24th November 2011, 10:36 | #7262 | Link |
Most likely, yes.
There will be a delay on the first seek while it builds a index, but further seeks should be working just fine and fast.
24th November 2011, 10:45 | #7265 | Link | ||
I have a 1.6GB file without such an index, and it takes about 10 seconds on a relatively slow harddrive to build that index. If the file is say a 1080p Blu-ray rip of 20GB, it would i guess take around 2 minutes or so (or even less on better hardware) In general, you should rather remux those files to add an index instead. MKV sadly is not designed to seek without an index - so either you have one in the file, or you need to build one. This is still a great advantage over the situation now, because now it doesn't allow seeking at all. Quote:
It looks like Gabest MKV splitter always builds the index on opening, while Haali also builds it on demand (Hey, i'm using Haalis matroskaparser library afterall!) Such files are just not perfect. If anything, they should only result as intermediate files in a encoding process, your final file should always have a Cue index, otherwise the mux is just wrong.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th November 2011 at 11:03. |
24th November 2011, 10:55 | #7266 | Link |
my experience has been that with my incomplete files muxed with haali's muxer, there is a slight delay.
However, the seeking problems with mature files muxed with mkvmerge have also gone away, and there is no delay at all in that case, despite they're large size. |
24th November 2011, 10:59 | #7267 | Link | |
I agree, index is a must. I only use it for intermediate files/testing, so I can have a preview of the current x264 output, to decide whether I'm happy with the result or if I have to stop the encoding process. |
24th November 2011, 11:06 | #7268 | Link | |
ffmpegsource indexes the timestamp of every frame for frame-accurate seeking/editing, so it will be slower. I would suggest to wait and test before drawing any more conclusions. As an alternative to the index building i could implement a binary search seek, but that would mean seeking is never fast on such files, but there is no initial delay either. Not sure if thats better - but its surely alot of effort for files that are not really *that* common for normal users.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th November 2011 at 11:09. |
24th November 2011, 13:25 | #7269 | Link | |
http://www.team-mediaportal.com/exte...-handler-0-9-7 http://forum.team-mediaportal.com/me...-7-beta-81068/ Or Internal Bluray Menu on Mediaportal too : http://forum.team-mediaportal.com/ge...upport-102375/ Thanks
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
24th November 2011, 13:27 | #7270 | Link | |
Nice
24th November 2011, 14:02 | #7271 | Link |
Hello, I'm a new user of LAV and I have a question about bitstreaming.
My config: HTPC running Win7 64, soundcard; Realtek HD audio in motherboard, audio receiver and speakers: Logitech Z5500, cable: optical. I've been checking if AC3 audio is working on these speakers, and it works. Testing the file "Test AC3 v2.0.avi", my audio receiver displays "Dolby Digital" and the surround test works. One thing I do not understand is that in the LAV audio options, under "bitstreaming", wether "Dolby Digital (AC3)" is checked or not, the surround sound works, and the Audio receiver says it's "Dolby Digital". I thought that when it's not checked, LAV decodes the AC3 and in that case, the audio receiver would not receive any proper data? Thanks Gz |
24th November 2011, 16:52 | #7274 | Link | |
In any case, as long as you get audio and it sounds good, all is well!
24th November 2011, 19:14 | #7276 | Link |
Baby steps.
24th November 2011, 20:26 | #7278 | Link |
Since its the parser he wrote, i would assume its also used by his DirectShow filter.
