Old 9th November 2013, 12:04   #781  |  Link
andybkma
Simply omit the *MTMode() statements.
Thanks, I tried that which leaves me with this code:
SetMemoryMax(128)
ffdshow_source()
FineSharp()
or LSFMod()
But then I get error "Cache: Filter returned invalid response to CACHE_GETCHILD_CACHE_MODE.
If I replace the MT avisynth.dll back to the original (non-MT) one in the SysWow64 folder then all is fine with the above code. So something is not right with the above code with the MT version of avisynth.dll to make it run in non-MT...
andybkma is offline   Reply With Quote
Old 9th November 2013, 12:07   #782  |  Link
Groucho2004
Try with this version of Masktools.
Old 9th November 2013, 12:28   #783  |  Link
andybkma
Thank you kindly, that did it
Old 9th November 2013, 12:33   #784  |  Link
andybkma
Correct. SEt states that MTmode 3 should be used before ffdshow_source(), I do wonder if this is the cause of your problems.
What you could also do it dropping the SetMTMode(2) if it still causes issues, that way you're in mode 3 through the whole process except for the end.
If you have no joy with that then I'd try the other suggestions above (Soothe=false and Maxmem setting, maybe mode 5)
So you want to try this:
SetMemoryMax(512)
SetMTMode(3)
ffdshow_source()
SetMTMode(2)
FineSharp()
SetMTMode(1)
GetMTMode(false) > 0 ? distributor() : last
and
SetMemoryMax(512)
SetMTMode(3)
ffdshow_source()
FineSharp()
SetMTMode(1)
Thank you all for trying to help this noob to MTavisynth out. So lowering the SetMemoryMax to (128) from (512) seemed to have helped out my crashing ZoomPlayer at video start. So I went ahead and compared CPU usage and the rendering stats with mVR using the MT and the non-MT orig version and to be honest I don't see a bit of difference with either FineSharp() or LSFMod(). So am wondering if this MT avisynth version is for much heavier scripts than these two sharpeners or perhaps when combining multiple scripts?
Old 9th November 2013, 12:39   #785  |  Link
Groucho2004
Pretty much, yes. QTGMC() or some heavy de-noising functions do benefit from multi-threading.
If you want to experiment further, you might want to use this to test scripts.
Old 11th November 2013, 07:35   #786  |  Link
real.finder
about crashing, in the last version (2013.09.28), became occur randomly and without an appointment
and if it occurred, and after the re-run encoding again even without modifications, may work without crashing, or it occurred in other frame
that a side, for me, almost every filter work fine with mode 2, even Lsfmod
Old 29th November 2013, 17:41   #787  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Hi, actually I am getting random BSOD when encoding using Avisynt MT after updating operating system to windows blue. I have tried encoding without MT and system is stable. Excuse me but I'm not sure if it could be related. Would be it?
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 29th November 2013, 17:45   #788  |  Link
Boulder
Pig on the wing
Boulder's Avatar
You could try debugging the dump, but I would first try testing the system stability with stuff like Prime95 or LinX.
Old 29th November 2013, 20:10   #789  |  Link
SEt
User mode apps must not even have rights to crash your system. So anything but Avisynth is to blame here (drivers? OS? hardware?). It's quite trivial that without MT your system is more stable: because way less system resources are used.
As already suggested, test system stability with apps like LinX and Prime95. Heavy modern games are also good for load tests (if you are not extremely GPU-bound there).
SEt is offline   Reply With Quote
Old 29th November 2013, 20:38   #790  |  Link
Overdrive80
Anime addict
I have seen minidumps and are caused by different reasons. Here minidumps
I have tested system with LinX without BSOD.
I apologize because I dont want to turn the thread into offtopic but only happens to me if I run with MT.
EDIT: All drivers is updated.
Old 29th November 2013, 21:08   #791  |  Link
Groucho2004
LinX also doesn't produce BSODs.
Old 29th November 2013, 21:22   #792  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Did you give LinX the maximum amount of memory available? And you should also run it for several hours, I've seen it calculate an incorrect result after it had already been running the whole previous night.
Old 30th November 2013, 11:43   #793  |  Link
real.finder
use 2013.03.09 build instead of 2013.09.28
I also had stability problems in latest version
Old 30th November 2013, 11:59   #794  |  Link
Overdrive80
Anime addict
After of 14 hours I didnt get any error.
Thanks, I will test it.
EDIT: I can confirm that real.finder said, my system has become stable with previous version of MT.
Old 22nd January 2014, 19:41   #795  |  Link
Overdrive80
Anime addict
Excuse me, I hope that you can help me. Since days ago I get errors with avisynth like this:
I use windows 7 x64, I dont undertand why show "C\Windows\system32\avisynth.dll" if this *.dll is in syswow64.
I attach script. I would attach crash file of vdub if is required. Thanks.
Old 22nd January 2014, 20:39   #796  |  Link
When you have a complex script like that, you have to strip it down and then add stuff back step by step to see what causes the crash.
Old 22nd January 2014, 20:48   #797  |  Link
ultim
AVS+ Dev
ultim's Avatar
Based on the casing of the DLL (AviSynth.dll vs. avisynth.dll) I think you have AviSynth+. In this case please post to the AviSynth+ thread instead of here next time.
AviSynth+
ultim is offline   Reply With Quote
Old 22nd January 2014, 21:22   #798  |  Link
Overdrive80
Anime addict
Ok, I will do. Is curious, I dont get this error if I remove the line: SetMTMode(x,y). O_O.
For you say, I understand that maybe some filter is looking for avisynth in wrong directory, dont it?
Nop, I use avisynth MT of SEt. But thanks for your interest.
Old 22nd January 2014, 21:24   #799  |  Link
MT is a hit or miss kind of thing. I never use it so can't help you, but others that use it may weigh in.
Old 22nd January 2014, 21:55   #800  |  Link
TheSkiller
I get this error (access violation) too, using the latest AviSynth 2.6 alpha 5 and SEt's MT. It didn't ever happen before.
To me the error seems to occur quite randomly upon loading scripts. Sometimes I reload the script in VirtualDub (F2 Key) and get the error, then I reload again and it works... Sometimes it's there 10 times in a row. Sometimes it won't stop. I cannot nail it down to a specific script line.
TheSkiller is offline   Reply With Quote
