Old 23rd October 2007, 15:05   #661  |  Link
mroz
mroz's Avatar
First result for the original MV_BUFFER_FRAMES=10
vim:tabstop=6
Tuesday, October 23, 2007 12:58:52
Frame Total Variation
15858 1 1.816673
15859 2 3.181405
15861 3 0.210538
Test complete.
So at least I can now see an error - three close frames out of nearly 150,000.
@Fizick:
Before I test with the modified MVTools, can I just check with you, will they all produce bitwise identical output when run with no SetMTMode? If so, I only need run the SetMTMode variants & compare to my baseline avi, which will cut the time for each run from nearly 8 hours to only 1.5 hours.
BTW The links you posted to the dlls are broken - you missed the s off the end of each mvtool.
mroz is offline   Reply With Quote
Old 23rd October 2007, 18:02   #662  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
mroz,
Thanks for fast testing. (I corrected a links).
Yes, all MVTools without SetMTMode must produce identical results (only speed may vary a little).
Modifications is not big, it is not a solution of the problem, but some indicative test.
Old 23rd October 2007, 18:53   #663  |  Link
tsp
tsp's Avatar
Fizick: a possible (temporary) solution could be to use a smart pointer to MVGroupOfFrames that correctly decremented the refcount of MVGroupOfFrames when it goes out of scope and only allow recycling of MVGroupOfFrames that has a refcount of 0. Currently only IncRefcount is implemented for MVGroupOfFrames.
Get my avisynth filters @ http://www.avisynth.org/tsp/
tsp is offline   Reply With Quote
Old 23rd October 2007, 20:25   #664  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
tsp,
yes, and buffer size must be changed from constant (it may be not enough) to variable.
Old 23rd October 2007, 21:15   #665  |  Link
tsp
tsp's Avatar
Fizick: I will try implementing the MVGroupOfFrames smartpointer and a variable buffersize
Old 23rd October 2007, 22:39   #666  |  Link
tsp
tsp's Avatar
Ok a new version that incorporates the above suggestion is ready. Please try it and see if it improves anything when used with setmtmode. You can get it here:
http://www.avisynth.org/tsp/mvtoolsMTcomp.zip
Old 24th October 2007, 03:57   #667  |  Link
mroz
mroz's Avatar
Originally Posted by Fizick View Post
mroz,
Great, that'll save lots of time
Understood but I appreciate that work is being done.
Here are my corresponding results for your MV_BUFFER_FRAMES=6 dll
vim:tabstop=6
Tuesday, October 23, 2007 17:53:11
11035	1	0.015687
11037	2	0.018902
11038	3	0.248984
11086	4	0.349582
11090	5	0.972039
15095	6	1.939990
15098	7	0.280023
16865	8	0.721465
16866	9	0.812497
16889	10	0.670940
16890	11	1.173558
17302	12	0.038992
17305	13	0.505871
17306	14	0.719297
18118	15	0.089515
20351	16	0.502222
20354	17	0.210579
22854	18	0.376654
24835	19	1.557945
24838	20	0.165073
28903	21	0.197361
28906	22	0.091904
29180	23	0.232695
29182	24	0.322055
29183	25	0.373993
30282	26	0.510847
30424	27	0.019494
30426	28	0.110264
30798	29	0.373128
30802	30	0.260479
31510	31	0.228801
33562	32	0.211502
33565	33	0.082752
33657	34	0.125897
33670	35	1.098033
33673	36	0.058188
35916	37	0.302044
37413	38	0.024555
37416	39	0.248225
40088	40	0.365724
41457	41	0.024742
41460	42	0.077433
42949	43	0.379954
42950	44	0.346376
43619	45	0.728546
43622	46	0.182506
44745	47	0.629474
44746	48	0.399838
46131	49	0.021676
46134	50	1.285427
48111	51	0.603243
48114	52	0.082384
48194	53	0.166780
51767	54	0.038720
51770	55	0.071487
52195	56	0.209815
52198	57	0.053900
52971	58	0.046540
52974	59	4.742179
55760	60	0.520754
55761	61	0.170728
55762	62	0.237919
57478	63	0.295764
61243	64	0.337114
61246	65	0.081116
61503	66	0.092666
61506	67	0.048821
61607	68	0.289923
61610	69	0.082652
61687	70	0.152583
61690	71	0.175322
62591	72	0.920901
62594	73	0.357663
62823	74	0.711127
63833	75	2.121323
63834	76	3.187475
64275	77	0.001378
64961	78	0.162714
64962	79	0.345326
67111	80	0.002054
67114	81	0.187752
69703	82	0.040604
69706	83	0.476924
71515	84	0.708087
71518	85	0.101423
71834	86	0.353010
73215	87	0.048512
73218	88	0.375491
74395	89	0.028145
74398	90	0.184067
74921	91	0.010113
74922	92	0.176437
75031	93	1.834347
75034	94	0.122357
77595	95	0.355491
77598	96	0.125475
78220	97	0.178333
78222	98	0.295954
78223	99	0.385514
78555	100	0.036707
78558	101	0.038212
79946	102	0.019544
79950	103	0.314157
80103	104	0.072031
80106	105	0.443512
80794	106	0.231408
80798	107	0.429387
82511	108	3.504525
82514	109	0.131558
83095	110	0.241904
83098	111	0.229109
83167	112	0.042083
83170	113	0.502277
83946	114	1.424533
84443	115	0.632131
85035	116	1.133995
85038	117	0.234205
86291	118	2.460492
86294	119	0.241094
89296	120	0.267791
89298	121	0.630590
89299	122	0.276484
89646	123	0.175880
91951	124	0.657542
91952	125	0.011080
91953	126	0.386147
92610	127	0.351812
92613	128	0.278424
93207	129	0.117969
93208	130	0.293646
94782	131	0.339254
94785	132	0.127108
95146	133	0.055489
95149	134	0.245969
95480	135	0.032614
95481	136	0.241876
96537	137	0.145288
96720	138	0.001228
96724	139	0.246610
96725	140	0.059872
96781	141	0.075450
96866	142	1.591221
96869	143	0.085255
99546	144	0.090596
99549	145	0.111317
99646	146	0.028165
99649	147	0.356581
99974	148	4.203999
99977	149	0.189322
100734	150	0.052224
100737	151	0.317698
101410	152	0.380507
101413	153	0.268456
101446	154	0.851510
101449	155	0.201051
101566	156	0.627114
101569	157	0.112604
102066	158	0.909575
102069	159	0.114531
103164	160	0.172163
103165	161	0.194189
104458	162	2.803576
104459	163	0.095143
104461	164	0.217942
104798	165	0.232049
104801	166	0.390398
106811	167	0.479852
106813	168	1.080945
106814	169	0.366071
107395	170	0.290446
107397	171	0.756489
107398	172	0.094236
108499	173	0.035672
108501	174	0.772666
109116	175	0.013842
109117	176	0.693476
109263	177	0.419134
109265	178	0.433827
109887	179	0.037398
109889	180	0.456709
110363	181	0.638587
110365	182	0.273036
111294	183	0.519425
112855	184	0.436112
112856	185	0.461187
112858	186	0.197535
113339	187	0.465803
113342	188	0.735912
118453	189	0.144465
118456	190	0.255532
118482	191	0.030365
118483	192	0.052658
118484	193	0.430398
119627	194	0.005023
119628	195	0.373068
119993	196	0.174600
119996	197	0.494724
120457	198	0.356260
120460	199	0.047622
124524	200	0.323934
125926	201	0.825262
125927	202	0.336890
125928	203	0.762235
125929	204	0.391387
125930	205	0.597881
125931	206	0.380590
130107	207	0.216572
130109	208	0.507754
130153	209	0.247313
133415	210	0.019257
133416	211	0.025065
133418	212	0.018010
133851	213	0.830890
133853	214	0.449552
134842	215	2.091352
134843	216	2.824228
134845	217	0.755368
134846	218	2.100201
134902	219	0.515646
134905	220	0.719432
134906	221	3.407452
135722	222	0.713153
137604	223	0.508993
137605	224	1.093383
137607	225	0.392873
137608	226	0.923373
138706	227	1.288582
138709	228	0.682757
143484	229	3.782573
143693	230	0.248797
143695	231	1.875079
143696	232	0.889129
They seem to be consistent with expectations. Do you have any guess as to how number of errors will scale with buffer size?
Now I know I don't need to repeat the non MT runs for the new dlls I should be able to post all other results by tomorrow.
Edit: Will of course also test tsp's mod.
Old 24th October 2007, 05:03   #668  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
thanks tsp!
I independenty made patched version too
(it support MVDegran1 and MVAnalyse only)
http://avisynth.org.ru/tmp/mvtools.dll
probably your is more smart.
(More comments in evening.)
mroz,
thanks for test! probably we really get weak chain.
Old 24th October 2007, 13:32   #669  |  Link
Vesi
Posts: n/a
since i have athlon 3200+, when i use this script i get about 4-5fps.
how can i use mt with this script to see how it goes?
should i use mt with lsf or frfun7?
FRFun7(Lambda=1.1,T=6.0,Tuv=0)
dull = last
sharp = dull.LimitedSharpenfaster( ss_x=1.0, ss_y=1.0,smode=3, strength=60, overshoot=1,special=true )
Soothe( sharp, dull, 20 )
Tweak(sat=1.1,bright=-8,cont=1.1)
@ where to get the latest MT?
Edit: i have found some info that mt is meant for cce encoding, not for divx/xvid, so can we use it with x264?
Old 24th October 2007, 16:36   #670  |  Link
tsp
tsp's Avatar
Vesi: Unless you have a hyperthreading or multicore or multiprocessor computer you wouldn't see any improve using the mt plugin.
Fizick: I more or less copied the PVideoClip class and modified it to
use MVGroupOfFrames pointer instead of VideoClip pointer and changed the return type of MVFrames::GetNewFrame and MVFrames::GetFrame to the new PMVGroupOfFrames class and fixed all the compiler error what came afterwards (about conversion from PMVGroupOfFrames to MVGroupOfFrames * not possible). So it should work with all the functions that uses idx
Old 24th October 2007, 22:07   #671  |  Link
mroz
mroz's Avatar
thanks tsp!
mroz,
Just finishing running all the huffy encodes on my test material. Will queue up the comparison analysis then & that should take about another 1 to 2 hours.
Your dll above resulted in a silent crash about 1% of the way into the encode. There's no useful info in the Megui log from Mencoder. It just seems to have terminated prematurely. I've not had any other problems on this machine since building it a couple of months ago, but I suppose it could still be anything.
I'm re running that encode now & currently it's about 24% of the way through, so if the problem was down to mvtools, it isn't deterministic, but then if it's a threading issue one wouldn't expect it to be.
Update: it crashed at 68% of the way through. Again, no useful log info; it just terminated unexpectedly.
Regarding anticipated results, I can say before performing the comparisons that I've noticed the more errors there are, the more compressible the output, thus file size is some indication of error rate. For the buffer size variations it looks as though there's a very rapid increase in error numbers as the buffer size drops.
The table below shows this. Under version, b<x> indicates the Fizick builds with buffer size <x>.
Version  Error #  Undersizing (as a fraction of clean output)
b4           ?    0.0092
b5           ?    0.0024
b6         232    0.0000039
b10          3    0.000000062
b15          ?    0.00000000032
tsp          ?    0 (though not bitwise identical)
Edit: re the output from the crashes, I've corrected the unwritten header info (AVIRepair) & rebuilt the index (DivFix), just out of curiosity. DivFix failed on the 2nd crash file (maybe it doesn't like large files - it gave an i/o error). However the first small one, about 1min 53s long (321MB) is playable. Nothing unusual is visible just before the encode terminated, however about 1min 14s into it there's a weird artifact lasting 35 frames in the bottom 1/10 of the display. It's equivalent to a black rectangle smoothly rising up from the bottom, obscuring the intended content, reaching a maximum height & then dropping back down. IOW for the duration of the effect, the bottom n lines of the display are blanked, with n rising from 0 to about 50 then falling back to 0.
Old 25th October 2007, 04:34   #672  |  Link
mroz
mroz's Avatar
Results:
b4      128886    0.0092
b5       75865    0.0024
b6         232    0.0000039
b10          3    0.000000062
b15          3    0.00000000032
tsp          2    0 (though not bitwise identical)
Interpreting the last two rows above requires a recap & clarification of a few aspects of this test. Note that rounding error leads to a 'Variation' (see script below) of 0.000022 between identical frames, so I arbitrarily chose to log any variation greater than 0.0001 as a dubious frame.
Now for b<x>, x<=10, logged errors are typically 0.1 to 1 in magnitude & almost never below 0.01. The resulting artifacts shown by subtract are visible to the eye without any enhancement & resemble ghosting around moving edges, corresponding to incorrect buffers being accessed I assume that actually correspond to temporally nearby frames.
Recall the log from b10:
15858	1	1.816673
15859	2	3.181405
15861	3	0.210538
Test complete.
Cases b15 & tsp1 are significantly different as the logs below show:
b15:
Thursday, October 25, 2007 01:44:06
76888	1	0.000386
128332	2	0.000904
128331	3	0.001176
Test complete.
tsp1:
Thursday, October 25, 2007 02:07:57
7037	1	0.001146
63052	2	0.003961
Test complete.
The few errors that have been noticed are unusually (though not exceptionally) small. Visually, I can't see them in a simple subtract. Subtract(c1,c2).Levels(124, 1, 132, 0, 255) renders them visible & shows them to be somewhat different to the usual. These five are all similar in character; tsp1 frame 63052 is a reasonable example:
By digitalrat
They all occur on the right side & resemble a formless small patch of noise almost. Typically within a low contrast area of the video & subject to high motion.
Do you think these are indicative of the multithreading problems? I know Fizick said the b<x> variations should produce pixel wise identical output to each other when run without MT, which implies the errors in b15 must be the result of interaction with MT, but does that also apply to the tsp modified MVTools?
I'll run a non MT encode overnight using the tsp variant just to check.
Can anyone draw any conclusions, or likely conclusions, from the above?
Any comments? Anything more I can do?
For completeness, here's the script I used to look for differences:
SetMTMode(2,0)
leaf1="noSetMT"
leaf2="SetMT-t1-b10"
global c1=AVISource("E:\Work\test\hfyu_MVMT-longtest-"+leaf1+".avi")
global c2=AVISource("E:\Work\test\hfyu_MVMT-longtest-"+leaf2+".avi")
global total=0
global file="E:\Work\test\compare-"+leaf1+"-"+leaf2+".log"
BlankClip(c1, width=16, height=16) # maybe 15% faster than using c1 as our 'dummy' clip (& 100% faster than using subtract(c1,c2) with variation subtitled)
WriteFileStart(file, """ "vim:tabstop=6"+chr(10) """, """ Time("%#c")+chr(10) """, """ "Frame"+chr(9)+"Total"+chr(9)+"Variation" """, append=true)
WriteFileEnd(file, """ "Test complete."+chr(10) """)
ScriptClip( """
  variation = LumaDifference(c1,c2)+ChromaUDifference(c1,c2)+ChromaVDifference(c1,c2)
  # nb1 keeping writefile inside here allows us to store variation as local, reducing problems with running in MTMode 2
  # nb2 aside: writefile doesn't want to when called inside FrameEvaluate; anyone know why?
  # nb3 sometimes the running total is reported incorrectly in MTMode 2 as another thread updates the total before code writes out data to log;
  #     this isn't terribly important & can be corrected as is implicit in data set
  # nb4 compare against 0.0001 instead of 0 to allow for rounding errors - 2 identical files will report a variation of 0.000022
  WriteFileIf(file, "variation>0.0001", "current_frame", "chr(9)", "thistotal", "chr(9)", "variation")
  global total = total + ((variation>0.0001) ? 1 : 0)
  thistotal = total # massively reduce chance of MTMode 2 screwing up logging of total
  return last
Old 25th October 2007, 05:11   #673  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
tsp,
thanks, I see the source code now.
some question about memory optimizing.
I see if all buffer spaces are filled, you increase its size by doubling.
Why double the buffer size instead of incrementing it?
mroz,
thanks for massive test info.
there is no fast conclusion.
wait.
But it is better fogrget about my broken mvtools.dll.
tsp mod shoold be better (more safe).
Old 25th October 2007, 13:44   #674  |  Link
mroz
mroz's Avatar
Wrt the non-MT encode using tsp's build, you probably don't need me to tell you, but it did indeed result in a bitwise identical output to the other builds' non-MT output. So, whatever is causing the small variance in output, it is MT related.
Old 25th October 2007, 16:53   #675  |  Link
tsp
tsp's Avatar
Fizick: mainly to avoid resizing the array to many times. But incrementing it might be better as it doesn't take much time to copy the pointers.
The corruption in the lower right corner could be because both thread are running MVPlane::Refine/RefineExt at the same time. I have created a new version that uses a critical section to avoid this. It is available from here
mroz: Thanks for the testing. Could you try the new version above?
[edit]
ups wrong version. I have updated the file so please download again. This one should work.
[/edit]
Old 25th October 2007, 20:03   #676  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I have seen this behaviour recently even without any MT - however the application I used to encode uses multithreading. I'm trying to reproduce it to provide a better report, I first need to figure out if it's the encoder or MVTools causing the issue.
Old 25th October 2007, 20:09   #677  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Tsp, thanks for update (I will mirror your version at my site after test).
Can two threads simultaniuosly refine different planes now?
If not, is any performance penalty?
Can somebody (mroz) make a speed test?
(and artefact test too, of course)
Old 25th October 2007, 23:18   #678  |  Link
tsp
tsp's Avatar
Fizick: Yes they can refine different planes at the same time as there are one lock per plane. In a very small speedtest with a 720x576 source and this script
SetMTmode(2)
function MVDegrain2i(clip "source", int "overlap", int "dct", int "idx")
overlap=default(overlap,0) # overlap value (0 to 4 for blksize=8)
dct=default(dct,0) # use dct=1 for clip with light flicker
idx=default(idx,1) # use various idx for different sources in same script
fields=source.SeparateFields() # separate by fields
backward_vec2 = fields.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=overlap, idx = idx,dct=dct)
forward_vec2 = fields.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=overlap, idx = idx,dct=dct)
backward_vec4 = fields.MVAnalyse(isb = true, delta = 4, pel = 2, overlap=overlap, idx = idx,dct=dct)
forward_vec4 = fields.MVAnalyse(isb = false, delta = 4, pel = 2, overlap=overlap, idx = idx,dct=dct)
fields.MVDegrain2(backward_vec2,forward_vec2,backward_vec4,forward_vec4,thSAD=400,idx=idx)
Weave()
source=AVISource("F:\20070513-193504.avi").trim(0,101)
mvdegrain2i(source,4,1,1)
the new and old version of mine has the same speed (1.54 fps, 66 sec). I didn't test for artifacts in this run. The weird thing is that without SetMTmode and the above script the speed is 0.74 fps (138 sec) or 2.1(110% speed increase) times faster with 2 cores. I don't know how to explain this. Very strange.
Old 26th October 2007, 04:57   #679  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
I do not understand why you use same critical section both for frame and for plane class?
Old 26th October 2007, 08:29   #680  |  Link
tsp
tsp's Avatar
it's not the same critical section. It is both defined in the MVFrames and MVPlane class. I use the same variable name for the CRITICAL_SECTION sorry if that is confusing. So it is one CRITICAL_SECTION per class instance.
