Old 29th September 2010, 13:03   #621  |  Link
Zerofool
VR, 3D & HDR UHD fan
Hi, now that nnedi3 and eedi3 do have 64-bit experimental builds, I only need a 64-bit version of the plug-in "Average". I see it's been requested by Stephen R. Savage, but there's no progress as far as I can see. If someone can port the plug-in, that would be very nice.
I would also like to request a feature from Avisynth 2.6. The ConvertTo function has this "chromaresample" argument, which is very helpful for my needs (mostly RGB videogame footage), If it could be ported to this 64-bit build of Avisynth, that would be great, thanks in advance.
And godspeed to the project .
Zerofool is offline   Reply With Quote
Old 1st October 2010, 18:13   #622  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Is there any known problem with the resizer in Avisynth x64?
I got lots of crashes in MeGui and after some more testing and checking with Vdub, it seems Avisynth x64 crashes on certain source resolutions for the resizer.
f.e.
1920x1080 autocropped in MeGui to 1916x1080 => any resizer => 1280x720 = crash
1920x1080 autocropped in MeGui to 1918x822 => any resizer => 1280x544 = crash
Same machine, same source files, same resolutions on Avisynth x86 work without any problems.
LeXXuz is offline   Reply With Quote
Old 2nd October 2010, 04:22   #623  |  Link
zmaster
nvidia user
Which version of AviSynth_MT do you use? Resizing works great in the version of 4/16/2010.
zmaster is offline   Reply With Quote
Old 2nd October 2010, 05:59   #624  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
Not really. Try resizing to a mod2 (not mod4) height.
Lyle_JP is offline   Reply With Quote
Old 2nd October 2010, 07:05   #625  |  Link
zmaster
nvidia user
Lyle_JP,
Hmm... You can specify any particular case? I think resizing always works correctly.
Originally Posted by LeXXuz View Post
1920x1080 autocropped in MeGui to 1916x1080 => 1280x720
1920x1080 autocropped in MeGui to 1918x822 => 1280x544
These situations I have reproduced. The desired result is achieved, no problem.
Old 2nd October 2010, 07:52   #626  |  Link
asarian
I still can't get this to work properly. :( I did everything in the readme.txt, to the letter, ran the avisynth64_install.cmd, but I can't even get this simple script to work (gits2.avs):
LoadCPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\ffms2.dll")
FFVideoSource("f:\jobs\gits2.mkv").ConvertToYV12()
MCTemporalDenoise(settings="low", useEEDI2=true)
And I call it as follows:
c:\x264\x264.exe --crf 14 --sar 1:1 --aud --nal-hrd none --level 4.1 --preset placebo --vbv-bufsize 70000 --vbv-maxrate 60000 --bframes 8 --aq-mode 2 --tune film --output "c:\video\gits2.264" "f:\jobs\gits2.avs"
(x264.exe is the 64-bit executable)
Nothing happens, for a long time. Then I get this error:
avs [error]: Script error: there is no function named "gradfun2db"
(MCTemporalDenoise.v1.4.20.avsi, line 700)
(f:\jobs\gits2.avs, line 6)
I am not even using "gradfun2db", nor have I set ENHANCE to true.
Please, tell me what I'm missing.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 2nd October 2010, 09:54   #627  |  Link
kypec
User of free A/V tools
kypec's Avatar
MCTD "low" settings have enhance option enabled by default, try to set it false explicitly in your filter call.
kypec is offline   Reply With Quote
Old 2nd October 2010, 10:51   #628  |  Link
asarian
Good catch! Sadly, it keeps throwing the same error, even when I set it to 'medium'.
Old 2nd October 2010, 20:27   #629  |  Link
AlekseiV
The script seems to suggest setting GFthr to 1.0 to disable Gradfun2db:
enhance : Enable GradFun2DBmod post processing to enhance flat areas
GFthr   : Gradfun2db threshold [1.0=off,...]
AlekseiV is offline   Reply With Quote
Old 3rd October 2010, 12:31   #630  |  Link
LeXXuz
LeXXuz's Avatar
Lyle_JP,
Yep. Works with x86 version also without any problems.
I'm not sure which x64 version is installed. Have to see if it's from 4/16.
Old 3rd October 2010, 14:19   #631  |  Link
asarian
So, this is interesting. Seems basically GradFun2DB is always on by default then. Didn't know that (I usually have a second line following with a separate GradFun2DB command). I just thought GradFun2DB was a function of ENHANCE.
Now, who do I suck up to to have GradFun2DB ported to 64-bit? :) Seriously, if someone were to do so, then MCTemporalDenoise could finally run with all the trimmies in 64-bit (where it solidly belongs).
Old 3rd October 2010, 16:11   #632  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Now, who do I suck up to to have GradFun2DB ported to 64-bit? Seriously, if someone were to do so, then MCTemporalDenoise could finally run with all the trimmies in 64-bit (where it solidly belongs).
Set fixband=false in MCTD.
LaTo is offline   Reply With Quote
Old 3rd October 2010, 16:20   #633  |  Link
asarian
Thanks for letting me know the official way.
But, erm, any chance you'll compile GradFunDB for 64-bit one day?
Old 5th October 2010, 12:59   #634  |  Link
AlekseiV
Avisynth 8-29-10 with DGDecode_mpeg2source post-processing and SetMTMode(2) has bad artifacting for me.
If cpu=1 or 2, small white dots occasionally appear. Hard to spot in a still frame.
If >2, lots of green or white things often appear. See here or here (cpu=4 and cpu=6)
Shows up even in a script consisting only of:
SetMTMode(2,4)
return DGDecode_mpeg2source("Dresden.d2v", info=3, idct=5, cpu=6) #tested: idct=3|5, cpu=1-6
They're non-deterministic, reloading the script and requesting the same frame causes different artifacts (or none)
It works fine with SetMTMode(3) or just disabling post-processing.
Has anybody else seen this?
Old 5th October 2010, 22:33   #635  |  Link
asarian
Just want to thank everyone involved (to no small degree, Kemuri) for porting all this stuff to 64-bit. :) I can now run a full MCTemporalDenoise job, complete with GradFun2DB and SupTitle plugin, all in 64-bit. No more mucking around with avs2yuv.exe, and hope it still all fits into memory.
Old 7th October 2010, 16:37   #636  |  Link
kypec
kypec's Avatar
Finally succeeded to install that x64 build on my Win 7. The culprit was to execute all scripts and registry editing from inside "cmd.exe", otherwise the enviroment was configured like 32-bit and though the import of registry keys appeared good, they were never really written into proper place!
Quick benchmark of simple AVS scripts utilizing MCTemporalDenoise(settings="medium") on 1920x800 source [no MT at all I remind you] returned following results:
  • 32-bit avs2avi.exe = 0.97 FPS
  • 64-bit avs2avi64.exe = 1.13 FPS
for E8400 @ 3.0GHz that I've in my office.
~17% speedup is not that much but I believe MT will boost the performance even more once I run it at home i7-920 @ 2.66GHz.
Old 15th October 2010, 17:20   #637  |  Link
cweb
cweb's Avatar
I just installed this 64 bit build, and I'm looking right now for a 64-bit version of hdragc... hoping someone ports it someday
Edit: What's needed to port these plugins actually? Is there any documentation available or examples?
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 16th October 2010, 02:36   #638  |  Link
AlekseiV
You need the source code, for one. Since HDRAGC is closed-source, the author would need to rewrite any x86-only code and recompile for x64.
Old 16th October 2010, 08:51   #639  |  Link
cweb
cweb's Avatar
I've got the source I think of an older GPLed version dated 2005, at least that's what it says...
I just installed visual studio 2008 with the x64 tools.
Old 16th October 2010, 14:58   #640  |  Link
cweb
cweb's Avatar
I built hdragc for x64 and got it to load but it kept adding green frames every now and then.. so I gave up on it.. for now at least.
This is avsrecursion.dll which I built for 64 bits too.. I didn't test it but here it is just in case. No guarantees that it works..
http://www.filesonic.com/file/25354761/AvsRecursion.rar
