27th May 2010, 20:41 | #3225 | Link | |
Rack04 : Big problem with your x64 1613M version. I have the program wich brutaly crash/stop without any kind of error message after encoding 30 frames of the 1rst pass (video is 1280x720 23.976fps)...
Commande line used : Quote:
28th May 2010, 09:40 | #3229 | Link |
User of free A/V tools
You've only fixed _x86 part. <komisar> is still mentioned at _x64 part.
I think it would be easier for you and also for the readers to join that descriptive links to patches. Write them just once together with compilation settings used and post only separate download links to _x86 / _x64 builds underneath. Same suggestion to unpatched builds applies. It's redundant and likely error prone to write same information twice, no need for that. Last edited by kypec; 28th May 2010 at 09:44. |
28th May 2010, 16:01 | #3230 | Link | |
Silent Reader
--profile high --preset veryslow --tune film --slices 4 --level 4.0 --keyint 48 --min-keyint 2 --aq-mode 2 --b-pyramid strict --aud --nal-hrd vbr --open-gop --vbv-bufsize 31250 --vbv-maxrate 15000 --direct auto |
28th May 2010, 17:23 | #3233 | Link | |
30th May 2010, 07:02 | #3238 | Link |
I continue to have the same situation with first pass truncked after some minutes with only a "encode failed" and second pass that can't find the "stat file".
I've downloaded again from the Rack04 updated post the new build (with the open gop corrected patch), but same problem. I download the x86 without filters. Am i missing something? Thanks |
30th May 2010, 09:03 | #3239 | Link | |
Silent Reader
Does it even have open-gop-patch? it's not "Modified"! Maybe your 1st pass doesn't start because it can't recognize "--open-gop" command. |
2nd June 2010, 17:46 | #3240 | Link |
Toolchain:
x264 Builds:
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
