8th June 2010, 22:23 | #7961 | Link |
HD-Fan
Sometimes the videos I convert for my iPod are in way too many pieces but it's rare to get. So I have no choice but convert those many pieces into one file.
For example if an episode is 40mins long then it probably will have 1-6 pieces. Episode.1.part1.avi Episode.1.part2.avi Episode.1.part3.avi Episode.1.part4.avi .... and so on but all adds up only around 200 - 300MB. And there isn't just one episode in the entire series Lol. |
8th June 2010, 23:11 | #7962 | Link |
Why one episode is divided in parts???
9th June 2010, 01:00 | #7963 | Link |
oups.. sorry.
here http://tinyurl.com/24nbv8l and here the script used (here only the part with the subs) .... #Subtitles Loadplugin("D:\DVD-tools\RipBot264v1.16.0\Tools\AviSynth plugins\VSFilter\VSFilter.dll") video=TextSub(video,"C:\Temp\RipBot264temp\job17\3_subtitles_English.ass",-1,23.976) #AudioSource audio=DirectShowSource("C:\Temp\RipBot264temp\job17\2_audio_Japanese.flac",video=false) audio=ResampleAudio(audio,48000) ..... |
10th June 2010, 01:02 | #7967 | Link |
Custom Installer Maker
Yes, also I have encoded two blu-rays locking to DVD9 size and I fear they might as well be a little oversized too.
You are right. I will begin locking to a 5-10 mb margin to be on the safe side as well.
Applications: VistaTweaker, Launch, ServiceTweaker. Custom installers: iTunes without QuickTime, Skype and more. |
10th June 2010, 23:21 | #7968 | Link |
I want to know the difference in ref frames,seems default is 3.I have had some movies (bluray) that have 5 sometimes 4.So the more the better,I assume? A default bluray encode will take my pc about 5.5 hrs.Does using more ref frames mean way longer encode? Also does trellis 2 be that much better? I read it makes the encode take way longer,correct? Thanks to who helps!
stinman |
10th June 2010, 23:43 | #7969 | Link |
3 is optimal. above that starts placebo. your choice. options with higher number will aways take more time. your choice.
11th June 2010, 00:19 | #7970 | Link | |
stin |
11th June 2010, 00:21 | #7971 | Link | |
More reference frames isn't necessarily a placebo, but generally the drawbacks outweigh the benefits; there's scenes where up to 16 reference frames could make a difference, but it's often hardly worth the extra encoding time, and would leave your output file unplayable on most hardware. Or software, for that matter. Lots of HD players out there (including TMT and KMplayer) can't even handle an increase in B-frames properly. So, keeping your reference frames at max 4 for your 1920x108p content is probably your most optimal, overall bet.
Gorgeous, delicious, deculture! |
11th June 2010, 00:27 | #7972 | Link | |
11th June 2010, 00:41 | #7973 | Link | |
@Atak_Snajpera
does the sample helped you ? Quote:
11th June 2010, 00:50 | #7974 | Link |
i see no problem with your sample.
11th June 2010, 05:26 | #7977 | Link |
I don't know,just habit of 2 pass and wanting to control size, after using TsMuxer to mux vid and audio I see what the size was(usually 20/24Gbs movie only) I try to stay close to half the size, and it never fails me to come out with a movie that you can't tell the difference. I always do dvd's with crf20.Blurays I only do the video and mux the HD audio back in after with TsMuxer.
How would you know what size,lock the size in mb just like 2 pass? I may try one over night,crf 20. stin |
11th June 2010, 05:43 | #7978 | Link | |
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 57mn Bit rate : 11.8 Mbps Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.320 Stream size : 9.47 GiB (87%) Writing library : x264 core 95 r1592 95aacc4 Encoding settings : cabac=1 / ref=5 / of course it goes on,I didn't want to fill up the page,I'm sure you seen it.I've always left them at 3. Thanks for the link stin |
11th June 2010, 06:07 | #7979 | Link | |
