23rd September 2012, 16:46 | #13962 | Link | |
http://depositfiles.com/files/w5ggyvnq5
Windows 7 x64 i7 870 16GB RAM AMD 6870 Last edited by robpdotcom; 23rd September 2012 at 16:55. |
23rd September 2012, 16:52 | #13964 | Link | |
23rd September 2012, 16:57 | #13965 | Link | |||
For you AMD users here are a couple of test builds:
http://madshi.net/madVR83a.rar Please copy one madVR test build into official madVR v0.83.0 folder at a time, renamed to "madVR.ax", of course. Please test all test builds and let me know which one of them work (if any) and which don't. Thanks! Quote:
Can you please try creating a freeze report by pressing Ctrl+Alt+Shift+Pause? Quote:
I'm not sure what's the best way to cut. There are probably many tools out there for that purpose. You could probably mux to DVD, then use the mkvtoolnix GUI to split the MKV into small parts. Probably there's a better way. Maybe someone else has a good suggestion? |
23rd September 2012, 17:02 | #13966 | Link |
I agree that resizing is ugly (and slower) in overlay mode. Otherwise it seems to work without problem on my GTS450.
One other thing I noticed that stopping playback is noticeably slower. I get a 1-2 second black window. Last edited by mzso; 23rd September 2012 at 17:08. |
23rd September 2012, 17:04 | #13967 | Link | |
/人 ◕ ‿‿ ◕ 人\
It's slightly noticeable only when rendering time is near frame interval time (it happens with 60 fps video). |
23rd September 2012, 17:06 | #13968 | Link | |
Do you see any advantages of Overlay mode compared to conventional Windowed mode on your PC? |
23rd September 2012, 17:14 | #13974 | Link | |
For me the normal mode is better since I didn't have problems, so the overlay mode brings just losses. Apart from the resizing there's the impossibility to take screenshots. Otherwise I didn't notice anything different in the two modes. |
23rd September 2012, 17:17 | #13975 | Link |
Here is the freeze report:
http://www.sendspace.com/file/t6urb1 Also tested with the latest mpc-hc from xhmikosr and same thing, black screen when I close the media file while it's running and in FSE mode.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S Last edited by fairchild; 23rd September 2012 at 17:20. |
23rd September 2012, 17:17 | #13977 | Link |
/人 ◕ ‿‿ ◕ 人\
Off, because I'm using integrated graphics all the time. Also I'm making screenshots (press 1, than alt+2, than alt+prtSc - and you'll get frame in 100% size) quite often...
However it would be cool if it would possible to have different settings for different GPU's (e.g. overlay off for intel, but on for nVidia). |
23rd September 2012, 17:18 | #13978 | Link |
madVR 0.83 with overlay enabled will give a black screen if playing a video with multiple subtitles, and I switch the subtitle stream. Happens with both nVidia and Intel GPUs. Also happens with either MPC-HC internal subtitle renderer and vsfilter.
The only way to make the problem goes away is to disable the overlay feature. |
