16th March 2012, 15:31 | #12781 | Link | |||
At least now, its not completely swallowed. Before the fix, when I try ctrl + J to open Google Chrome/Firefox download tab, it won't open. Only trigger madVR shortcut. Currently, the download tabs does open, but it also trigger madVR shortcut at the same time. |
16th March 2012, 16:26 | #12782 | Link |
Hey madshi, do you think the "queue output samples" in ffdshow would have an impact on madvr's performance? I remember the feature has been in there for a long time. I disabled it recently just in case.
17th March 2012, 11:38 | #12785 | Link |
I use a passively cooled GT 430. I found two models but only one was available at UK online retailers so my choice was rather limited. Be prepared to spend up to 50% more than you would for an actively cooled one.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
17th March 2012, 13:53 | #12787 | Link |
@madshi
Is it possible to make a madvr where you leave the whole scaling part on the shaders away and leave that to the hardware but keep the rest ? For Intel user that would be much much more efficient i guess having not the massive GPU overhead from the Shader Scaling part Especially on the less powerful Intel HD Graphics GT1 and leaving the scaling to the Driver and Egurs Hardware Asic Lanczos4 (Luma/Chroma) implementation
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 17th March 2012 at 14:00. |
17th March 2012, 14:31 | #12788 | Link |
madshi
When I try to switch Film-> Video (23hz -> 59 hz) using Cntrl+Alt+Sh+T I get red message resetting Direct3D device failed (8876086c). Log and freeze report: http://dl.dropbox.com/u/43376972/LOG%20MADVR.zip Thanks! |
17th March 2012, 16:16 | #12789 | Link |
madshi
For this sample (PAL DVD film in 50i container) http://dl.dropbox.com/u/43376972/Pal...nter%20OFF.mkv Settings: force film mode if in doubt, activate deinterlacing, but OSD says that deinter is off ! So deinterlacing is not on automatically? |
17th March 2012, 16:33 | #12791 | Link | |
Your stream is probably fully progressive. |
17th March 2012, 17:46 | #12793 | Link | |
But have a look at this sample http://dl.dropbox.com/u/43376972/SD%20%281%29-001.mkv (NTSC DVD film). Mediainfo says that video in this sample is Scan type: progressive but Madvr switches Deinterlacing on (IVTC in film mode). |
17th March 2012, 17:52 | #12794 | Link | |
I suppose madVR turns itself into IVTC mode under the assumption that the soft-telecine may not be consistent, and eventually end up mixed with hard-telecine.
17th March 2012, 19:29 | #12795 | Link | |
17th March 2012, 20:17 | #12797 | Link | |
17th March 2012, 20:33 | #12798 | Link | |
Right after boot-up I launched MPC/MadVR : this way the dbghelp from the Madvr dir became loaded. If I launch Process explorer then, I think that Windows will not load the dbghelp from the OS but rather use the one that's already in memory. |
17th March 2012, 20:54 | #12799 | Link |
Is NV12 superior to YV12? I noticed that LAV Video send NV12 to madVR instead of YV12. I remember madshi saying that they're basically equivalent but NV12's precedence over YV12 with LAV is a little different from what ffdshow normally does.
17th March 2012, 21:04 | #12800 | Link | |
They contain the exact same information, but basically all GPUs don't natively handle YV12, they prefer NV12. Difference to ffdshow? Sure, i do it the right way, not the ffdshow way. I'm tired of those comparisons.
