10th September 2018, 15:10 | #601 | Link |
No idea, sorry. I'm rather sure that it's not Avisynth.
Groucho's Avisynth Stuff |
10th September 2018, 15:48 | #602 | Link |
GillesH:
FFMS2 and L-SMASH Works do the same for AviSynth as the FFmpeg input plugin does for VirtualDub: Using the core of FFmpeg to read media files and provide their content to the plugin's host system. Building a keyframe index is nothing bad: It happens only once, and it adds another layer of reliability for the case that frames from the source clip are requested in a random order, instead of sequentially; sometimes the internal keyframe index in a container may even be damaged, and a source plugin relying on them would fail. The plugins do that additional indexing for your convenience. And L-SMASH Works offers two different technologies: LwLibav*Source uses an additional index (but supports a lot of containers, even those which do not have an internal index at all), and LSMASH*Source relies on an internal index inside the clip (but supports only a few containers). |
10th September 2018, 15:54 | #603 | Link |
For LSMASHSource.dll, I use a modified version modified on 9/1/2016. File Size: 9.19 MB
There is no version number indicated. For Avisynth, I use 2.6 MT and I am of the same opinion as Groucho. It's not Avisynth. But it does not matter, I will continue with FFMS2 or FFMS2000 that manage to decode this MOV Clip. Thank you for your help. |
10th September 2018, 16:11 | #604 | Link |
There have been several attempts recently to update both plugins to a newer FFmpeg core, and with better support for AviSynth+ and modern color spaces. You may try l33tmeatwad's test release with SWResample patch as one of the latest binaries, you may not use any resampler, but the splitters and decoders should be the most recent available.
10th September 2018, 16:12 | #605 | Link | |
I actually do not update FFMPEG too often (last time somewhere before they announced WinXP end of life). There is no clean way to index files with ffmpeg: my plugin does some guesswork which fails here and there. FFMS2 does something similar but is backed by much more experience. In theory is is possible to use "vd input" in avisynth for convenience, but I don't have enough time/passion to implement this.
VirtualDub2 |
10th September 2018, 16:23 | #607 | Link |
You might still want to try DSS2Mod. LAV Filters are pretty mature and you can offload decoding to the GPU.
10th September 2018, 16:24 | #608 | Link |
Hi Shekh,
Congratulations for this VirtualDub2. We will calmly wait for your passion and your time to have this future "vd input". For the moment, FFMS2 seems to be suitable. Except for slow start. All my encouragement for VirtualDub2. |
10th September 2018, 16:47 | #610 | Link | |
For lsmash, you can try threads=1, seek_mode=2 and/or changing the seek threshold seek_mode=2 is aggressive setting and will return last good frame when errors occur |
15th September 2018, 19:21 | #611 | Link |
New RAW format which could be possibly added in in Vdub2.
https://www.blackmagicdesign.com/pro.../blackmagicraw link to SDK at the bottom. SDK provides everything including debayering. Can RAW pixels bee accessed through it if wanted? Sample are also in the link. It uses .braw, but in reality it's MOV container. |
15th September 2018, 20:14 | #612 | Link | |
VirtualDub2 |
15th September 2018, 20:53 | #613 | Link |
Just looked through the sdk: it is not very verbose. From what I understood they do not wrap traditional RGGB data at all, so maybe there is no way to interface with related tools/formats.
VirtualDub2 |
15th September 2018, 22:27 | #614 | Link |
It's sort of Cineform competition, but only for RAW.
It's purely RAW codec at least atm. It's also used strictly by BlackMagic. No idea if they will allow for 3rd party recorders to implement it. They say that some partial debayering is done in camera- so this may be true that data is not anymore typical RAW. I would like to see this "pseudo RAW" data, how it differs to "real" RAW. Is it easy to add to Vdub2 or lots of work? Last edited by kolak; 15th September 2018 at 22:30. |
15th September 2018, 23:27 | #615 | Link |
It looks very easy to add as decoder.
But I don't see any mention of something raw. The minimum decoding is from compressed to RGB and includes some processing which can be controlled (like applying curves, white balance etc). The mention of partial debayering is quite vague. Just a guess: it means it is actually demosaiced to planar rgb and then compressed (wavelet?), so the rawest raw you can get from it is some rgb. This sdk is called "beta 1", quite possible things may change.
VirtualDub2 |
16th September 2018, 00:05 | #616 | Link |
It's new, but won't change much.
They can't do full debayering as bitrates are to low. All descriptions are based on RAW uncompressed as reference. This format is made to replace CinemaDNG RAW (if you know it). It's just developed, so should be decent. CPU/GPU support with CUDA, Metal and OpenCL (also all OSes). Yes- there is processing possible and you can write simple JSON file which controls it (if you download sample you will see it). It's almost like Cinefrom active metadata, but more limited. It's possible to have different values for different timecodes with frame accuracy. If there is no access to "RAW" data then we can't see what it exactly is, but this is not that important. If we could decode it then this would be great. They have simple player, but only for Mac atm. Other tool which supports it is Resolve. You an read about it more here: https://forum.blackmagicdesign.com/v...hp?f=2&t=79208 It's just new RAW format for BlackMagic cameras. I will make sure BM users know Vdub2 supports it- 1st 3rd party tool And it will allow to create h264 preview files directly from RAW. Last edited by kolak; 16th September 2018 at 00:18. |
21st September 2018, 16:00 | #617 | Link |
Mod or option request:-
Could it be possible to have "Run Video Analysis Pass" return when done, on last frame, rather than original start frame, I always have avoided that function in VDub, as I might want to see accumulated metrics (in AVS) for final frame. Cheers.
22nd September 2018, 22:17 | #618 | Link | |||||
New build out.
Also may be useful: in "Go to frame" dialog I can enter offsets. For example, type +5 to move 5 frames forward or -1 to move backward. Quote:
The first (left) pane can be set to fixed zoom, the other can still autosize. And this is saved.
VirtualDub2 |
22nd September 2018, 23:03 | #619 | Link |
Formerly davidh*****
Excellent work, thanks shekh!
I know it's been mentioned before, but I think an option to change the background colour of the window would be really useful. I also think a borderless/centered pane option would be great - it can be really useful, and much easier on the eye, to have a large surrounding area of a solid colour, rather than have the video up against the top left corner and surrounded by a 3D border. I made a couple of mock-ups: https://imgur.com/a/N4BaiR9 Direct links: 1. Current 2. Centered, borderless 3. Centered, borderless. custom background colour Tell me you don't find #3 just a little bit sexy... Last edited by wonkey_monkey; 23rd September 2018 at 00:59. |
23rd September 2018, 02:43 | #620 | Link | ||
