Old 1st October 2013, 16:37   #20181  |  Link
oddball
Bug report.
http://pdl.warnerbros.com/wbmovies/gravity/trailer2/GRAVITY_TRAILER_5-2k.mov
Plays as red and shades of black. If I switch to EVR it plays fine.
oddball is offline   Reply With Quote
Old 1st October 2013, 17:02   #20182  |  Link
sneaker_ger
It works fine for me. It's ProRes 10 Bit 4:2:2 - do you have any intermediate filters between LAV and madVR? Do you have "P210" output ticked in LAV Video? ("v210" output seems broken for me, not sure if LAV or madVR fault)
Old 1st October 2013, 18:56   #20183  |  Link
6233638
Originally Posted by oddball View Post
Bug report.
http://pdl.warnerbros.com/wbmovies/g...AILER_5-2k.mov
Please report bugs to the bug tracker: http://bugs.madshi.net
But Madshi is aware of the problem: http://www.avsforum.com/t/1490573/gr...#post_23762599
I'm guessing you don't have any display calibration options enabled.
Old 1st October 2013, 19:22   #20184  |  Link
sneaker_ger
Indeed, I do not.
madVR reports BT.709 matrix, DCI-P3 primaries and limited range (all "best guess").
Old 1st October 2013, 19:23   #20185  |  Link
oddball
Nope. P210 and v210 make no difference.
http://i.imgur.com/sARBOwd.jpg
"But Madshi is aware of the problem: http://www.avsforum.com/t/1490573/gr...#post_23762599"
Will check it out.
Old 1st October 2013, 19:25   #20186  |  Link
oddball
OK disabling display calibration fixes it.
Old 1st October 2013, 19:36   #20187  |  Link
sneaker_ger
Does v210 work with disabled display calibration, too? Odd that it's just me.
Old 1st October 2013, 21:19   #20188  |  Link
6233638
You could also tag the video as BT.709 content by putting primaries=709 in the filename.
Old 2nd October 2013, 09:30   #20189  |  Link
ryrynz
ryrynz's Avatar
Next madVR build is going to have some goodies for you guys. Will take a while until it will be released, though.
Would absolutely love to get a test build with the deband feature. Pretty excited for this one based on what I've read and seen over on the flash3kyuu thread.
Old 2nd October 2013, 11:32   #20190  |  Link
SHaKOL
Hi
i have a problem with .avi files when i choose madVR as the video renderer, like this:
but when i choose enhanced video rendere (custom presenter) works normally
SHaKOL is offline   Reply With Quote
Old 2nd October 2013, 11:46   #20191  |  Link
Duffy Moon
Duffy Moon's Avatar
For the last few months, I've been having a problem with my reds. They look very blotchy and noisy. I'm not aware of having changed anything except for drivers (to the latest build). I'm using the latest MPC. All other colours are absolutely fine.
Duffy Moon is offline   Reply With Quote
Old 2nd October 2013, 12:02   #20192  |  Link
ryrynz
ryrynz's Avatar
If updating the drivers was something you've changed then it would make sense to revert that to see if it fixes the issue, besides that you could try restoring default settings via the batch file in MadVR's directory.
Resetting and reverting are the basics when it comes to troubleshooting, always do those first.
Old 2nd October 2013, 12:12   #20193  |  Link
Duffy Moon
Duffy Moon's Avatar
Thanks. I'll try restoring default settings. Actually, I only updated the video driver about a week ago, so the phenomenon was the same with previous one.
Old 2nd October 2013, 12:37   #20194  |  Link
ryrynz
ryrynz's Avatar
If the issue still occurs after resetting post all relevant details of your system (OS, graphics adapter, driver, madVR version etc) and we'll figure it out.
Old 2nd October 2013, 13:59   #20195  |  Link
michkrol
Originally Posted by SHaKOL View Post
Hi
We'll need more info to help. Post your system specs (especially GPU), operating system, drivers version, player + version, codecs + version, madVR version.
If you're not using MPC-HC 1.7.0, try it (mpc-hc.org).
Try pressing (CTRL+J) if you get an OSD in top left corner of the video, post a screenshot, similar to this:
Post a list of filters used (in MPC-HC right click on video, select filters).
Apart from the files being *.avi, what codecs are used? Preferably post MediaInfo (in MPC-HC: File-> Properties, select MediInfo tab, copy whole text here as [code] block).
michkrol is offline   Reply With Quote
Old 2nd October 2013, 18:53   #20196  |  Link
StephaneM
I need some help regarding external pixel shaders, no matter what I try I fail to apply a shader.
What I have done so far : created the playback graph and all is fine. Then upon user interaction I try to add a shader.
Here is my interface definition for C# Interop :
[ComImport, System.Security.SuppressUnmanagedCodeSecurity,
Guid("B6A6D5D4-9637-4C7D-AAAE-BC0B36F5E433"),
InterfaceType(ComInterfaceType.InterfaceIsIUnknown)]
public interface IMadVRExternalPixelShaders
    [PreserveSig]
    int ClearPixelShaders(bool postScale);
    [PreserveSig]
    int AddPixelShader([MarshalAs(UnmanagedType.LPStr), In] string sourceCode,
                       [MarshalAs(UnmanagedType.LPStr), In] string compileProfile,
                       int stage, IntPtr reserved);
And this is how I'm using it :
IMadVRExternalPixelShaders madvrShaders = playbackGraph["VideoRenderer"].GetInterface<IMadVRExternalPixelShaders>();
if (madvrShaders != null)
    int result = madvrShaders.AddPixelShader(shaderCode, targetProfile,
                                             (int)madVRProperties.ShaderStage.PreScaling, IntPtr.Zero);
Marshal.ReleaseComObject(madvrShaders);
No matter what I do I get 0x80004005 as result...
Regarding the arguments I'm passing here they are :
targetProfile = "ps_2_0"
shaderCode = "sampler s0 : register(s0);\nfloat4 p0 : register(c0);\n\n#define width (p0[0])\n....."
Am I missing something ?
Thanks,
Stéphane.
StephaneM is offline   Reply With Quote
Old 2nd October 2013, 19:09   #20197  |  Link
Nachbar
xysubfilter and madvr crash
I just had it crash while I was watching Commie's Monogatari series second season episode two
It crashed specifically while I was full screen around the 3:40 - 4:00 mark. I'm not using full screen exclusive mode. I believe the cause is xysubfilter (not to be confused with xyvsfilter) It will also sometime crash saying it was madvr.dll that caused it
I'm using LAV filters 0.58.2, madvr 0.86.11, reclock 1.8.8.0, mpc-hc 1.7.0, and xysubfilter 3.1.0.546
I've attached the crash report in a zip file.
Nachbar is offline   Reply With Quote
Old 2nd October 2013, 20:05   #20198  |  Link
read the rules:
http://forum.doom9.org/forum-rules.htm
Old 2nd October 2013, 20:16   #20199  |  Link
Nachbar
Thanks Vivan for showing me the fix - it is xysubfilter's fault.
The fix is here: http://code.google.com/p/xy-vsfilter/issues/detail?id=153
Old 2nd October 2013, 21:56   #20200  |  Link
SHaKOL
specs: gtx 570, windows 7 ultimate 64-bit, 327.23 driver, mpc-hc 1.7.0.7680, cccp 2013-08-01, madVR 0.86.11
General
Complete name                  : H:\1\Drift King\الدروس\مجلد جديد ‫‬\ألتنقية\1020.avi
Format                         : AVI
Format/Info                    : Audio Video Interleave
File size                      : 1.91 GiB
Duration                       : 30mn 17s
Overall bit rate               : 9 026 Kbps
Video
Format                         : MS Video
Codec ID                       : CRAM
Codec ID/Info                  : Microsoft Video 1
Duration                       : 30mn 17s
Bit rate                       : 8 988 Kbps
Width                          : 1 152 pixels
Height                         : 796 pixels
Display aspect ratio           : 1.447
Frame rate                     : 200.000 fps
Bits/(Pixel*Frame)             : 0.049
Stream size                    : 1.90 GiB (100%)
