17th January 2009, 22:16 | #381 | Link |
Does it mean that multiAVCHD already support this functionality?
As I tried a BDMW structure with some files greater than 4 GB the copy process of multiAVCHD stopped with an error message. M2TS split on TsMuxer tab is defined with 3999. Is there another option which must be activated? Regards. M. |
17th January 2009, 23:07 | #382 | Link | |
I recomend use 10000 (10GB).. |
17th January 2009, 23:22 | #383 | Link |
I deank,
I think that you have a problem with movies with resolutions of 1280x536, 1280x544 and 1280x534, i.e., movies with maximum vertical resolution of 576p. You detect that the best output will be a 576p film and that results on playing the movies not in HD but in SD. I'm having this problem with my PS3 connected to a Sony FullHD LCD. I think that you should force a HD resolution of 720p or 1080p and not having the ability of choosing SD resolutions. |
18th January 2009, 00:47 | #384 | Link | |
Programmer (or just 教务长)
18th January 2009, 00:48 | #385 | Link | |
And, NO, I personally don't have "problems" with movies... with ANY movie. Last edited by deank; 18th January 2009 at 01:08. |
18th January 2009, 01:08 | #386 | Link |
Hi Deank,
Now all is going smoth - 3 source .ts files = 3 titles in the film. But no menu titles - only the initial screen with MULTIAVHCD. Any button pressed gives no action. I have to call Title search menu and put manually the title number I need. Built 201, authoring options are Create top menu, Light / static menu and all three options in the right column are checked, others are not. Why? |
18th January 2009, 01:14 | #387 | Link |
I don't know why. I tested on PAL PS3 and it works with FULL-PAL download - also with LITE-PAL download. Check what video-system you selected in drop down menu in Authoring.
If nothing helps - just use the former versions menu - check [x] Show non-existent titles in the same authoring tab. I'd suggest you DELETE your MULTIAVCHD folder and download PALFULL again. |
18th January 2009, 11:41 | #388 | Link | |
18th January 2009, 11:44 | #389 | Link |
I suggested to use
[x] Show non-existent titles Check it and try again. It will be easier to test with USB instead of burning disk. Also try with PAL/NTSC in drop-down, or delete _MENUSTR\00002.litePAL1, 2, 3, 4 and 5. Somewhere in the LOG tab you should see: [12:49:42] Preparing authoring information... [12:49:42] Copying 1 sec blank video data. [12:49:42] Creating static/lite top PAL menu. [12:49:42] Trying to download 00002.litePAL1... [12:49:47] Proper lite menu Page #1 downloaded! [12:49:47] Setting menu for 1 titles... Last edited by deank; 18th January 2009 at 11:52. |
18th January 2009, 12:27 | #391 | Link |
OK, re downloaded the complete PAL package (previously had NTSC I think) and deleted the full multiAVCHD folder and re-created it with latest download. Added the 3 titles and de-selected Show non-existent titles. Created a multiBD, burnt with ImgBurn and still have the same issue (stuck on intro screen).
Running same test now with [x] Show non-existent titles so will report back when complete. Edit: [x] Show non-existent titles worked..... Last edited by rendez2k; 18th January 2009 at 12:56. |
18th January 2009, 13:12 | #396 | Link |
Also, since update I've started occasionally getting this error. Restarting multiAVCHD appears to fix:
http://i68.photobucket.com/albums/i3...multierror.jpg |
18th January 2009, 13:41 | #397 | Link | |
deank, i'm getting the menu error too on the last build. I get the menu and no options and the PS3 wont play anything beyond the menu. I'm trying now with "skip menu" option to see what it does. Last edited by Glorioso; 18th January 2009 at 13:46. |
18th January 2009, 15:42 | #398 | Link | |
18th January 2009, 15:45 | #399 | Link | |
I hope I'll be able to fix the issue with multiBD output. |
