Old 5th April 2009, 01:23   #1801  |  Link
Egh
Originally Posted by LoRd_MuldeR View Post
Because testing showed that "threads = 3/2 * cores" works best. And that finding doesn't seem to be random at all
The intuitive solution "threads = cores" would only give optimal performance if no thread ever becomes idle (needs to wait for another thread).
still random. nearly 25% cpu% loss (total % for both cores) just with 2 threads instead of 3. With the same .bat file of course. So you effectively imply in this scenario either one thread is idle 50% of time of both threads idle 25% of time. Suboptimal?
Egh is offline   Reply With Quote
Old 5th April 2009, 01:36   #1802  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I don't imply anything. I just say that in a "real life" application you cannot assume that threads are working 100% independently of each other. Threads need to synchronize now and then! And that means that any thread unavoidably will have some idle time while waiting for another thread. Also you must keep in mind that the "look ahead" part of x264 is not multi-threaded. Lookahead needs to run each time a new encoder thread is spawned. Now imagine you were running exactly four threads on a quadcore CPU. When the first thread/frame completes, only three encoder threads are left running in parallel. Now lookahead will need to run again before a new thread is spawned. With lookahead and the three encoder thread still all four cores are busy. But if the second thread/frame completes, while lookahead has not completed yet, only two threads are left running in parallel - one CPU core becomes idle. This easily explains why running more encoder threads than cores makes sense. Last but not least the multi-threading in x264 obviously is pretty optimal: When you configure the number of threads properly (cores * 3/2), then x264 will fully utilize a quadcore CPU and give ~4x speed of a single core.
Old 5th April 2009, 05:58   #1803  |  Link
skystrife
skystrife's Avatar
x264 r1136 x64 (unpatched) - Alternate Download
gcc 4.3.4 fprofiled build.
x264.1136M.x86.exe - Alternate Download / x264.1136M.x64.exe - Alternate Download
gcc 3.4.5 fprofiled build with -march=pentium2. / gcc 4.3.4 fprofiled build.
Patches used:
x264_hrd_pulldown.11_interlace.diff
x264_win_zone_parse_fix_05.diff
skystrife is offline   Reply With Quote
Old 5th April 2009, 20:02   #1804  |  Link
techouse
Strictly Rhythm
techouse's Avatar
x264_x86_r1136_techouse | INFO
GCC 4.3.3, fprofiled, -march=core2
x264_x64_r1136_techouse | INFO
GCC 4.3.4 20090328 (prerelease) (x64.generic.Komisar), fprofiled, -march=core2
Patches used:
techouse is offline   Reply With Quote
Old 7th April 2009, 05:27   #1805  |  Link
burfadel
According to the GIT, the last patch was added 32 hours ago (faster CABAC RDO), and yet there are no 1137 builds...
www.x264.nl doesn't seem to be autoupdating it, at least quickly?...
Old 7th April 2009, 06:04   #1806  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
the latest patch wasn't released until 5 hours ago.
the devs often keep the patches locally for testing and only push to the global repository after testing is complete.
however the times are from the local repository, not from the global.
if you want the actual times it hits the global, you can check the x264-devel mailing list for subjects that start with 'commit: '
like r1137
as for x264.nl it could either be on hold or there was a problem somewhere.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 7th April 2009, 06:25   #1807  |  Link
skystrife
skystrife's Avatar
x264 r1137 x64 (unpatched) - Alternate Download
x264.1137M.x86.exe - Alternate Download / x264.1137M.x64.exe - Alternate Download
Patches used:
Old 7th April 2009, 07:00   #1808  |  Link
burfadel
like r1137
Ah ok! that makes sense
Old 8th April 2009, 17:34   #1809  |  Link
3ngel
Serious Corrupt Problem
I'm getting this on Phenom with latest
x264.1137M.x86.exe --pass 1 --bitrate 1270 --stats ".stats" --progress --keyint 250 --bframes 16 --qpmin 10 --qpmax 51 --aq-mode 0 --psy-rd 0.8:0 --no-psnr --no-ssim --no-fast-pskip --mixed-refs --b-adapt 0 --trellis 2 --ref 9 --no-deblock --subme 7 --direct auto --me umh --merange 32 --nf --weightb --b-pyramid --partitions all --8x8dct --threads auto --thread-input --no-dct-decimate --level 41 --output NUL "t.avs"
Original image size 844*480
Second Pass has identical parameters
Same result with --no-asm too
EDIT:
About the same glitches (not exactly the same) i obtain with previous versions too back to about 1113
These types of glitches are present randomly on all the video
Tested with CoreAVC, MPC Decoder and with MPC, graphedit etc...
3ngel is offline   Reply With Quote
Old 8th April 2009, 17:41   #1810  |  Link
komisar
komisar's Avatar
3ngel, what/whose build you use? Can you repeat this "bug" with other builds?
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 8th April 2009, 17:42   #1811  |  Link
3ngel
http://skystrife.com/x264/x264.1137M.x86.exe
Old 8th April 2009, 17:45   #1812  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
post the sample you're encoding so i can do testing on my phenom computers when i get off work.
Old 8th April 2009, 18:19   #1813  |  Link
akupenguin
x264 developer
akupenguin's Avatar
@3ngel
Your artifacts are definitely produced by a median-predicted lossless codec, such as ffvhuff or lagarith. Either a decoder bug or a corrupt bitstream.
mpeg-like codecs do not have failure modes that look like that.
Old 8th April 2009, 18:44   #1814  |  Link
3ngel
Mmm... i see.
I've tested the script in VDub before feeding to encoder, and it's a regular not corrupted lagarith. Moreover playing the .avs (and the lags .avi within) all is regular.
Now i'm doing a new encoding.
Old 8th April 2009, 18:47   #1815  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
I've seen that before as well--in a broken lagarith decode.
Old 8th April 2009, 18:52   #1816  |  Link
3ngel
But if it can be a lagarith issue, why i don't see the same in vdub?
Both VDub and avs use the same decoding routine (and i see both fine).
Old 8th April 2009, 19:14   #1817  |  Link
LoRd_MuldeR
Software Developer
Try converting your video to HuffYUV or FFv1 in VirtualDub. Then try to feed that into x264...
Old 8th April 2009, 19:17   #1818  |  Link
3ngel
Yes, doing that right now (doing uncompressed).
Old 8th April 2009, 23:08   #1819  |  Link
techouse
Strictly Rhythm
techouse's Avatar
x264_x86_r1137_techouse | INFO
x264_x64_r1137_techouse | INFO
GCC 4.3.4 20090408 (prerelease) (x64.core2.Komisar), fprofiled, -march=core2
Patches used:
Old 9th April 2009, 02:00   #1820  |  Link
Egh
Your explanation is very good, however can you describe in more detail how lookahead works? For instance, how much time or cpu% is spent for lookahead thread. As well, how do the things work in non-multithreaded mode, on single core?
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
