4th February 2004, 20:10 | #41 | Link | |
PGC Navigator in Training
@tluxon
2COOL |
4th February 2004, 22:22 | #42 | Link |
This is the first time I've used IFOedit and my very first attempt is on a DVD with duplicate menus in two VTS groups. It LOOKS like the implication here is that I don't even need any of the files in the VTS group of the aspect ratio I don't want to keep. Have I got that right?
For some reason, I went into this expecting that I needed to keep ALL the files and I would be doing something like replacing the files I don't want with "lite" ones of the same name and structure. Thanks, Tim |
4th February 2004, 22:36 | #43 | Link | |
2COOL Last edited by 2COOL; 5th February 2004 at 09:10. |
5th February 2004, 01:23 | #44 | Link | |
Re: @2COOL
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker Last edited by geffroman; 10th March 2004 at 00:36. |
5th February 2004, 14:37 | #45 | Link | |
@all
I don't know about alot of you guys but I'm a "why" person. When I press a button, I want to know what happens and why it happens. That's why a "guide" is called a guide. I want to guide you, not scare you but the decision is up to you. Just like in the movie, The Matrix...either you take the blue pill or you take the red pill.
2COOL Last edited by 2COOL; 11th March 2004 at 20:36. |
5th February 2004, 15:25 | #46 | Link |
@2COOL
I, for one, really appreciate that you took the wordy approach. Believe it or not, it was my first look inside an IFO file and I had never read as much as an introduction to what was in one. Sure, it looked like a little more than it really is, but most things do when they're complete with explanations. I suppose you could have referenced a more detailed IFO explanation guide (if there is one) and provided a much leaner guide yourself, but by putting it all in one place you made it easier to ingest/digest only the parts most pertinent to your guide. I'm hoping tonight I'll be able to pick up where I left off on Monday. Thanks! Tim |
5th February 2004, 16:47 | #47 | Link | |
@2COOL
Thanks again for all that you do for us... Jeff
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker |
5th February 2004, 19:50 | #48 | Link | |
Re: @2COOL
2COOL |
5th February 2004, 22:57 | #49 | Link | |
Re: Re: @2COOL
9th February 2004, 19:22 | #51 | Link |
@2COOL,
Unfortunately, our family is in the midst of upsizing our RV and we've spent almost ALL our spare time these last several days researching models and attending the Seattle Winter RV show. I will definitely lock down some time to continue tonight. Thanks, Tim |
13th February 2004, 11:40 | #53 | Link |
Nice guide 2Cool. Wish I saw it about 3 hours sooner. I just tested it with Second Hand Lions. Im a registered MenuEdit user and I used the blank_exe. Worked like a charm.
I have one question. Is the last fake stripping with IFOEdit really needed? I asume its done for a good reason, but is it really need for the movie to work properly? I test played my movie before I did the last fake strip and it work fine before the last fake strip and after it. I saw no difference. So can you explain a little about what could happen if the last one isn't done. Last edited by DMagic1; 13th February 2004 at 11:43. |
13th February 2004, 20:49 | #54 | Link | ||
2COOL |
8th March 2004, 20:17 | #55 | Link |
Posts: n/a
widescreen selection AFTER the play movie menu
please help...how do you automaticaly change the default of which aspect ratio format is being played when the "play movie" button is selected?. i ripped out the fullscreen so only the widescreen is present and the default choice is fullscreen which isn't present.... so the only way it will work is if i setup the DVD first by selecting the widescreen format and then going back to the main menu and playing the movie. if i hit play movie before i change to widescreen the movie just hangs
the movie is for my daughter "barbie as rapunzel" |
8th March 2004, 21:47 | #57 | Link |
Posts: n/a
please help 2 cool
i am honoured that YOU responded to my reply, your guides are excellent..thank you. BUT you did not include the link for you guide with my problem, the guide i posted in is good for aspect ratio menus BEFORE the play movie screen (i used it for stuart little 2)...
but my issue is AFTER the play menu screen... it has to selected and then back to the play menu screen. this would be the same for "audio" selection. i need to change the DEFAULT movie format from FULLSCREEN to WIDESCREEN because if i hit "play movie" the intro loops back because the default format (fullscreen) has been ripped OUT !!!!, i want the "play movie" buttom to play the only format present ....the WIDESCREEN version. thanks 2cool JOE |
9th March 2004, 05:19 | #59 | Link |
Posts: n/a
the movie is barbie as rapunzel (it is for my daughter) and yes i am playing back the "DVD files" on my PC as a test before i actually burn the disc. i use POWER DVD and yes the "keep aspect ratio" button is selected
the dvd boots up the the main menu that offers two buttons "movie" and "games", after i select "movie" another menu pops up that has 3 buttons "play movie" "chapters" "dvd set up". on the original dvd if i just hit "play movie" without going first to "dvd set up" the FULLSCREEN movie is played by default. howevere if i first "set up dvd" and select widescreen in this menu than of course i must go back to the "play movie" menu and then the WIDESCREEN format plays if i do select the same "play movie" on the ripped dvd (absent of a FULLSCREEN format) the screen remains black (no corresponding default format ... and if i pre-select widescreen than the only format present (widescreen) will play as expected this jumping to the "dvd set up" menu and back to the "play movie" menu is the procedure i want to ELIMINATE. i want to boot the dvd and selct "movie" and than "play movie" and i want my widescreen to play by DEFAULT. my 5 year old daughter will never understand all this.... not to mention my 32 year old wife (if you know what i mean) JOE |
