Old 26th November 2009, 22:58   #201  |  Link
schweinsz
A new version is available at http://di-avc.com/DiAVC_alpha.zip.
Changes:
Faster start and seek
Fix the timestamp position shifting for repeated streams PROBABILY
schweinsz is offline   Reply With Quote
Old 27th November 2009, 02:02   #202  |  Link
hxhxd
schweinsz, could you post a change log or update date in you website?
hxhxd is offline   Reply With Quote
Old 27th November 2009, 05:13   #203  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
Originally Posted by schweinsz View Post
Do I need force the width and height mod 16 when require memory from the DirectVobSub if the width or height not mod 16?
I am actually unsure how DirectVobSub works. It is pretty buggy in general, and even if mod8 worked, mod4 surely wouldn't. When you "force the width and height mod 16," does that imply a resize operation? Perhaps you could study how ffdshow connects to DirectVobSub, as I (think) it can deliver a mod8 image to it successfully.
Stephen R. Savage is offline   Reply With Quote
Old 27th November 2009, 06:17   #204  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
how about adding padding?
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline   Reply With Quote
Old 27th November 2009, 06:53   #205  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Still broken...
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
Old 27th November 2009, 11:16   #206  |  Link
schweinsz
I just add padding. I have gotten the black screen if the directvobsub is used even the width and height mod 16. I am finding the reason.
Old 30th November 2009, 16:20   #207  |  Link
schweinsz
A new alpha version is available at http://di-avc.com/DiAVC_alpha.zip.
Change log:
fixed the compability problem with directVOBSUB.
fixed some problems in the filter
Improved supports to VFR samples
Old 30th November 2009, 16:40   #208  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Uhh, play->stop->play causes confused presentation, and still broken about repeated VFR.
Edit: When seeking sample, these problems disappear.
Old 30th November 2009, 17:44   #209  |  Link
schweinsz
I can't understand the "repeated VFR", I do find the video you share to me has several frames at about 56' that has a much more long presentation time than others, I fixed the start presentation time and end presentation time for them.
I compared the start presentation time and end presentation time with coreavc, and I found all start presentation time is same, the DiAVC set the end presentation time = start presentation time of next frame, but coreavc use the time gotten from samples. IMHO, I think the DiAVC is better.
Old 30th November 2009, 17:53   #210  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Player: WMP11, MediaPlayerClassic HomeCinema rev1369 built by alexins, and graphedit
Graph:
VFR source sample -(video)-> DiAVC -> Video renderer (VMR7 renderless)
               -(audio)-> ffdshow audio decoder -> Reclock 1.8.4.8
Snapshots of ffdshow OSD: [Compare_both_timstamps]Sample_of_timestamp_shift_for_DiAVC(VFR_Anime_OP).mp4.rar
Old 30th November 2009, 18:20   #211  |  Link
schweinsz
Uhh, play->stop->play causes confused presentation.
Fixed the problem, a new version is uploaded to http://di-avc.com/DiAVC_alpha.zip. This is a bug in the filter that is introduced when I fixed the directvobsub. Great thanks to you. I will fix the problem related to the VFR bitstreams according to your information.
Old 30th November 2009, 18:25   #212  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
But I still can't understand your broken VFR frames, do you mean the frames is displayed later than it should be, or earlier than it should be, or it should be displayed repeatly?
I mean the frames is displayed later than it should be in case of this sample.
Old 30th November 2009, 18:37   #213  |  Link
schweinsz
Ok, I will fix the problem tomorrow.
Old 30th November 2009, 18:40   #214  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Aha, it seems the new version is fixed about repeated VFR streams.
I'll test more.
Edit: Oh, the new version works fine at many VFR videos I encoded. Apparently, timestamp shifting problem was solved.
It's great work. Thank you.
Old 30th November 2009, 19:01   #215  |  Link
schweinsz
I'll test more.
Ok, good news, I will try to release the beta version, fixing bugs take up many of my time.
Old 30th November 2009, 20:36   #216  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Before releasing the beta version, could you fix this problem?
I found other bugs:
1. DiAVC cannot connect stream in WMP11, though DiAVC set as default decoder with DiAVCSetting.exe.
But DiAVC can connect it after changing the merit value into 0xff80000X with another merit value changer.
And I found a new bug.
Whenever seeking the stream in DiAVC+madVR, the timstamps are shifted from original.
DiAVC+madVR is still unstable. Also the following issue is not fixed.
when you stop playing, it runs through CPU usage rate unless restarting the movie or closing the player.
Old 30th November 2009, 23:11   #217  |  Link
turbojet
Any news on the playback issues/crashes with m2ts/ts files?
m2ts are bluray and ts are used for video captures so people are encountering these a lot unless they are obtaining things illegally or using dvd sources.
Old 1st December 2009, 11:29   #218  |  Link
schweinsz
Originally Posted by turbojet View Post
I did some tests with MPC-HC 1351 on windows 7 x64. mkv files everything is ok except the aforementioned slow seeking.
But there's some issues with m2ts files.
Gabest MPEG splitter + DiAVC = double speed playback, crashes on seek
Haali media splitter + DiAVC = playback ok, crashes on seek
I can't re-produce the issue with my samples (for examples, downloaded from http://x264.nl/h.264.samples/) using MPC-HC 1.3.1249.0. Could you share me some such samples? I am lack of the m2ts samples. You can try the DiAVC now, I fixed some bugs in the filter recently, perhaps the crash-related bug is fixed.
Old 1st December 2009, 14:09   #219  |  Link
schweinsz
Ok, I download some samples at http://www.cccp-project.net/beta/test_files/ and get the crash, I will fix it recently.
Old 2nd December 2009, 10:30   #220  |  Link
adam777
First of all, great work, schweinsz, I've used DiAVC for the last 2 weeks or so, and am very happy with it.
One problem, that was already mentioned, I believe, is the decoder doesn't seem to work with EVR custom.
Trying the above combination results in a black screen with only audio playing.
As I normally use madVR, it's not such a big problem, but would probably need to be fixed in future releases.
Thank again for your work, Adam.
adam777 is offline   Reply With Quote
avc, diavc, fastest decoder, h.264, software
