Old 24th April 2012, 02:38   #21  |  Link
moonwander
Thank you for your reply.
I uploaded a 2 seconds test video, it's already around 10MB:
http://members.shaw.ca/fs1/elph300hs.MOV
moonwander is offline   Reply With Quote
Old 24th April 2012, 02:50   #22  |  Link
moonwander
command line log:
ffmpeg.exe -y -i elph300hs.MOV -async 1 -vcodec copy -acodec libvo_aacenc -ac 2 -ab 192000 elph300hs.mp4
ffmpeg version N-39664-g6bfb304 Copyright (c) 2000-2012 the FFmpeg developers
built on Apr 9 2012 20:29:24 with gcc 4.6.3
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 46.100 / 51. 46.100
libavcodec 54. 14.101 / 54. 14.101
libavformat 54. 3.100 / 54. 3.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 67.101 / 2. 67.101
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 10.100 / 0. 10.100
libpostproc 52. 0.100 / 52. 0.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'elph300hs.MOV':
Metadata:
major_brand : qt
minor_version : 537331968
compatible_brands: qt CAEP
creation_time : 2012-04-24 01:30:11
Duration: 00:00:02.29, start: 0.000000, bitrate: 35886 kb/s
Stream #0:0(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuvj420p, 1920x1080, 34008 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 48k tbc
Metadata:
Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s16, 1536 kb/s
Metadata:
strptime() unavailable on this system, cannot convert the date string.
Output #0, mp4, to 'elph300hs.mp4':
Metadata:
major_brand : qt
encoder : Lavf54.3.100
Stream #0:0(eng): Video: h264 (![0][0][0] / 0x0021), yuvj420p, 1920x1080, q=2-31, 34008 kb/s, 23.98 fps, 24k tbn, 24k tbc
Metadata:
Stream #0:1(eng): Audio: aac (@[0][0][0] / 0x0040), 48000 Hz, 2 channels, s16, 192 kb/s
Metadata:
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (pcm_s16le -> libvo_aacenc)
Press [q] to stop, [?] for help
frame= 55 fps=0.0 q=-1.0 Lsize= 9580kB time=00:00:02.25 bitrate=34844.2kbits/s
video:9523kB audio:54kB global headers:0kB muxing overhead 0.025042%
Old 24th April 2012, 02:59   #23  |  Link
nm
I tried the latest 32-bit static build at http://ffmpeg.zeranoe.com/builds/
No problems playing your sample with VLC and MPlayer after the conversion.
Which player did you try?
Old 24th April 2012, 03:03   #24  |  Link
moonwander
You are fast!!
It plays on PC, original or converted. Problem is playing with Sony Bluray player, I think it's similar to OP's problem, he was playing with PS3.
The Bluray player can play video shot by Sony Nex-5N or Nikon AW-100, just can't handle the videos from Canon.
Old 24th April 2012, 03:38   #25  |  Link
nm
This is also something you could've mentioned right in the beginning...
As Audionut mentioned earlier in this thread, the H.264 streams in these Canon files are Level 5.0, which is probably why Sony's players don't like them. You could try cheating the player by changing the level flag to 4.1 with roozhou's modified ffmpeg. It's not guaranteed to work though.
Re-encoding is the way to go for better compatibility.
Old 24th April 2012, 05:07   #26  |  Link
moonwander
Thank you nm!
Re-encoding is too time consuming.
I tried to trick the level with -vbsf h264_changesps=level=30, ffmpeg complains...
ffmpeg.exe -y -i elph300hs.MOV -async 1 -vcodec copy -acodec libvo_aacenc -ac 2 -ab 192000 -vbsf h264_changesps=level=30 elph300hs_41.mp4
Metadata:
major_brand : qt
Metadata:
Metadata:
Unknown bitstream filter h264_changesps=level=30
Old 24th April 2012, 05:25   #27  |  Link
moonwander
ignore my previous post. The trick worked!
Have to download the hacked version of ffmpeg, then use it against the output of previous ffmpeg. It's still much faster than re-encoding! Thanks a lot!!!
canon, ps3, remux
