19th January 2010, 10:01 | #10362 | Link |
Do you mean in terms of MPC and FFDShow or via PDVD 9 Ultra.
Anyway that doesn't really matter as I can't see any reason why it would cause any problems, it uses the same audio chip across the whole HD5xxx series right upto the HD5970. |
19th January 2010, 10:05 | #10363 | Link |
Didée Fan
the ffmpegmt won't compile in the 3027 trunk build. I worked once then I couldn't get it to compile again.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. |
19th January 2010, 11:56 | #10366 | Link |
MPC-BE DEV
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
19th January 2010, 12:16 | #10367 | Link |
Just picked up a 5670 and wondering what I need to make bitstreaming dd, dts, dts-ma and true-hd:
- 9.12, 9.12 hotfix or 10.1 beta? - Realtek driver or not? - mpc-hc: select 'MPC audio renderer as output'? - latest ffdshow with all bitstream boxes checked? Anything else in ffdshow that needs to be selected or changed? I use W7 |
19th January 2010, 12:43 | #10368 | Link |
Most of us are using 9.12 hotfix w/Realtek 2.39 HDMI driver. The ATI-provided driver has the silent stream issue, and also the Realtek driver works with 32-bit output with ReClock and WASAPI exclusive, the ATI driver only does 16-bit. I don't see any upside to the ATI driver.
The Default DirectSound renderer works fine, or the ATI HDMI output also works. MPC audio renderer does exclusive mode, and last I tried (MPC-HC 1489 I believe) you had to disable audio switcher, which then doesn't let you switch audio tracks. Everything else works at default too, but just in case make sure you have mpeg PS/TS/PVA in the internal filters checked. Ffdshow needs you to select the bitstream boxes, I don't think anything else has to be done. BTW the audio discussion specific to this was branched off to here. |
19th January 2010, 15:47 | #10369 | Link | |
We use an old mt patch for slices in our normal libavcodec. That got broken due to the updates. At first it crashed, after the fix by Michael you mentioned, it no longer crashes, but there still are some decoding problems.
MPC-HC 2.2.1 |
19th January 2010, 19:55 | #10370 | Link |
To follow up on yadif not doubling frame rate. None of the ffdshow de-interlacers that can double frame rate now do. The frame rate doesn't change even though visually it does look de-interlaced, its just the same frame rate.
19th January 2010, 20:31 | #10372 | Link | |
Any chance someone will provide some benchmarks in comparison to existing solutions (i.e. software decoding, dxva, CUDA) for various files/systems? I'm just curious as to the results. I'm a little surprised the DXVA with Overlay used 3x as much CPU as regular DXVA but it's hard to judge without that overall context and baseline measurements. Last edited by rsd78; 19th January 2010 at 20:36. |
19th January 2010, 22:18 | #10375 | Link |
Anime Otaku
Revision 3207 introduced a bug on the DVD navigation, menu options no longer highlight on mouse over. Revision 3204 works fine.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
19th January 2010, 23:01 | #10377 | Link |
DXVA Post Processing - Beta 2
Beta 2 improves overlay mode visibility, and also adds Blend mode,
I'm not really sure if blend mode is very useful, because those read operations are very resource-hungry. [full-processing-mode seems less and less practical, it's not fully implemented in this beta (and the previous one)] build http://iknowu.net/files/public/ffdsh...sing-Beta2.exe patches http://iknowu.net/files/public/ffdsh...ng-Beta2.patch http://iknowu.net/files/public/ffdsh...edSample.patch Regards, Tal |
19th January 2010, 23:19 | #10378 | Link | |
Media Control author
For now we are stuck on a serious problem : the copy from the GPU to system memory take too much time (80ms for one 720p frame), more time than it should according to intel's article. Multithreading the copy did worse (120ms) Even if we do the copies in parallel, the copy time will most likely exceed the playback time. Anyway I will give it a shot. So for now full postprocessing with DXVA decoding consumes more than full software decoding and processing. As Tal pointed out, there is something that we should have missed I don't understand why it would take so much time |
20th January 2010, 00:53 | #10379 | Link | |
Does anyone know somewhere I can get build 3205 and 3206, and how to contact either tal_aloni or drevil_xxl, as they are the people who made changes in these builds. Revision 3207 - Directory Listing Modified Mon Jan 18 14:41:19 2010 UTC (33 hours ago) by drevil_xxl minor fix Revision 3206 - Directory Listing Modified Sun Jan 17 22:16:10 2010 UTC (2 days, 1 hour ago) by tal_aloni bugfix related to rev. 3105 Revision 3205 - Directory Listing Modified Sun Jan 17 20:17:30 2010 UTC (2 days, 3 hours ago) by tal_aloni Internal: separation between video sample processing and sample delivery. (it's now possible to process video sample without delivering it) I suspect 3205 or 3206 work by tal_aloni on deinterlacing related files will be the cause of the bug. |
20th January 2010, 02:00 | #10380 | Link |
Check the link in my signature for r3206. r3205 caused a blank video screen for me so I didn't uploaded. (I actually reported this to tal.aloni via IRC and he committed r3206 which fixed the problem).
