11th April 2016, 20:15 | #37444 | Link | |
Man don t lost tour time trying 10bit because Intel drivers don't output 10bit so tour data is converted to 8bit by Intel gpu, also don t turn of dithering because you lose information... The instrution to turn off dithering is only to test if your screen suports 10bit
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500 Windows 8.1 Pro x64 |
11th April 2016, 22:14 | #37445 | Link | |
the Subs are stored in the mkv as DVD-sub. There seems not to be an Option (in MPC-BE, madVR or xysubfilter) to adjust the depth of the Subs... I would be ok with an user-adjusted Option...I'm not talking about the "original Settings in the mpls"... Thanks Edit : I'm on Win8.1x64, MPC-BE from Shark007 with madVR and his standard codecs) Last edited by arrgh; 11th April 2016 at 22:16. |
11th April 2016, 23:40 | #37446 | Link | |
12th April 2016, 04:37 | #37448 | Link | |
QB the Slayer
However, there is one feature of the new crimson drivers that makes the drop worth while... The custom resolutions. When I created custom resolutions with CRU or any other way, the 72 Hz resolution would always disappear upon reboot (only being enabled when making a driver level change such as Underscan/overscan or disabling/enabling the monitor driver among other tricks). Now, with the Crimson Custom Resolutions, there is no need for jumping through such hoops to ensure I have my 60, 72 and 75 Hz resolutions at all times. So grab the latest Crimson Drivers, if you don't like them... just roll back, it's not rocket science. QB
12th April 2016, 13:40 | #37449 | Link |
That's not true, mine can.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
12th April 2016, 15:32 | #37450 | Link |
thats new! can you tell me how ? i searched a lot on internet but only find people afirmig that nots capable...
on my old laptop on nvidia cp had the option to 8 or 12 bit... but on my nw laptop on intel cp don´t have nothing...
13th April 2016, 09:16 | #37451 | Link | |
2. Intel uses Limited range output by default. You can use madLevelsTweaker utility (in madv folder) to easily set to Full range (via "EnableRGBFullRange" registry entry), which is suggested if your display device is capable to process this. Here also you can see the full registry path for your current display. I don't know whether this affects 10 bit output, probably it depends on your hardware/software chain. (E.g. I got crushed black with Limited range on my TV, now all good with Full range.) 3. There's another setting on the UI called "IT content" (it can modify chrome subsampling on your display device). Unfortunately it stopped working for me a half a year ago (I don't know what changed in my chain, it worked 1 year ago).
13th April 2016, 13:15 | #37452 | Link | |
I searched a lot abou this it content option... But did not find anything... What this option does?
13th April 2016, 16:48 | #37453 | Link | |
I think my video card couldn't handle NNEDI3.. everything is working just fine with superxbr 100 now. |
13th April 2016, 18:23 | #37454 | Link |
@Madshi:
Sorry it took me a while to do more tests regarding the crash on first play, but I've been very busy with work. I finally had a chance to spend a few hours trying to debug this, and here are the results. My current config: Win 8.1 Pro x64 with MCE ADM 7870 With Crimson 16.4.1 (same issue with all Crimson drivers) Latest MPC-BE x64 nightly, MadVR and LAV x64 beta Problem: player crashes at launch (MPB-BE has stopped working) on first playback after a reboot. Playing the same file right after the initial crash (or any other file) works fine. Once the first crash has occurred, playing the same file (or any other file) with a different player works fine. There is no crash if EVR or EVR-CP is selected instead of MadVR. I've tried the following: Revert to Catalyst 14.12 (last stable catalyst for my GPU): same issue (rules out Crimson) MPC-HC x64 instead or MPC-BE: same issue (rules out MPC-BE) MPC-BE x86 instead of MPC-BE x64: same issue (rules out x64) Using FSE mode: same issue (rules out non FSE mode) Disabling the use D3D11 path: same issue (rules out D3D11 path) Playing with the general settings in the rendering options (delay playback, disable desktop composition, use a separate device for presentation): same issue Trying to launch MPC-BE and MPC-HC directly, without using MyMovies to select the film: same issue (rules out MyMovies) I'm running out of idea, but it looks like this clearly establishes that the issue lies with MadVR as it's not the GPU driver, nor the player, nor MyMovies. I'm going to try to go back to older MadVR versions, as this is not a problem I used to have, but I had already tried to go back as far as 0.89.x and the problem was still there, so not sure how much further I should go. What is the oldest version of MadVR that will still work with the current option/registry and won't mess up my configuration? In case it matters, I was always trying to play the same film, a bluray at 23p (BDMV folder), but I have the same issue with any movie (well, at least BD folder) so it's not movie specific.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 13th April 2016 at 18:26. |
13th April 2016, 18:28 | #37455 | Link |
I'll reply to all your comments when I find some time.
For now I just wanted to post a little image comparison which shows why I like anti-bloating for SSIM downscaling. The benefit of anti-bloating may be limited to very large downscaling factors, I'm not sure, and of course whether you want to use it or not is fully your choice. For this image comparison I've disabled the anti-ringing filter for the conventional downscaling algorithms, to make their results appear as sharp as possible (anti-ringing makes the images look slightly softer). Anyway, here goes: Please make sure that your browser doesn't zoom these images. chimei inn 4K video sample: original - | - Catmull-Rom - | - Jinc - | - Lanczos4 - | - Bicubic150 - | - SSIM-100 - | - SSIM-100 with Anti-Bloating windmill photo: original - | - Catmull-Rom - | - Jinc - | - Lanczos4 - | - Bicubic150 - | - SSIM-100 - | - SSIM-100 with Anti-Bloating (Thanks to Bart van der Wolf for the permission to use his image.) |
13th April 2016, 20:24 | #37456 | Link |
a general thing, imho it would make most sense to put most emphasis (--> what gets implemented or set as default) on the effects scaling has with the most common resolutions used for scaling (which would be imho 720p --> 1080p upscaling, maybe still DVD --> 1080p upscaling and 4k --> 1080p downscaling in the future). so even if lets say SSIM anti bloating might work very well when used to downscaling from 4k to 960x540, determining whether it gets implemented or set as default should still be decided based on the results of the most common scaling resolutions.
13th April 2016, 22:54 | #37457 | Link |
Which kernel are you using for those SSIM shots? Bicubic or jinc? Also, thanks for the comparisons.
I gotta agree with you. At a glance, AB makes things closer to what they should look like, especially for the windmill bricks. Also, at least compared to bicubic 150, even with AB, SSIM is sharper. However, for the food pic, it's little harder to say that SSIM without AB is absolutely ruining the image. If I pixel peep, the table cloth pattern tends to jump too far forward, but at a distance, no AB looks better. I think it depends a lot on view distance to decide if SSIM AB is better. Without AB, you definitely spoof a higher-res image with sharper/higher frequency features, and the inaccuracy isn't as bad or apparent at longer distances. This sharpening effect is probably better/more accurate than anything you could accomplish with adaptivesharpen or the likes. I'd say keep AB as an option for the user to decide on for SSIM (maybe labeled as "accurate" vs "sharp") |
14th April 2016, 03:25 | #37458 | Link | |
14th April 2016, 09:21 | #37460 | Link | |
Its reg entry for It Content is "MP_ITContent_3060300" but it doesn't do anything for me (but it did in the past). According to this post it's advised to enable it: "This turns off any processing within the Intel display driver." http://www.acousticfrontiers.com/201...o-with-a-htpc/ Does it change anything for you when tick/untick it?
