Old 24th March 2018, 04:47   #1  |  Link
hydra3333
ffmpeg using .vpy scripts directly one day, like avisynth ?
Do you think there's any chance of ffmpeg one day building with something like --enable-vapoursynth so that it can consume .vpy scripts directly, sort of like avisynth ? Is there a feature in the works of any kind ?
It could mean that VS may need to be amenable to cross-compilation, so I figure the chances are remote. What do you reckon ?
Yes there's vspipe (video, no audio unless I'm mistaken ?) and HDR can be piped per this https://forum.doom9.org/showthread.p...37#post1831137
This person had a start at having a go with what appears to be limited success
'vapoursynth': { # not cross compiling ( yet )
and
'vapoursynth_libs': {
https://github.com/DeadSix27/python_...ss_compiler.py
Old 24th March 2018, 09:11   #2  |  Link
Selur
Selur's Avatar
sure it's possible in theory, but whether someone is motivated enough to implement it is a totally different thing
-> either implement it yourself and send a patch to the ffmpeg dev team or create a feature request through the official channels and hope for the best
The repository you link there doesn't seem to aim to add Vapoursynth support to ffmpeg.
It's compiles for example MPV on Linux for Windows.
Old 24th March 2018, 09:39   #3  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
That must be a very old comment about cross compiling, I know people who've cross compiled it many times to compare gcc vs msvc for speed. Time to write the code I guess...
Myrsloik is offline   Reply With Quote
Old 24th March 2018, 14:07   #4  |  Link
hydra3333
Oh. Would you be able to name someone here, or maybe post or a github link or something ?
Old 25th March 2018, 12:30   #5  |  Link
jackoneill
unsigned int
jackoneill's Avatar
The core library and the included plugins (minus ocr) can be cross-compiled pretty easily. You pass
--host=x86_64-w64-mingw32
to configure.
The Python module is the annoying part, because you must also cross-compile Python, and I think the Python developers don't make it easy.
But this is all irrelevant, because VapourSynth has a C API, so you can just use the official binaries compiled with MSVC. You don't have to cross-compile it for ffmpeg.
Correction: VapourSynth has a reasonable C API, unlike Python.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 25th March 2018, 13:07   #6  |  Link
Selur
Selur's Avatar
Also instead of cross compiling you could also compile it on Windows using media-autobuild_suite.
(Cross-Compiling won't allow ffmpeg to .vpy files so this might not be what you are looking for.)
Old 27th March 2018, 05:01   #7  |  Link
hydra3333
Thank you. Yes I've used jb's under Windows - and may still resort to that if cross-compilation of a static ffmpeg and its dependencies (3rd party libraries) is out of the question.
My objective was to cross-compile a static ffmpeg for windows whilst as far as possible keeping a minimalist Windows PC environment free from bits needed for compilation (eg stuff as needed for jb's approach and/or visual studio bits for vapoursynth). There are various linux cross-compilation approaches (eg zeranoe's which is a widely used build, rdp's, deadsix27's) eg using "free" ubuntu in a clean VM. The market appears to be out there.
to configure.
Ah, good oh. I guess one needs to do the usual things like setup the same folder structures as compiling it under windows, with sources from https://github.com/pinterf/AviSynthPlus/tree/MT and https://github.com/sekrit-twc/zimg/releases
Oh. Time for some newbie googling, to see if anyone's cross-compiled python libraries in a way acceptable to an ffmpeg build process.
I suppose setting up for cross-compiling would need to take into account the "correct" way to do these these things, to result in a cross compiled Win build:
From the current windows build instructions
Needs Visual Studio 2017 and vsnasm (https://github.com/ShiftMediaProject/VSNASM)
It also needs both 32 and 64 bit Python 3.6 series with recent setuptools, cython, sphinx and sphinx-intl installed
Inno setup is needed to create the installer (default installation path assumed)
7-zip is needed to compress the portable version (default installation path assumed)
Clone VapourSynth
Clone zimg v2.7 branch into the VapourSynth dir (https://github.com/sekrit-twc/zimg)
Clone avs+ pinterf mt branch into the VapourSynth dir (https://github.com/pinterf/AviSynthPlus/tree/MT)
Compile 32 and 64 bit release using the VapourSynth solution
Run cython_build.bat to compile the Python modules
Run make_docs.bat to compile the documentation
I had to make "novice's home notes" while experimenting building vapoursynth under windows on a very old and exhausted "spare" PC ... so I suppose these would also need to be catered for as a part of cross compilation
A. Under Windows, I found that for other dependencies like
cython, sphinx and sphinx-intl this seemed to not crash:
1. install 64 bit python (3.6 in this case) as I only need 64bit stuff
2. start an Admin CMD dos box (or it can't copy files into protected folders) then use the pip command to install the packages, which apparently gets installed with python:
pip uninstall cython
pip --no-cache-dir install cython
pip uninstall sphinx-intl
pip --no-cache-dir install sphinx-intl
# uninstall and then install, to get the latest versions
B. Under Windows I also got this error building avscompat
LINK : fatal error LNK1181: cannot open input file 'gdi32.lib'
which is apparently a known error per http://stackoverflow.com/questions/3...file-gdi32-lib
If anyone has this problem on Visual Studio 2017, it is an issue with the Windows 10 Creators Update.
A workaround is to select the "Windows 10 SDK (10.0.15063.0) for Desktop C++ x86 and x64" under the "Desktop development with C++" workload in the Visual Studio Installer.
C. Other source to clone before building, into EXACTLY the right folders
1. For vapoursynth to build, the avs+ mt branch placed in the root of vapoursynth folder tree must be called "AviSynthPlus". Source: https://github.com/pinterf/AviSynthPlus/tree/MT
2. and the zimg v2.7.1 branch placed in the root of vapoursynth folder tree must be called "zimg". Source: https://github.com/sekrit-twc/zimg/releases
Looking at that, I'm agreeing with you, jb's Windows-based build method looks like it may be the only way for a newbie to get something up and going once the VS coding etc is done. Unless someone has already done it and is willing to share the process in detail for others to learn
Old 27th March 2018, 17:38   #8  |  Link
jackoneill
unsigned int
jackoneill's Avatar
VapourSynth's Avisynth(+) compatibility module must be compiled with MSVC, because it uses the Avisynth(+) C++ API, and Avisynth(+) itself is compiled with MSVC. If you manage to compile the Avisynth(+) compatibility module with clang and its -fms-extensions parameter, that may also work, but I don't think anyone tested it.
Old 27th March 2018, 18:18   #9  |  Link
Myrsloik
Myrsloik's Avatar
Clang can compile that too now after avs+ actually made the headers follow the c++ standard... I think it works but didn't test it that much.
Old 28th April 2018, 20:15   #10  |  Link
DJATOM
DJATOM's Avatar
I spent some time on making x264 support vpy scripts internally. Patch here.
The ideas and some code taken from ffmpeg demuxer proposed here, avs.c input from x264 and NVEnc's vpy input module.
Not sure if that's faster than piping, but looks like complex scripts uses all CPU cores.
Code will definitely compile well with icl 2018 or gcc 7.3.0. I didn't tried another compilers.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 29th April 2018, 01:06   #11  |  Link
hydra3333
Thank you !
Separately, here's a link explaining why building a static ffmpeg with vapoursynth can't be done.
https://forum.doom9.org/showthread.p...31#post1840531
Old 29th April 2018, 01:15   #12  |  Link
TheFluff
Excessively jovial fellow
http://lists.ffmpeg.org/pipermail/ff...il/229125.html
Old 29th April 2018, 16:07   #13  |  Link
hydra3333
OK, if that could be done and for example that meant that if the ffmpeg exe was run in the same folder as "portable VS" and it worked then that could well be close enough for some purposes ( eg mine ).
Do you know of the current ffmpeg change proposal (per the link above) achieves that including delayed loading of python or are there more changes needed ?
Also, I wonder if the same portable VS folder structure is needed for plugins DLLs etc which I guess can't be statically linked in either, I suppose it is.
Old 29th April 2018, 17:09   #14  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
It loads the script into memory, and then uses libvapoursynth's vsscript_evaluateScript() to evaluate it. Whatever libvapoursynth does in the background regarding python etc. is what matters, not really that patch.
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 30th April 2018, 02:29   #15  |  Link
hydra3333
Your own, good oh.
If I may, do you have a link to your procedure which I could look and learn from (and pinch) ?
Old 1st May 2018, 12:21   #16  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by HolyWu View Post
For unknown reason I have to pass -lpython3.6m -lstdc++ as extra libs when linking with static vsscript, otherwise undefined references occur.
--enable-vapoursynth --extra-cflags="-DVS_CORE_EXPORTS" --extra-ldflags="-static" --extra-libs="-lpython3.6m -lstdc++"
You have to pass -lstdc++ because I assume ffmpeg has no C++ code, or at least the library that uses VSScript doesn't. Thus gcc is used for linking, not g++. gcc doesn't link stdc++ because it thinks it's all C code, but VSScript uses C++ internally.
And you need to pass -lpython3.6m most likely because ffmpeg's configure doesn't call pkg-config with the --static parameter. If it did, VSScript's pkg-config file would give it -lpython3.6m already.
Old 1st May 2018, 16:10   #17  |  Link
poisondeathray
Will this one day be implemented in common distributed builds , such as zeranoe's ? Or the autobuild scripts ? Or will this be something you have to compile yourself ?
Old 1st May 2018, 19:51   #18  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
--pkg-config-flags=FLAGS pass additional flags to pkgconf []
In other words, adding "--static" to this will get you that.
Old 5th May 2018, 02:21   #19  |  Link
hydra3333
Here's the ffmpeg commit
https://git.ffmpeg.org/gitweb/ffmpeg...182aa0b3778b79
avformat: add vapoursynth wrapper
This can "demux" .vpy files. Autodetection of .vpy scripts is
intentionally not done, because it would be a major security issue. You
need to force the format, for example with "-f vapoursynth" for the
FFmpeg CLI tools.
Some minor code copied from other LGPL parts of FFmpeg.
I did not find a good way to test a few of the more obscure VS features,
like VFR nodes, compat pixel formats, or nodes with dynamic size/format
changes. These can be easily implemented on demand.
--enable-vapoursynth in the ffmpeg configure
Old 5th May 2018, 04:47   #20  |  Link
hydra3333
It nearly works, as reported in https://github.com/DeadSix27/python_...ript/issues/61
It seems that something may be amiss per comment https://github.com/DeadSix27/python_...ment-386771355
