5th May 2014, 18:07 | #12681 | Link | |
Compression mode: Lousy
2nd June 2014, 15:40 | #12682 | Link |
With 16 bit in 24 bit Lossless audio conversion is there any way to skip the first pass if I already know what's inside, or at least do the first pass without encoding and a forced second pass? I was thinking maybe -down16 but then realised that would just turn the 24 bit track with 8 bits of zeros into a 16 bit track with 5 bits of zeros. Or is there any way to just reverse the process, start with 16 bit and if it encounters a 24 bit section restart at 24, if it winds up being 20 bit it can do a third pass and I can sit there feeling stupid.
2nd June 2014, 16:16 | #12683 | Link | |
However, when you don't know what's inside, I know of no way to just restart encoding with 24-bit, you'll have to make do with 24-bit and reduce that to 16t-bit if eac3to later detects that the whole track is only 16-bit... Last edited by DarkSpace; 2nd June 2014 at 16:18. |
3rd June 2014, 02:05 | #12686 | Link |
47.952fps@71.928Hz
Is there anywhere that states all the available switches?
The wiki doesn't list "-dontDither", nor does anything when running eac3to. http://en.wikibooks.org/wiki/Eac3to/How_to_Use#Command_Line_Syntax
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
3rd June 2014, 02:52 | #12687 | Link |
Broadband Junkie
Probably something close to the following string dump:
mb test lowPriority progressnumbers neroaacenc= demux skipbytes no2ndpass check fix shutdown logPids logMkv logDts analyzeBitdepth checkPitch nero sonic arcSoft libav downmix down6 down2 downDpl downStereo phaseShift mixlfe normalize 2pass seekToIFrames full float32 skip down32 down31 down30 down29 down28 down27 down26 down25 down24 down23 down22 down21 down20 down19 down18 down17 down16 down15 down14 down13 down12 down11 down10 down9 down8 192000 176400 96000 88200 48000 44100 24000 22050 8 7 6 5 4 3 2 1 16 24 fast steep r8brain 23.976 24.000 24.975 25.000 29.970 30.000 47.952 48.000 50.000 59.940 60.000 changeTo speedupTo slowdownTo FPS value quality=0. quality=0 quality=1 quality=1.0 quality=1.00 blu-ray bluray core silence loop edit=?:??:??,*ms edit=?:??:??.???,*ms slowdown speedup override dontRepairDts dontPatchDts keepFullRange dontCrop stripPulldown keepPulldown resampleTo big little mono double7 simple check16bit ignorePitch decodeHdcd keepDialnorm dontDither ms dB 192 448 640 768 1536 log |
3rd June 2014, 12:10 | #12689 | Link |
Someone already collected all documented and undocumented switches a while ago:
http://en.wikibooks.org/wiki/Eac3to/...nd_Line_Syntax Unfortunately, this does not include the options of the latest version. |
18th June 2014, 23:01 | #12690 | Link | |
20th June 2014, 14:57 | #12691 | Link |
Not that I'm aware of, actually I asked as a feature request on the MakeMKV forum if the program could give a report at the end as to whether a 24 bit DTS-MA or TrueHD track turned out to be 16 bit or not during FLAC conversion. If that happens EAC3To going through both passes during the re-encode would be a waste of time. But of course Mike doesn't usually implement anything so it's unlikely to happen, which is why I had to find a way to justify getting the answer I got.
5th July 2014, 01:50 | #12692 | Link |
I converted a 24/44.1 6-channel DTS file to a FLAC using eac3to with Arcsoft DTS Decoder. The conversion went fine, but there's something weird: I played both files with foobar2000 and checked the waveforms with the Waveform Seekbar addon.
DTS: FLAC: The LFE channel (on the bottom) is louder on the FLAC. Why is that so? |
6th July 2014, 06:43 | #12693 | Link |
...and a REAL problem. There's a certain DTS-CD whose DTS-ES files I could extract properly with bsconvert, but once I put them in eac3to, it simply refuses to decode them with Arcsoft. It doesn't even produce an error. It just says:
DTS-ES, 6.1 channels, 0:04:58, 1235kbps, 44.1kHz Remapping channels... Decoding with ArcSoft DTS Decoder... And that's it. Other DTS-ES files I've used work perfectly. I use Arcsoft 1.1.0.0. |
6th July 2014, 10:39 | #12694 | Link |
I asked a question about thd+ac3 in another topic ;
http://forum.doom9.org/showthread.ph...42#post1685842 I copy it here, the eac3to topic is more appropriate ; is there a trick to mux a True HD track with an ac3 track (both having exactly the same duration) into a single .thd+ac3 file or this interleaved file can only be created from a single True HD track ? It's just by curiosity, I understand that it's not very useful because if one really need to have another ac3 track (than the True HD track), it can be muxed into m2ts in addition to the .thd+ac3. The only utility I see would be to avoid to increase the total bitrate (of a Blu-ray for example) if one need an ac3 track with a different mix than the True HD track. I guess it is possible (but is maybe not available yet but could perhaps be added in eac3to), because just after having created the ac3 track from the True HD, thus just before interleaving them, there are 2 tracks. And I don't see the difference between taking this ac3 stream (existing as a temporary file) and another (already existing) for the interleaving operation. |
6th July 2014, 11:26 | #12695 | Link | |
Please upload a sample (dtswav) before extract with bsconvert.
6th July 2014, 11:38 | #12696 | Link | |
Nope, now you can create a thd+ac3 track with the ac3 created for eac3to with the thd input.
I don't know if madshi can add this option.
6th July 2014, 12:15 | #12697 | Link |
Ok, and do you know how the interleaved ac3/True HD tracks are created by professional tools for Blu-ray's ?
Because I guess that unlike eac3to, they don't create an ac3 stream from the THD stream, they probably take 2 streams (even when they come from the same mix) and interleave them. |
6th July 2014, 13:22 | #12698 | Link | |
SuperVirus
6th July 2014, 14:41 | #12699 | Link | |
Life's clearer in 4K UHD
6th July 2014, 16:03 | #12700 | Link |
I don't need to get the core (eac3to can do it and also TSMuxer IIRC), I'd like to know if an ac3 stream and a THD stream without core can be muxed together to get a .thd+ac3 (which is usually done by re-creating the core from a THD track whose core has been removed).
eac3to |
