Old 25th September 2019, 20:04   #1001  |  Link
videoh
Useful n00b
We're having so much fun I decided to try with GPU encoding for this use case we are discussing:
DGSource() + NVENCC + 2080 Ti + 7700K: 1:05.
I tried to choose settings that produced results perceptually approximating x264 medium.
Old 26th September 2019, 07:32   #1002  |  Link
LigH
LigH's Avatar
Isn't the video decoding done in a separate PureVideo decoder chip which may not have developed as much as the 3D rendering and shader operations? ... The closet was the room with the least needs for space in this house.
New German Gleitz board
Old 26th September 2019, 08:42   #1003  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by MeteorRain View Post
That means the video renderer can't keep up because of the limited PCIe bandwidth? Very interesting.
Also the number of lanes that the CPU has with the GPU is important. For instance, Xeon CPUs like the W-3265M has 64 PCI-E lanes, while its consumer counterpart probably has less lanes. The thing is that it's not only a matter of GPU, but also a matter of which CPU you are using. As a matter of fact, having a very good GPU with a not so good CPU will limit its efficiency.
Old 27th September 2019, 03:40   #1004  |  Link
redbtn
redbtn's Avatar
Can I safely index MKV (hevc) with audio tracks and subs for now? I read somewhere earlier that i need remux MKV with only video track for better indexing, cuz another tracks can impact on accuracy.
redbtn is offline   Reply With Quote
Old 27th September 2019, 05:38   #1005  |  Link
videoh
Useful n00b
Quite right, LigH. Seems to me that the main nVidia development effort goes into gaming-relevant things. We really need super high PCI bandwidths too.
Old 27th September 2019, 05:56   #1006  |  Link
MeteorRain
結城有紀
Fairly safe. It used to index all other tracks and would create huge index file. Now they are all skipped. Let us know if you hit issues again.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 1st October 2019, 12:46   #1007  |  Link
StvG
@HolyWu, I built LSMASHSource from your repo using this CMake file taken from @MeteorRain repo. When tested for seeking issues with that file my build has errors but your build is fine. Something wrong with my building process? ffmpeg 4.2.1 / 4.3 used without difference.
There is patch for replacing avresample with swresample in your repo but avisynth exlibs - #pragma comment( lib, "libavresample.a" ).
StvG is offline   Reply With Quote
Old 2nd October 2019, 21:53   #1008  |  Link
StvG
Thanks for the info.
Old 15th October 2019, 10:45   #1009  |  Link
FNSCAR
@HolyWu ,I downloaded your build from release page of your github but there is no vsLSMASHSource.dll in folder.
Does it support vapoursynth?
FNSCAR is offline   Reply With Quote
Old 15th October 2019, 11:29   #1010  |  Link
ChaosKing
It works for avisynth and vapoursynth.
Old 15th October 2019, 16:11   #1011  |  Link
FNSCAR
I update vapouraynth to latest R47.2 and it works.Thank you.
Old 15th October 2019, 16:44   #1012  |  Link
DJATOM
DJATOM's Avatar
R47.2 is buggy. Stick with R46 or go to latest R48 test. It contains fixes for all spotted bugs of R47.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 20th October 2019, 16:32   #1013  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Question: Would be possible to use multiple threads to speed up indexing process? For example by using some kind of chunk indexing?
I'm asking because NVMe SSDs with read speed of 3GiB/s+ are getting much more affordable. I have Xeon E5-2690@3.2GHz (8C/16T) and I see that i'm experiencing a bottleneck due to single threaded code.
In this example I'm indexing 4k movie (~50Mbps) from RAM disk...
1,24GiB/s is a max I can get on single core. ffmsindex is even more cpu intensive (only ~0,5GiB/s).
Currently indexing of ~60 GiB 4k movie takes ~1 minute. With proper multi-threading we could easily reduce indexing time to ~15s!
Old 22nd October 2019, 18:20   #1014  |  Link
kedautinh12
Originally Posted by HolyWu View Post
https://github.com/HolyWu/L-SMASH-Works/releases/latest
Uploaded new binary which ditches libaom and is built by clang-cl. The binary size is smaller than the previous ICL build and decoding speed seems to be marginally faster.
No problem. Here.
Your Latest still error with .vp9, add this video and check
https://drive.google.com/file/d/1FAl...w?usp=drivesdk
Old 22nd October 2019, 18:29   #1015  |  Link
stax76
stax76's Avatar
Maybe you are asking the wrong question, how about MakeMKV creating an index? Answer: It's just code, anything is possible.
Old 23rd October 2019, 02:11   #1016  |  Link
kedautinh12
https://down.7086.in/AviSynthPlus%20...-r935%2B34.zip
Stop indexing progress spamming
-- Now only refresh at every 1%.
Still error with vp9, only old ver r929 of VFR-maniac still fine
Old 23rd October 2019, 02:35   #1017  |  Link
poisondeathray
This is AVC. Works ok. Rename the file characters
Old 23rd October 2019, 03:05   #1018  |  Link
kedautinh12
I was renamed and load ok but still error with image in video
Old 23rd October 2019, 03:36   #1019  |  Link
poisondeathray
what error? what time ?
Old 23rd October 2019, 06:01   #1020  |  Link
kedautinh12
When i load video with LWLibavVideoSource still error with L-SMASH-Works_20190917 and LSMASHSource-r935+34
https://drive.google.com/open?id=115...Yi9jrKPfOO2smu
But i load ok with L-SMASH-Works r929
https://drive.google.com/open?id=16c...G738RIUaCO2MtC
