21st January 2004, 12:57 | #161 | Link |
karl_lillevold:
Thank you very much for your tutorial.Now I replaced every tools are latest.It is work now. But another problem is mka input plugin of foobar2000 does not play this .mka files.It can play mpc or another directshow players. |
21st January 2004, 13:23 | #162 | Link |
FFmpeg fan
mkv with vorbis audio
@jcsston: I am just curiouse. Will you add vorbis as possible audio codec for your Matroska output plugin. (mkv and mka?)
I do am content with having HE AAC as audio codec (), but up to now i was little bit sad that, though producer supports the nice and open audio codec vorbis, it can only be used for audio-only encodes. I thought that might be a problem with the container rm because of unsolved problems muxing rv40 video and vorbis audio. So i hoped to avoid this trouble by using your output-plugin. But it does not work. Do you planed to add vorbis, is there a limitation in producer that prefents the use of vorbis together with video or did i just make a mistake? VideoVorbis.rpjf: <?xml version="1.0" encoding="UTF-8"?> <job xmlns="http://ns.real.com/tools/job.2.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://ns.real.com/tools/job.2.0 http://ns.real.com/tools/job.2.0.xsd"> <disableLoadManagement type="bool">false</disableLoadManagement> <enableTwoPass type="bool">true</enableTwoPass> <clipInfo> <entry> <name>Allow Recording</name> <value type="bool">true</value> </entry> <entry> <name>Generated By</name> <value type="string">Helix DNA(TM) Producer 10.0 for Windows, Build 10.0.0.74</value> </entry> </clipInfo> <input xsi:type="avFileInput"> <filename type="string">RahXephon.avi</filename> <name type="string">home_video_test</name> </input> <parOutputs> <output> <destinations> <destination xsi:type="fileDestination"> <filename type="string">RahXephon_vorbis.mkv</filename> <name type="string">home_video_test</name> <pluginName type="string">rn-file-mkv</pluginName> </destination> </destinations> <mediaProfile> <audioMode type="string">music</audioMode> <disableAudio type="bool">false</disableAudio> <disableVideo type="bool">false</disableVideo> <outputHeight type="uint">0</outputHeight> <outputWidth type="uint">0</outputWidth> <resizeQuality type="string">high</resizeQuality> <videoMode type="string">normal</videoMode> <audienceRefs> <audienceRef>VorbisTest</audienceRef> </audienceRefs> </mediaProfile> </output> </parOutputs> <audiences> <audience> <avgBitrate type="uint">450000</avgBitrate> <maxBitrate type="uint">1500000</maxBitrate> <name type="string">VorbisTest</name> <streams> <stream xsi:type="videoStream"> <codecName type="string">rv10</codecName> <enableLossProtection type="bool">false</enableLossProtection> <encodingComplexity type="string">high</encodingComplexity> <encodingType type="string">vbrBitrate</encodingType> <maxFrameRate type="double">30.000000</maxFrameRate> <maxKeyFrameInterval type="double">10.000000</maxKeyFrameInterval> <maxStartupLatency type="double">60.000000</maxStartupLatency> <pluginName type="string">rn-videocodec-realvideo</pluginName> <quality type="uint">30</quality> </stream> <stream xsi:type="audioStream"> <codecFlavor type="uint">7</codecFlavor> <codecName type="string">vorbis</codecName> <pluginName type="string">rn-audiocodec-vorbis</pluginName> <streamContext type="bag"> <audioMode type="string">music</audioMode> <presentationType type="string">audio-video</presentationType> </streamContext> </stream> <stream xsi:type="audioStream"> <codecFlavor type="uint">7</codecFlavor> <pluginName type="string">rn-audiocodec-vorbis</pluginName> <codecName type="string">vorbis</codecName> <streamContext type="bag"> <audioMode type="string">music</audioMode> <presentationType type="string">audio-only</presentationType> </streamContext> </stream> </streams> </audience> </audiences> </job> producer.exe -j VideoVorbis.rpjf -lc "e,i,w,d" >out.txt ... Diagnostic: Using VorbisTest Audience Diagnostic: Using video codec: rv10 (322000 bps) Warning: Unrecognized property analysisFile provided to the Vorbis Codec. Diagnostic: Using audio codec: vorbis (128000 bps) Info: Starting encoding pass Diagnostic: Setting video packet size to 1352 Error: Invalid codec specified for the mkv file writer. Info: Total | Audio | Video | Avg | Min | Avg | Min | Pre- |Audience Name Info: kbps | kbps | kbps | FPS | FPS | QI | QI | roll | Info: Total Bitrate = 0 kbps Error: Encoding failed! Done Errors: 2 Warnings: 2 |
21st January 2004, 19:43 | #163 | Link |
Using Producer to rip to iPod compatible M4A
Using Producer like satori first suggested in foobar, reminded me how I set up EAC to rip to AAC encoded with Nero... So with the latest mkvtoolnix and mp4creator60, it is now possible to set up foobar or EAC to rip to iPod compatible M4A using RealProducer 10 with RA10-AAC (Coding Technologies AAC). All you have to do is to set the CLI encoder up like this: encoder: c:\windows\system32\cmd.exe extension: m4a parameters: /c d:\misc\producer_10\producer.exe -i %s -o %d.mka -ad c:\audio.rpad -dv && mkvextract tracks %d.mka 1:%d.aac && mp4creator60 -aac-profile=4 -optimize -create=%d.aac %d (no line-breaks, add/edit full paths for each tool if they are not in your $PATH) For this to work, you need jcsston's mkvwriter in Producer's tools directory. Without mkvwriter, one additional step from RM to MKA is needed. You may also want to tag on at the end of the long line above: && tg.exe %d --artist "%a" --album "%g" --track "%n" --title "%t" --genre "%m" --year %y if you would like tags in your M4A file.. for 192 kbps AAC, use audio.rpad like this: Code:
<?xml version="1.0"?> <audience> <avgBitrate type="uint">192000</avgBitrate> <maxBitrate type="uint">192000</maxBitrate> <streams> <audioStream> <pluginName type="string">rn-audiocodec-realaudio</pluginName> <codecName type="string">raac</codecName> <codecFlavor type="uint">4</codecFlavor> <streamContext type="bag"> <presentationType type="string">audio-only</presentationType> <audioMode type="string">music</audioMode> </streamContext> </audioStream> </streams> </audience>
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 21st January 2004 at 19:48. |
22nd January 2004, 10:41 | #164 | Link |
@karl_lillevold
In this process.It made .mka .aac and.m4a files. aac file shows AAC+SBR in foobar2000.But .m4a shows only AAC. (I never checked by iTunes since I just uninstalled) When AAC wrapped in mpeg4 container was SBR header losted? |
22nd January 2004, 17:00 | #165 | Link |
re SBR info lost: Yes, the raw ADTS .AAC format does not have a flag to store whether or not there is SBR information in a stream. This is a well known problem, and most AAC decoders (CT, Core, 3ivx) handle this by decoding the first frame to figure it out. In some cases the wrong information will be shown (Core), but still decoded correctly. 3ivx on the other hand displays HE-AAC in any case.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
22nd January 2004, 18:01 | #166 | Link |
well sbr/he-aac in .aac should be whereever possible avoided
only because some (not all) decoders support a workaround for these crappy files, some people might already call mka/mp4/m4a files with he-aac/sbr but without the needed flag borked... but i guess it would solve the problem if jcsston could add support for adding this flag to .mka already via commandline (as for example mkvmerge and avi-mux gui already offer)!
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 22nd January 2004 at 18:04. |
22nd January 2004, 18:29 | #167 | Link | |
22nd January 2004, 18:37 | #168 | Link |
ah ic (stupid me )
but no, afaik no mp4 muxer supports flagging he-aac when muxing to mp4
22nd January 2004, 23:43 | #169 | Link | |
he_aac_file.mka -> Matroska Splitter -> 3ivx Muxer -> he_aac_file.mp4 If the flag is set in the mka, it should be set in the mp4, too. |
23rd January 2004, 23:44 | #170 | Link |
Re Graphedit w 3ivx MP4 muxer: In theory, yes. In practice, no, at least not on my system (latest versions of all filters). Resulting file plays twice the speed, and is full of noise. Also, for the command chain above, everything needed to be on the command line, to be able to run in CLI encoders (EAC, foobar2000).
24th January 2004, 00:40 | #171 | Link | |
24th January 2004, 03:28 | #173 | Link |
hartiberlin,
didnt we already discuss how to correctly compare rv9/10 vs wmv9 vs mpeg-4 hdtv clips? or was this with somone else?
25th January 2004, 05:24 | #174 | Link |
This is probably a dumb list of questions, but I am not knowledgable of the all specs between the compression technologies.
Is AAC better than RA8 for saving CD tracks? I get the impression it is. If so, what AAC compression level in RealPlayer 10 should I use to save CD tracks? How does RV10 compare to DivX 5.1.1? Given the same source video file, do they compress to comparable size files? Does one format have advantage over another in regards to editing or streaming? |
25th January 2004, 15:41 | #175 | Link |
retired developer
Hi
AAC range is from 64 to 320kbps, RA8 (cook) is from 16 to 96kbps. AAC is surely better than cook for CD ripping, since you can choose 192kbps. About RV10 vs DivX, it's all about taste. I encode mostly animes, and with RV10 I can get 60% smaller files without big quality loss.
Detritus Software |
25th January 2004, 16:13 | #176 | Link | ||
dunno about the quality real's aac codec brings...
25th January 2004, 16:36 | #177 | Link |
Life's clearer in 4K UHD
'Tiss true
Hey Sirber if you want to hear some comparisons of 2Ch HE and LC AAC encodes at low bitrates please check out Area 51 of my web site! I will be adding Mp3pro, WMV9 and maybe some RA9/10 audio soon. Cheers
25th January 2004, 16:43 | #178 | Link | |
CT invented "Plus" (HE), and the HE part of the AAC codec we license was implemented exclusively by CT, and should be the highest possible quality. CT's extensive audio experience is highly regarded. It would be interesting to have a listening test compare the LC AAC part of these codecs though, to see if the individual tuning has made a difference. It would also be nice to have the HE part compared, I think only CT and Nero have so far implemented HE...
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 25th January 2004 at 16:47. |
25th January 2004, 16:53 | #179 | Link | |||
check out rjamorims public listening tests: http://www.rjamorim.com/test/aac128test/results.html especially sorenson (fhg) vs. apple (dolby), nero is completely self made afaik Quote:
http://www.rjamorim.com/test/64test/results.html btw there is now a listening test about mp3 at 128kbps running, would be great if you guys join it http://www.rjamorim.com/test/mp3-128/presentation.html the more people participate the better the results!
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 25th January 2004 at 16:58. |
25th January 2004, 17:03 | #180 | Link |
Re: rjamorims public listening tests: I know about those, and have taken part in most of them (well, at least one clip each). The Coding Technologies AAC codec has not been included in any of them yet, and the 64 kbps test includes only Nero-HE, even though HE was invented by CT. Perhaps as more "HE" implementations become available, there will be a separate HE test.
