Old 11th February 2010, 13:09   #1  |  Link
Passant
Mencoder stops very early when trying to convert a .mov file into an .avi file
I tried to register on the mencoder-users mailing-list but to no avail. So, I think this is probably the best place to talk about my issue:
I downloaded this screencast:
http://railscasts.com/episodes/199-mobile-devices
(55megs, Quicktime RLE)
I tried to encode it with Video4Fuze to watch it on my Sansa Fuze (Video4Fuze is just a handy GUI on top of mencoder and avidemux)
This failed and gave me a pretty small file, lasting only a few seconds, when the screencast lasts 5 minutes.
In addition, while the audio is ok, the video is way way too fast.
When I try to launch mencoder using the same parameters used by video4fuze, I get this from mencoder:
mencoder.exe -ss 00:00:00 -ffourcc DX50 -ofps 20 -vf
pp=li,expand=:::::224/176,scale=224:176,harddup     -ovc lavc -lavcopts
vcodec=mpeg4:vbitrate=683:vmax_b_frames=0:keyint=15:turbo:vpass=1 -srate
44100 -af resample=44100:0:1,format=s16le -oac mp3lame -lameopts cbr:br=128
-nosound  "C:\tmp\podcasts\Vidcasts\199_mobile_devices.mov" -o
brol_fuzed2.avi
MEncoder Sherpya-SVN-r29355-4.5.0 (C) 2000-2009 MPlayer Team
success: format: 0  data: 0x0 - 0x377187a
libavformat file format detected.
[lavf] Audio stream found, -aid 0
[lavf] Video stream found, -vid 1
VIDEO:  [rle ]  800x600  32bpp  29.970 fps    0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:44  fourcc:0x20656C72  size:800x600  fps:29.970  ftime:=0.0334
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [harddup]
Opening video filter: [scale w=224 h=176]
Opening video filter: [expand aspect=224/176]
Expand: -1 x -1, -1 ; -1, osd: 0, aspect: 1.272727, round: 1
Opening video filter: [pp=li]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffqtrle] vfm: ffmpeg (QuickTime Animation (RLE))
Forcing output FourCC to 30355844 [DX50].
VDec: vo config request - 800 x 600 (preferred colorspace: BGRA)
[PP] Using external postprocessing filter, max q = 6.
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
VDec: using BGRA as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
[swscaler @ 0x1c11070]BICUBIC scaler, from rgb32 to yuv444p using MMX2
videocodec: libavcodec (224x176 fourcc=30355844 [DX50])
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
Writing header...
ODML: Aspect information not (yet?) available or unspecified, not writing
vprp header.
Writing header...
vprp header.
Pos:   0.1s      3f ( 0%)  0.00fps Trem:   0min   0mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.2s      6f ( 0%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.3s      9f ( 0%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.5s     12f ( 0%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.6s     15f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.7s     18f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.8s     21f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.8s     24f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   0.9s     27f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [0:0]
Skipping frame!
Pos:   1.1s     30f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [106:0]
Skipping frame!
Pos:   1.1s     33f ( 1%)  0.00fps Trem:   0min   1mb  A-V:0.000 [98:0]]
Lots of "Skipping frame" messages, and then, at the end:
Skipping frame!
Pos:  15.8s    429f ( 9%) 54.32fps Trem:   1min   5mb  A-V:-0.028
[149:127]
Skipping frame!
Pos:  15.8s    432f ( 9%) 54.34fps Trem:   1min   5mb  A-V:-0.038
[148:127]
Skipping frame!
Pos:  15.9s    435f ( 9%) 54.33fps Trem:   1min   5mb  A-V:-0.048
[152:127]
Skipping frame!
Pos:  16.1s    438f (10%) 54.36fps Trem:   1min   5mb  A-V:-0.058
[152:127]
Too many audio packets in the buffer: (4096 in 1121863 bytes).
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
Flushing video frames.
Writing index...
Writing header...
vprp header.
Video stream:  152.010 kbit/s  (19001 B/s)  size: 304971 bytes  16.050
secs  438 frames
Audio stream:  128.000 kbit/s  (15999 B/s)  size: 264986 bytes  16.562
secs
I tried with the -ni option, just in case, but with no success.
Is this a problem in the source file? Some flags that I should enable in mencoder?
Regards,
Passant is offline   Reply With Quote
mencoder
