8th December 2004, 16:13 | #441 | Link |
Just a Member
OK.
You need to find the starting and ending sector of the Cells. Due they are Menu Cells, you will find the info (using IFOEdit) in VMGM_C_ADT table (if VIDEO_TS.VOB) or in VTSM_C_ADT (if VTS_XX_0.VOB). So, locate your Cell in the table (using CellID and VObId), and write down the starting/ending sectors. Because they are blank cells the total number of sectors should be 5 , let's say endsector=inisector+4; Now, you can "jump" (there is a button in the bottom-left) in VobEdit to the ini sector. The inisector MUST be a Nav pack. Click on the pack (inn the left side of Vobedit) and in the right side you will see the pack contents, where you will find the addresses I've referenced in my previous post To cut the cell, just write in Cutfile the values inisector (Initial block) and endsector (End block), keeping the block size of 2048 (default). Press OK and you're done. The output file should be a 10 KB one. Please zip the cells and the IFOs and send them to me. jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
8th December 2004, 18:20 | #443 | Link |
Just a Member
8th December 2004, 20:44 | #444 | Link |
reMember
The start and end sector values in IfoEdit are in hex.
Are the sector (block) values in CutFile also in hex or are they in decimal? EDIT: Oops, didn't see at first that IfoEdit has BOTH the decimal AND hex values...! I got it now. Expect a pm with the files in a few minutes, jsoto! Last edited by CoNS; 8th December 2004 at 21:02. |
8th December 2004, 22:54 | #445 | Link |
Just a Member
Thanks, I've got them.
At first view I was unable to see a reason... But, I've found a possibility. Second Cell in root menu is marked as STC discontinuity in PGCEdit IFOs, but not in VobBlanker ones Did you do a IFOEdit mock strip on menus in PGCEdit files? I believe a IFOEdit's mock strip fixes this... Or... may be PgcEdit changes this bit in the PGC when blanking out a cell? @r0lZ, could you confirm this? VobBlanker is not doing that, and I believe we can consider this is as bug. So, please change the cell type in IFOEdit from 8 to 10 and try again. (You have to burn a new media, I hope your settop is able to read DVD+-RW) jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ Last edited by jsoto; 1st January 2005 at 23:57. |
8th December 2004, 23:10 | #446 | Link |
reMember
Yep, changing it from 8 to 10 makes it work!! (seems the same upon playback as when fixed with PgcEdit)
Good job! (and no, I haven't anywhere in the process done a mock strip of the menu PGC in IfoEdit. That goes for the version fixed with PgcEdit, too) Should the cell type only be changed from 8 to 10 in the following cell (cell 2/3)? How about cell no. 3/3, which also is marked as cell type 8? |
8th December 2004, 23:11 | #447 | Link | |
PgcEdit daemon
BTW, your 'reordering' method when writing VOBs may cause the same problem, when some cells are reused. Note: This flag is called SCR Discontinuity by Mpucoder (and me), and STC discontinuity by Derrow. Who is right?
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 8th December 2004 at 23:22. |
8th December 2004, 23:23 | #448 | Link | |
Just a Member
I'm thinking in the "logical" problem. We have blanked out a 26 seconds cell, so the system clock has to be resynchronized. Probably the settop is waiting until SCR or PTS gets the value indicated in the second (not blanked) cell jsoto
8th December 2004, 23:26 | #449 | Link |
Just a Member
@r0lZ
About your note... What does the flag mean? A discontinuity in SCR (System clock) A discontinuity in Presentation Time (PTS) ? Probably the discontinuities are always togheter... jsoto
8th December 2004, 23:37 | #451 | Link |
Just a Member
Sorry CoNS, for any reason, I didn't see your post. Great to know we found it!
The conclusion is clear: There is a bug (omission ) in VobBlanker. I've to modify the Cell type in the own cell (it is discontinous with the previous) and in following one when blanking/replacing cells (and also when cutting PGCs in the middle of a Cell, may be I'll solve some problems in this way) jsoto
9th December 2004, 02:42 | #452 | Link |
Country Member
@jsoto
Can this SCR issue be at all related to the issues I have been having when cutting PGCs? BTW: How does this flag work. I see PGCs with different values here for each cell (soemtimes 8, others 2 and others 10) and no idea what they all do (although pgcedit has an explanation of the bit settings). Can anybody explain? Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 9th December 2004 at 05:10. |
1st April 2005, 02:12 | #453 | Link | |
Posts: n/a
Now torn between scrapping this editing (as I'm only skipping warnings etc) and just back it up without any editing (just small amount of shrinking). ......As I type this it just finished. So this goes down as the longest PGCEdit I've ever done - about 14 hours start to finish. |
1st April 2005, 03:25 | #454 | Link |
PgcEdit daemon
Hum! I'm not proud!
But take in mind that PgcEdit is written in an interpreted language, without pointers and the like. It's difficult to speed it up. However, I wonder why it is so slow to save the DVD. Maybe I'll found a way to shorten the save duration... Another thing I may try in the future is to buy Tcl/Tk Pro package. It's a little bit expensive, but it has a bytecode compiler, a profiler, and some other useful tools. I just need some more donations...
14th January 2006, 16:42 | #456 | Link |
PgcEdit daemon
Yet another "IFO file too big" issue: http://forum.doom9.org/showthread.php?t=105580
16th January 2006, 20:29 | #458 | Link | |
Just a Member
Copy protection methods are always oriented to protect main movie, because there are many many people happy with movie-only backups, and the main movie is the content to be protected.. jsoto
