Old 10th January 2019, 23:16   #381  |  Link
MasterMeNL
Originally Posted by nalor View Post
Basically it sounds like a problem with your system when it's not even possible to copy those files with windows explorer.
Honestly I don't know how I can help in this case.
Maybe try to use a virtual windows with access to your drive? And see if you can copy the files there?
Gesendet von meinem H8324 mit Tapatalk
When doing it in a Windows 10 VM one of the following happens:
* Native SCSI passthrough: same problem occurs when copying these files as native Windows;
* Emulated drive: access works, DVDFab works, FindVUK complains about it not being a Blu-ray drive and refuses to work (appears there is no way to ignore this check). If I remember correctly it complained because QEMU (the VM) emulates the drive as a CD-ROM drive and not a Blu-ray drive.
I also did some testing on Linux with wine-4.0-rc4
* 32-bit wine, 32-bit DVDFab: DVDFab works, procdump crashes;
* 64-bit wine, 32-bit DVDFab: DVDFab works, procdump64 works, FindVUK step one works completely, step two fails because "Drive is NOT a Blu-ray drive! Exit now!";
* 64-bit wine, 64-bit DVDFab: DVDFab crashes
It appears wine does not support probing for all device info currently, and returns some dummy info which happens to be not a Blu-ray drive:
002a:fixme:ntdll:server_ioctl_file Unsupported ioctl 2d1400 (device=2d access=0 func=500 method=0)
As the UnitKeyDEC is found successfully the most important functionality works fine. I have not found a way to skip the part 2 Blu-ray drive check. Could you add an option or argument to skip the check and assume the drive is a Blu-ray drive or allow for hardcoding drive features in the config file? Possibly changing the check mechanism could fix this. DVDFab reports for example, even with wine, "Disc media: Blu-ray (BDMV)". Alternatively I don't mind hacking the source a bit and submitting a patch, but as far as I can see FindVUK is closed source.
Initially I'd say a version that skips the check would be good for testing, could you upload a version that makes this possible?
MasterMeNL is offline   Reply With Quote
Old 12th January 2019, 00:02   #382  |  Link
nalor
Originally Posted by Mr Wolf View Post
Thanks! I wasn't sure you received my PM.
By the way, is there a KEYDB.cfg database available, were all the keys found by FindVUK are uploaded?
Is there any problem to share my KEYDB.cfg on the forums? (for copyright reasons, I mean)
Hi!
Basically the easiest way to share your data is to 'synchronize' with FindVUK -> it uploads all entries from your local file missing in the online database.
I've created a small homepage for the online database here:
http://fvonline-db.bplaced.net/
Now it lists the date of the last update and download links for the most interesting languages.
Hope it helps!
nalor is offline   Reply With Quote
Old 12th January 2019, 01:01   #383  |  Link
Aperson
Originally Posted by MasterMeNL View Post
During part one there is the "Get basic AACS data" step. It prints out "AACS folder on disc is reachable - ValidateVUK is possible" and then the entire drive freezes. I have a 2011 SH-B123L. I noted that trying to copy MKB_RO.inf or MKB_RW.inf manually from the AACS folder causes the drive to lock up completely too, requiring Windows 10 to reboot. When running Linux on the same hardware copying these files works fine, but of course FindVUK does not work there. I have tried setting PauseBeforeValidateVUK to 1 but this did not change anything.
DVDFab itself can rip properly without locking up the drive, so I suspect the validation is causing issues. Could you add an option to disable/skip validation even if the AACS folder exists? Or is there something else I could try?
This sounds like the same issue I encountered when attempting to use FindVUK in a VMWare or QEMU VM with SCSI drive passthrough, I have not found a workaround, but I do know that DVDFab works because it does raw SCSI commands to the drive rather than accessing the filesystem. I don't remember fully, but I think that drive passthrough with a VirtualBox VM on a Linux host might've worked,
Aperson is offline   Reply With Quote
Old 12th January 2019, 01:02   #384  |  Link
nalor
Can you simply execute the 'FindVUK - ShowDriveDetailsForAllDrives' batch file inside qemu-windows and send me the result? I will simply add an exception for the qemu virtual drive - just need the details of it.
There's already such an exception for the virtualbox drive in the code as this is the one I've been using in the past and that I've tried with FindVUK.
Thanks!
Old 12th January 2019, 11:39   #385  |  Link
Mr Wolf
Mr Wolf's Avatar
If it can be any help, I'm using FindVUK and DVDFab in a Windows 7 VMware Workstation virtual machine (in a Windows 7 host).
This is my configuration:
I never had any issue accessing the blu-ray drive within the virtual machine.
Mr Wolf is offline   Reply With Quote
Old 12th January 2019, 15:14   #386  |  Link
MasterMeNL
Thanks!
Here are the details for the emulated QEMU drive:
2019-01-12 14:55:43 # 4 # [I] main / Drive_GetAllDetails(legacy) / Check drive features for drive >E<
2019-01-12 14:55:43 # 90 # [I] main / Drive_GetAllDetails(legacy) / Vendor >< ProductId >QEMU QEMU DVD-ROM< ProductRevision >2.5+< ScsiDeviceType >CD/DVD-ROM device< ConnectedTo >Atapi< Bus
2019-01-12 14:55:44 # 171 # [I] main / Drive_GetAllDetails(legacy) / Device has wrong mediatype - it is a >CD-ROM< but we need a DVD MediaType
As a side note, Wine does not implement this specific way of querying, the output of the showdrivedetails command under Wine 4.0-rc4 is:
0009:fixme:ntdll:server_ioctl_file Unsupported ioctl 2d1400 (device=2d access=0 func=500 method=0)
14:57:32 - Cannot enumerate storage device - stop getting drive details for this drive
I think it would be interesting to test this further as this is likely the only reason it currently does not work under Wine. For this there needs be a way to bypass the drive check completely as it will currently error under Wine. Alternatively autodetection of Wine is possible through the wine_get_version symbol in ntdll as described in https://www.winehq.org/pipermail/win...er/069387.html. What might be easier for a quick test is to assume the drive works if an error occurs during enumeration of the storage device instead of bailing out.
Thank you!
Old 23rd January 2019, 19:43   #387  |  Link
nalor
I've added the QEMU drive to the list of special drives - but my interest to support Wine is really low.
Since the first release nobody ever asked about wine and there are other alternatives to use FindVUK under linux, so I don't think it's necessary to specially support wine.
But QEMU support is included in the upcoming release
Old 25th January 2019, 08:06   #388  |  Link
legluondunet
As a Linux user too, I will be very interesting to use FindVuk on Linux with Wine.
But the main issue is that DVDFab 11.x version does not launch with Wine.
For the moment I installed Windows 7 on Virtualbox and I can use Findvuk with DVDFab last version.
This soluce is less stable than a real Windows install, but it works.
But I don't understand why I have to "hack" the blu ray I BOUGHT to read them on Linux.
We are living in a strange world.
legluondunet is offline   Reply With Quote
Old 9th February 2019, 00:33   #389  |  Link
nalor
Released 1.23 - includes a few small fixes/enhancements.
Old 17th February 2019, 14:11   #390  |  Link
nalor
Released 1.24 - fixed the problem that passkey got killed unfriendly every time ...
Old 24th February 2019, 05:57   #391  |  Link
EncryptedEggs
Hmm, my passkey trail has expired and I find that I get "no aacs key found" for the regular 1080p Bluray that comes with the 4K UHD Big Lebowski bluray. I see that the keys file does have the aacs key for the UHD disc, so presumably a FindVUK user does own this release. Would that person mind getting the key for the regular 1080p Bluray that comes with the UHD? Would be appreciate.
EncryptedEggs is offline   Reply With Quote
Old 24th February 2019, 11:23   #392  |  Link
Mr Wolf
Mr Wolf's Avatar
I have "The Big Lebowski" blu-ray and it plays with VLC, but I guess the key doesn't work with you because it's region 2. You don't use VLC to play blu-rays? Otherwise, you can get the key using FindVUK in combination with DVDFab.
Old 24th February 2019, 19:57   #393  |  Link
EncryptedEggs
Ah, yes, mine is Region A. I use VLC to play blu-rays. Unfortunately, my DVDFab Passkey trail expired so I'm dead there. Or can I get a new trial using a different one of their products?
Old 24th February 2019, 20:21   #394  |  Link
nalor
Hi!
Added 2 different statistic pages to the FindvukOnlineDatabase website.
The first page shows the evolution of the entries in the database - from the beginning until now.
DatabaseStatistics
The 2nd page shows the number of downloads per day:
DownloadStatistics
And just to be clear: the only kind of information stored when someone downloads is: time of download and requested language - nothing else! no ip addresse, no nothing...
Old 24th February 2019, 20:45   #395  |  Link
Mr Wolf
Mr Wolf's Avatar
Uh, I was talking about the free software:
https://it.dvdfab.cn/hd-decrypter.htm
I've always used that to get blu-ray keys with FindVUK and it has always worked like a charm.
Old 24th February 2019, 21:20   #396  |  Link
EncryptedEggs
Ok, I had been using the Passkey Lite trial. I downloaded what you linked but am not sure how to use with FindVUK. Where do I go from this: pic.
Old 25th February 2019, 10:16   #397  |  Link
Mr Wolf
Mr Wolf's Avatar
You should start FindVUK, and then FindVUK should start DVDFab to extract the key. The process is quite straightforward and automatic.
Old 22nd March 2019, 15:20   #398  |  Link
LM2005
1/2 Off topic sorry. I am watching 2k Blu rays with VLC and everything works fine (usually). But what about 4k disks. I don't have 4k drive nor display yet but getting better picture is one reason more to get them.
LM2005 is offline   Reply With Quote
Old 11th April 2019, 01:30   #399  |  Link
EncryptedEggs
My Region A Blade Runner The Final Cut doesn't seem to find a key (though I do see entries in the db that say BLADERUNNER_FINAL) and my DvdFab Passkey trial expired. If anyone can get the key for this disc thanks.
Old 13th April 2019, 20:58   #400  |  Link
Cilalulin
I get an error when trying to use FindVUK for my "Her" Blu-Ray:
I have splitted the log in half because of the character limit for each post.
Part 1:
2019-04-13 19:44:08 # 0 # [I] main / (legacy) / #############################################################################
2019-04-13 19:44:08 # 0 # [I] main / (legacy) /  ----------- FindVUK 1.24 -----------
2019-04-13 19:44:08 # 0 # [I] main / (legacy) / Operating System: Windows 7
2019-04-13 19:44:08 # 1 # [I] main / Settings_GetFilename(legacy) / SettingsFile: >F:\BluRay\Tools\FindVUK_1.24\config\FindVUK.ini<
2019-04-13 19:44:10 # 1246 # [I] main / ConsoleBufferSize(legacy) / Current BufferSize 80 x 300 - ScreenSize 80 x 25
2019-04-13 19:44:10 # 1246 # [I] main / ConsoleBufferSize(legacy) / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2019-04-13 19:44:10 # 1246 # [I] main / ConsoleBufferSize(legacy) / Max. ScreenSize 240 x 87
2019-04-13 19:44:10 # 1246 # [I] main / ConsoleBufferSize(legacy) / Final New Values - BufferSize 120 x 300 - ScreenSize 120 x 50 - Resize >1<
2019-04-13 19:44:10 # 1246 # [I] main / ConsoleBufferSize(legacy) / M1 - New BufferSize 120 x 300
2019-04-13 19:44:10 # 1247 # [I] main / ConsoleBufferSize(legacy) / Mx2 - New ScreenSize 120 x 50
2019-04-13 19:44:10 # 1331 # [I] main / BlurayMeta_CheckLanguage(legacy) / Please check if the following language is correct.
2019-04-13 19:44:11 # 2475 # [I] main / (legacy) / Open Main-KEYDB file: >C:\Users\Christoph\AppData\Roaming\aacs\KEYDB.cfg<
2019-04-13 19:44:11 # 2476 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\Christoph\AppData\Roaming\aacs\KEYDB.cfg< opened!
2019-04-13 19:44:11 # 2495 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\Christoph\AppData\Roaming\aacs\KEYDB.cfg< in memory now
2019-04-13 19:44:12 # 4066 # [I] bluray_keydb / _ParseMem / Removed duplicates for >0< discids from file >C:\Users\Christoph\AppData\Roaming\aacs\KEYDB.cfg<
2019-04-13 19:44:12 # 4066 # [I] main / (legacy) / Open Backup-KEYDB file: >F:\BluRay\Tools\FindVUK_1.24\VUKbackup\KEYDB.cfg<
2019-04-13 19:44:12 # 4067 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >F:\BluRay\Tools\FindVUK_1.24\VUKbackup\KEYDB.cfg< opened!
2019-04-13 19:44:12 # 4067 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >F:\BluRay\Tools\FindVUK_1.24\VUKbackup\KEYDB.cfg< in memory now
2019-04-13 19:44:12 # 4067 # [I] bluray_keydb / _ParseMem / Removed duplicates for >0< discids from file >F:\BluRay\Tools\FindVUK_1.24\VUKbackup\KEYDB.cfg<
2019-04-13 19:44:12 # 4068 # [I] main / Settings_ReadDVDfabSettings(legacy) / Information! Passkey detected >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2019-04-13 19:44:12 # 4069 # [I] main / Settings_ReadDVDfabSettings(legacy) / Tested Passkey Version >9.3.4.1< found
2019-04-13 19:44:12 # 4069 # [I] main / Settings_ReadDVDfabSettings(legacy) /  >>> everything should work as expected!
2019-04-13 19:44:12 # 4071 # [I] main / Settings_ReadDVDfabSettings(legacy) / Information! No MediaPlayer detected!
2019-04-13 19:44:12 # 4071 # [I] main / Settings_ReadDVDfabSettings(legacy) / Information! No DVDfab detected!
2019-04-13 19:44:12 # 4071 # [I] main / FVMAIN_Mode_FindVUK_GetSettings(legacy) / Passkey is preferred and available!
2019-04-13 19:44:12 # 4071 # [I] main / FVMAIN_Mode_FindVUK_GetSettings(legacy) / Passkey-MainFile:     >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2019-04-13 19:44:12 # 4072 # [I] main / FVMAIN_Mode_FindVUK_GetSettings(legacy) / Passkey-LogFile:      >C:\Users\Christoph\Documents\DVDFab Passkey\Log\passkey_internal.log<
2019-04-13 19:44:12 # 4072 # [I] main / FVMAIN_Mode_FindVUK_GetSettings(legacy) / KEYDB-Path:           >C:\Users\Christoph\AppData\Roaming\aacs\<
2019-04-13 19:44:12 # 4072 # [I] main / FVMAIN_Mode_FindVUK_GetSettings(legacy) / KEYDB-Backup-Path:    >F:\BluRay\Tools\FindVUK_1.24\VUKbackup\<
2019-04-13 19:44:12 # 4072 # [I] main / ProcDump_CheckAvailability(legacy) / ProcDump is not available right now at >F:\BluRay\Tools\FindVUK_1.24\tool\procdump64.exe<
2019-04-13 19:44:12 # 4072 # [I] main / ProcDump_CheckAvailability(legacy) /  >>> download a fresh copy now from >http://live.sysinternals.com/procdump64.exe<
2019-04-13 19:44:12 # 4073 # [I] main / DownloadFile(legacy) / Downloading ProcDump - Progress: 0 bytes
2019-04-13 19:44:13 # 4573 # [I] main / DownloadFile(legacy) / Downloading ProcDump - Progress: 0 bytes
2019-04-13 19:44:13 # 5073 # [I] main / DownloadFile(legacy) / Downloading ProcDump - Progress: 0 bytes
2019-04-13 19:44:14 # 5574 # [I] main / DownloadFile(legacy) / Downloading ProcDump - Progress: 48877 bytes
2019-04-13 19:44:14 # 6074 # [I] main / DownloadFile(legacy) / Downloading ProcDump - Progress: 48877 bytes
2019-04-13 19:44:15 # 6574 # [I] main / DownloadFile(legacy) / Downloading ProcDump - Progress: 196333 bytes
2019-04-13 19:44:15 # 7074 # [I] main / DownloadFile(legacy) / Finished download of ProcDump - received 341672 bytes
2019-04-13 19:44:15 # 7075 # [I] main / ProcDump_CheckAvailability(legacy) / Download complete
2019-04-13 19:44:15 # 7075 # [I] main / FVMAIN_Mode_FindVUK_GetSettings(legacy) / ProcDumpFile:         >F:\BluRay\Tools\FindVUK_1.24\tool\procdump64.exe<
2019-04-13 19:44:15 # 7076 # [I] main / FVMAIN_Mode_FindVUK_GetDump(legacy) /  --- PART 1 --- GET DUMP ---
2019-04-13 19:44:15 # 7081 # [I] main / FVMAIN_Mode_FindVUK_GetDump(legacy) / No running application process discovered
2019-04-13 19:44:15 # 7081 # [I] main / FVMAIN_Mode_FindVUK_GetDump(legacy) /  >> Start it now >C:\Program Files (x86)\DVDFab Passkey\DVDFabPasskey.exe<
2019-04-13 19:44:19 # 11101 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1171< NewLineCnt >1175<
2019-04-13 19:44:19 # 11101 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1171< Content ><
2019-04-13 19:44:19 # 11101 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1172< Content ><
2019-04-13 19:44:19 # 11101 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1173< Content >DVDFabPasskey 9.3.4.1 (2019/04/13 19:44:19)<
2019-04-13 19:44:19 # 11101 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1174< Content ><
2019-04-13 19:44:19 # 11101 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1175< Content >(empty)<
2019-04-13 19:44:35 # 26305 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1175< NewLineCnt >1177<
2019-04-13 19:44:35 # 26305 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1175< Content > 0m 18.12s: Drive E add. <
2019-04-13 19:44:35 # 26305 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1176< Content > 0m 18.12s: Drive G add. <
2019-04-13 19:44:35 # 26305 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1177< Content >(empty)<
2019-04-13 19:44:35 # 26405 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1177< NewLineCnt >1184<
2019-04-13 19:44:35 # 26405 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1177< Content > 0m 18.14s: Drive G media add. <
2019-04-13 19:44:35 # 26405 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1178< Content > 0m 18.14s: opened i/o type 1 <
2019-04-13 19:44:35 # 26406 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1179< Content > 0m 18.14s: opening drive G<
2019-04-13 19:44:35 # 26406 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1180< Content > 0m 18.14s: opened i/o<
2019-04-13 19:44:35 # 26406 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1181< Content > 0m 18.14s: currentProfile: 64<
2019-04-13 19:44:35 # 26406 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1182< Content > 0m 18.14s: got media type 15<
2019-04-13 19:44:35 # 26406 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1183< Content > 0m 18.14s: got max lba 17655647<
2019-04-13 19:44:35 # 26406 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1184< Content >(empty)<
2019-04-13 19:44:38 # 30106 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1184< NewLineCnt >1187<
2019-04-13 19:44:38 # 30106 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1184< Content > 0m 21.93s: got disc type 20<
2019-04-13 19:44:38 # 30107 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1185< Content > 0m 21.93s: type Blu-ray BDMV<
2019-04-13 19:44:38 # 30108 # [I] main / DVDfab_WatchLog_Standard(legacy) / Drive opened
2019-04-13 19:44:38 # 30108 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1186< Content > 0m 21.93s: volume label HER<
2019-04-13 19:44:38 # 30108 # [I] main / DVDfab_WatchLog_Standard(legacy) / Volume Label detected >HER<
2019-04-13 19:44:38 # 30108 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1187< Content >(empty)<
2019-04-13 19:44:38 # 30116 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1187< NewLineCnt >1188<
2019-04-13 19:44:38 # 30116 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1187< Content > 0m 21.94s: bd set region ?<
2019-04-13 19:44:38 # 30116 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1188< Content >(empty)<
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1188< NewLineCnt >1193<
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1188< Content > 0m 25.67s: opened i/o type 1 <
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1189< Content > 0m 25.67s: opening drive G<
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1190< Content > 0m 25.67s: opened i/o<
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1191< Content > 0m 25.68s: currentProfile: 64<
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1192< Content > 0m 25.68s: got max lba 17655647<
2019-04-13 19:44:42 # 33918 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1193< Content >(empty)<
2019-04-13 19:44:44 # 35319 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1193< NewLineCnt >1197<
2019-04-13 19:44:44 # 35319 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1193< Content > 0m 27.13s: got disc type 20<
2019-04-13 19:44:44 # 35319 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1194< Content > 0m 27.13s: internal path G:/BDMV/<
2019-04-13 19:44:44 # 35320 # [I] main / DVDfab_WatchLog_Standard(legacy) / DriveLetter detected >G<
2019-04-13 19:44:44 # 35320 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1195< Content > 0m 27.13s: aacs 1 bd+ 0<
2019-04-13 19:44:44 # 35321 # [I] main / DVDfab_WatchLog_Standard(legacy) / Detected CopyProtections AACS >1< BD+ >0<
2019-04-13 19:44:44 # 35321 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1196< Content > 0m 27.13s: read index.bdmv begin<
2019-04-13 19:44:44 # 35321 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1197< Content >(empty)<
2019-04-13 19:44:44 # 35721 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1197< NewLineCnt >1198<
2019-04-13 19:44:44 # 35721 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1197< Content > 0m 27.52s: got bdmv<
2019-04-13 19:44:44 # 35721 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1198< Content >(empty)<
2019-04-13 19:44:44 # 35921 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1198< NewLineCnt >1199<
2019-04-13 19:44:44 # 35921 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1198< Content > 0m 27.72s: blu-ray 5B1F6A3A61431523976B41B3402D247BC437CB55<
2019-04-13 19:44:44 # 35922 # [I] main / DVDfab_WatchLog_Standard(legacy) / DiscID found >5B1F6A3A61431523976B41B3402D247BC437CB55<
2019-04-13 19:44:44 # 35922 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1199< Content >(empty)<
2019-04-13 19:44:45 # 36521 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1199< NewLineCnt >1201<
2019-04-13 19:44:45 # 36522 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1199< Content > 0m 28.31s: cert BEE=0x00 same<
2019-04-13 19:44:45 # 36522 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1200< Content > 0m 28.31s: got agid 3<
2019-04-13 19:44:45 # 36522 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1201< Content >(empty)<
2019-04-13 19:44:45 # 36621 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1201< NewLineCnt >1205<
2019-04-13 19:44:45 # 36622 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1201< Content > 0m 28.39s: sent host cert chal<
2019-04-13 19:44:45 # 36622 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1202< Content > 0m 28.39s: got drive cert chal<
2019-04-13 19:44:45 # 36622 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1203< Content > 0m 28.39s: BEC 1<
2019-04-13 19:44:45 # 36622 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1204< Content > 0m 28.39s: DRIVE_VENDOR 0x0001<
2019-04-13 19:44:45 # 36622 # [I] main / DVDfab_WatchLog_Standard(legacy) / New Line >1205< Content >(empty)<
2019-04-13 19:44:45 # 36722 # [I] main / DVDfab_WatchLog_Standard(legacy) / Filechange detected! OldLineCnt >1205< NewLineCnt >1209<
I am using the lite version of DVDFab Passkey.
Do you want/need more information?
Cilalulin is offline   Reply With Quote
