms at playtime 1:59:16. [a04] Audio overlaps for 6ms at playtime 2:01:06. [a04] Audio overlaps for 9ms at playtime 2:44:49. [a04] Audio overlaps for 45ms at playtime 2:48:33. [a04] Source file joining currently doesn't work for FLAC files. |
18th December 2008, 23:18 | #7407 | Link |
eac3to v2.83 released
http://madshi.net/eac3to.zip Code:
* fixed: gap/overlap correction didn't work for FLAC and WAV files * fixed: when clipping was detected, 2nd pass was not always executed correctly |
18th December 2008, 23:23 | #7408 | Link | |
I'll give it a shot on the next seamless branch. I fixed the other one with v2.69. Last edited by Killroy™; 18th December 2008 at 23:38. |
19th December 2008, 02:43 | #7411 | Link | |
I just wanted to say there are no appearent changes between them as .81 was already making gaps/overlaps correction on transcoding flac. The question; what is beyond this? |
19th December 2008, 10:41 | #7416 | Link |
Depends on how many m2ts parts the movie consists of. If there are only 2 or 3 parts, then maybe the gap amount is too small to be of concern for eac3to. If there are more than 2-3 parts and there are still no gaps reported then that might be worth worrying about...
19th December 2008, 10:49 | #7417 | Link |
Madshi the movie consits of over 10 M2TS files
The Log: eac3to v2.82 command line: "F:\xxxxxxxxxxxxx\EAC3to\eac3to\eac3to.exe" "G:\xxxx\" 1) 2: "G:\xxxx\video.mkv" 4: "G:\xxxx\audio.pcm" ------------------------------------------------------------------------------ M2TS, 2 video tracks, 6 audio tracks, 19 subtitle tracks, 1:42:14 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: h264/AVC, 480p24 /1.001 (20:11) 4: TrueHD/AC3, English, 5.1 channels, 48khz (embedded: AC3, 5.1 channels, 448kbps, 48khz) 5: AC3, English, 5.1 channels, 448kbps, 48khz, dialnorm: -30dB 6: TrueHD/AC3, German, 5.1 channels, 48khz (embedded: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -29dB) 7: AC3, Russian, 5.1 channels, 448kbps, 48khz, dialnorm: -29dB 8: AC3, Ukrainian, 5.1 channels, 448kbps, 48khz, dialnorm: -29dB 9: DTS Express, English, 2.0 channels, 24 bits, 192kbps, 48khz 10: Subtitle (PGS), English 11: Subtitle (PGS), English 12: Subtitle (PGS), German 13: Subtitle (PGS), Dutch 14: Subtitle (PGS), Danish 15: Subtitle (PGS), Estonian 16: Subtitle (PGS), Finnish 17: Subtitle (PGS), Modern Greek 18: Subtitle (PGS), Hindi 19: Subtitle (PGS), Lithuanian 20: Subtitle (PGS), Norwegian 21: Subtitle (PGS), Swedish 22: Subtitle (PGS), Turkish 23: Subtitle (PGS), English 24: Subtitle (PGS), German 25: Subtitle (PGS), Dutch 26: Subtitle (PGS), Russian 27: Subtitle (PGS), Ukrainian 28: Subtitle (PGS), English [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [v02] Muxing video to Matroska... [a04] Decoding with libav/ffmpeg... [a04] Swapping endian... [a04] Remapping channels... [a04] Creating file "G:\xxxx\audio.pcm"... [a04] The original audio track has a constant bit depth of 16 bits. Added fps value to MKV header. Video track 2 contains 147076 frames. Video track 3 contains 147076 frames. eac3to processing took 35 minutes, 53 seconds. Done. |
19th December 2008, 11:15 | #7418 | Link |
Which Blu-Ray is that exactly? I'd suggest doing another run with eac3to v2.80, just to be sure that it's not a new bug introduced by the automatic 2pass logic. Also please check audio sync at the beginning and end of the movie. Is sync slightly off at the end of the movie?
19th December 2008, 11:36 | #7419 | Link |
Madshi,
it's Hancock. I remuxed the PCM (after Pcm2Ts) and the MKV with TsMuxer but the thing will not even play in my Popcorn Hour. The MKV alone plays fine though. Will try 2.80. Shouldn't make a difference whether I use the GUI or not should it? |
eac3to |
