15th October 2012, 20:47 | #14801 | Link | |
without MPC-HC internal switcher no switch. with only MPC-HC internal switcher seems work. with MPC-HC internal switcher and madVR doesn't work. if i leave empty the modes textbox, work (with MPC-HC switcher) with even 1024x768p60 (default for my screen) blank screen. I've tryed even older build of madVR and MPC-HC. my specs are w7 64bit, i7 920, hd4650, catalyst 12.6
powered by Google Translator |
15th October 2012, 21:55 | #14802 | Link | ||
15th October 2012, 22:33 | #14803 | Link | |
The problem I have is that it's difficult to find video/film sources that don't already have a ton of ringing already encoded outside of Blu-ray. (which mostly doesn't need upscaling yet) |
15th October 2012, 22:43 | #14804 | Link | |
Of course I don't know if this is technically a little Sisyphean task-like for you to mess with the GUI, but from a user's viewpoint, a little checkbox, hidden relatively deep in the settings, won't make it more confusing. Btw: I'd really appreciate if you could comment on this: http://forum.doom9.org/showpost.php?...ostcount=14538 Thanks. |
16th October 2012, 07:45 | #14806 | Link | ||
Well, you reported that the Jinc AR produces more (or uglier) ringing compared to e.g. Lanczos/Spline AR. I need more images which demonstrate that. Basically any images which make Jinc AR stumble somehow. And the more different the test images are the better. Thanks.
16th October 2012, 10:47 | #14807 | Link |
i can confirm the dpc problems with my amd 6770 for me they are at 1300 and i didn't notice a problem at all at least nothing i'm aware off.
using a queue like 4/4 solved the "issue" but more interesting is the fact that my hd4000 in the same pc doesn't have any problems with queues like 24/24l the 6770 is still running but all displays are disconnected. even with 4/4 the error comes back after some time with evr cp there r no problem at all with dpc spikes. bug report: start a video in windows mode for example a 720 on a 1080p screen press pause then stop and now press control+enter the video will be at the top left in original size the rest is black i can't test it in windows 7 overlay mode because my amd card can't handle it in normal and fse mode it exists i think someone else reported this before not sure sry for the terrible English |
16th October 2012, 11:34 | #14808 | Link |
Software Developer
madshi:
I addressed the over-complication of the settings dialog (and ZP has a lot of them) in three ways: 1. Split the options into a basic/advanced configuration. 2. Add a centralized documentation, in your case, maybe a wiki would be best. 3. Probably overkill in your situation, but I've also added a search function that scans through the dialogs and highlights the searched item. I'm not really sure if you have the time for it, but it would simplify some of your interface design decision making. |
16th October 2012, 11:43 | #14809 | Link | ||
16th October 2012, 12:07 | #14810 | Link | ||
What is the filename mode detection for? I'd assume to fix wrong flags? That's a good idea, but imho not if it's the default because flags/file headers should be regarded more important than file names since latter can be messed up too easily. It's like if an anti-virus would catch malware by file names. It's a good thing though if it's optional. Quote:
DVDs would profit so much from madVR. |
16th October 2012, 12:25 | #14811 | Link |
Nicolas Robidoux
Mathias:
Suggestion: Because you are effectively dealing with the most offensive common problem with a linear light toolchain, namely dark halos (your'e dealing with the light ones too, of course, but they are not the main issue with linear light resampling that uses negative lobe filters), and you are starting to do rather complicated things in the AR toolchain, including Gaussian blur, I suggest that you try your favorite AR toolchain through linear light (into linear light before the resampling filter, out of linear light after the final Gaussian blur) because this will restore, among other things, light <-> dark symmetry, and in particular would prevent the most annoying artifact of sRGB resampling (besides light halos), which is the "thinning" of light on dark features, which AR, I'm sure, can't do anything about. I have the foolish hope that this may reduce the size of the worst gremlins, as well. (This being said, I still have not read your overall description of how AR works, so everything is based on "I bet it works more or less like this...") Also, unless you have "fudge factors" in your AR algorithm, I also suggest that you see if you can see a difference when you use a LUT which has more points than what you use now. ----- When you have time to waste, I suggest that you try EWA Robidoux. Not perfect. But good-cheap-solid. P.S. "The Recommendations" are in need of an update. Will take a while. Don't take what's there for my current gospel. Last edited by NicolasRobidoux; 16th October 2012 at 12:27. |
16th October 2012, 12:57 | #14813 | Link | |
You should tag it with the correct rate or perhaps leave it from the filename altogether to disable the automatic detection. |
16th October 2012, 13:05 | #14814 | Link | |
Nicolas Robidoux
For example, at locations where there is some ambiguity RE: whether to "chop", blend instead. AR looks overly eager to me. You can leave some halo. The first halo, in particular, can be argued to increase acutance, so it's not all bad. Sometimes, "better" is better than "perfect". Last edited by NicolasRobidoux; 16th October 2012 at 13:35. |
16th October 2012, 14:19 | #14815 | Link | |
With the current system, you add the correct info to the filename and your set : perfect playback ! Last edited by Pat357; 16th October 2012 at 14:23. |
16th October 2012, 14:30 | #14816 | Link | |
In the end, filename detection is a somewhat "hacky" solution, especially if you have no influence on it (hidden magic that has confused you and me). That's why I like a checkbox. |
16th October 2012, 14:43 | #14817 | Link |
You have all the influence on it by changing the filename.
16th October 2012, 15:03 | #14818 | Link |
Nicolas Robidoux
To keep noobs out of trouble and the interface clean, have some options only accessible through config files. Emphasis on "only".
Then, your documentation can have a section called "Expert Configuration Options" with a blinking neon sign that says: "You are likely to break things if you mess with this stuff, which caters to the "needs" of the minority that eats bandwidth for breakfast, lunch and dinner on madVR forums. Not to forget the midnight snack." Last edited by NicolasRobidoux; 16th October 2012 at 19:12. |
16th October 2012, 15:54 | #14819 | Link | |
