31st October 2017, 08:16 | #46963 | Link |
Why don't you try it, it literally takes only minutes.
31st October 2017, 13:45 | #46966 | Link |
If I use D3D11 (Native) + MPC-HC (FSE), press Esc while the video is playing will caused the screen became black without any cursor & the only solution is to reboot the PC.
Microsoft & NVIDIA are the culprit. Last edited by khanmein; 31st October 2017 at 13:50. |
31st October 2017, 15:08 | #46967 | Link |
Vega 56 Performance?
Hello Huhn and all people , May I ask your opininion about Vega 56 before I buy a new card? I'd like to render bluray and UHD movies on my 4k projector. Coming from a GTX960 which is clearly on the knees, I want to render smooth 4k 10bit videos just like I did with my 1080p projector and blu ray movies, using SVP in combination with madvr. The CPU is a 2600k@4.4Ghz. I was about to buy a basic 1070 for 350e but I can get a Vega 56 for 40 more euros. Do you think it's worth upgrading to a Vega 56 instead of a 1070? I'd prefer to avoid weird bugs, there a few feedbacks here. Noise and power are not to be considered.
I7 2600K@4.4 / GTX1080 / ACER M550 (DLP 4K) / Catleap (IPS 1440p) / Onkyo SE200 Sound card |
31st October 2017, 16:21 | #46969 | Link | |
31st October 2017, 19:02 | #46970 | Link | |
Until then you can fix it by "disabling fullscreen optimizations" in the Windows compatiblity settings of your player. |
31st October 2017, 19:33 | #46971 | Link | |
31st October 2017, 20:47 | #46973 | Link |
HDR Works but it isn't smooth, you need to do manual setup/unset or you get a bad image or even a crash. It will probably be fixed in a few versions of the drivers and/or a Windows update. HDR on PC has been hit or miss version to version since I got an HDR display.
Edit: I don't have any HDR content to watch on PC, that isn't a demo, so this hasn't been an issue for me. Still it is impressive how hard keeping HDR working apparently is.
madVR options explained Last edited by Asmodian; 31st October 2017 at 20:55. |
31st October 2017, 21:03 | #46974 | Link | |
I know that you redesigned the UI and that you don't have the place anymore for nearest-neighbor so I'm not asking you to modifiy it again just to add this option now. But if you should modify again the UI in the future, please keep in mind that the return of nearest-neighbor is a good idea for some usages. Or you could probably remove Spline, I think that nobody uses it...
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H |
31st October 2017, 21:56 | #46976 | Link |
Not directly related to madvr, but I have a question for you madshi because you have a jvc projector like me. Do you have some panning flickering playing at 23hz? I know that is normal for film content (there is flicker at the theater too) but with my jvc the effect is more apparent on some bright high contrast movies like for example Everest. Do you think I will see any improvements in motion if I play a movie with a high end player like the oppo 203? or it will be the same because of the projector?
I have to say that I hate frame interpolation. Thanks man. |
31st October 2017, 23:01 | #46977 | Link | |
Regarding nearest neighbour, perhaps it's best to have as a filename/folder tag which ignores other scaling settings. Since you would usually know that you want to use it on a file/folder by file/folder basis. |
1st November 2017, 00:50 | #46978 | Link | |
