Old 13th September 2008, 21:29   #81  |  Link
Originally Posted by Sagekilla View Post
By the way, is this more or less optimized?
Well I have avoided stupid things but there are some things that still need to be investigated. The connection to DX/D3D is a possible area for improvement. But I'm pretty happy serving 1920x1080 46fps @ 2% on my machine. As long as we can feed x264 faster than it can encode, we are golden.
Guest is offline
Old 13th September 2008, 21:30   #82  |  Link
Originally Posted by BetaBoy View Post
Congrats neuron2!
Thank you.
BTW, any word on the CoreAVC API/SDK?
Guest is offline
Old 13th September 2008, 21:47   #83  |  Link
Sagekilla
x264aholic
Yes indeed, I'm glad you have this here now. Having my CPU usage for decoding basically halved (perhaps a third even, my desktop has a faster GPU) is a godsend.. Goodbye 0.7 fps decodes!
I absolutely cannot wait to test this on my monster of a setup.. GPU decoding on my desktop with a 9800 GTX, filter using MVDegrain3, pass it off with TCP serving to my laptop and encode it.
Sagekilla is offline
Old 13th September 2008, 22:02   #84  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
Edit 2: Odd, the error seems to have been a one shot deal. I haven't had it again.
I've gotten a bunch of spontaneous errors before.
And now trying it again, it's no longer working at all; spitting out some of the standard 'no supported GPU' errors
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline
Old 13th September 2008, 22:08   #85  |  Link
Reboot.
Guest is offline
Old 13th September 2008, 22:36   #86  |  Link
Dreassica
Works here too, ha to install badaboom and the drivers as well as copy the 2 files Crypto had to copy to the dir dgaindexnv is located in.
24 fps with max 28 on a 8800gts 512MB
Dreassica is offline
Old 13th September 2008, 23:13   #87  |  Link
The PureVideo deinterlacer looks REALLY good but reduces the frame rate by 25% (i.e., rate is 75% of the rate without deinterlacing) on full HD. I'll expose it as an option in the next alpha.
Guest is offline
Old 13th September 2008, 23:23   #88  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Awesome!!!
Currently downloading the CUDA driver for Vista x64 here... I *thought* I had it installed, but it wasn't working (the cuinit error).
Will report back ASAP!
Thanks Don!
-Derek
Blue_MiSfit is offline
Old 13th September 2008, 23:41   #89  |  Link
Blue_MiSfit
Okay, so i have the CUDA driver installed, and when I open DGAVCIndexNV I get the "failed to find CUDA compatible D3D device" error.
I have an 8800gt, which is both CUDA and DXVA compatible.
Vista x64 being a naughty little child perhaps?
Has anyone else gotten this working with Vista x64?
~MiSfit
Old 13th September 2008, 23:49   #90  |  Link
rack04
Where do I get DGAVCDecodeNV.dll? It's not included in the zip file.
rack04 is offline
Old 14th September 2008, 00:17   #91  |  Link
You'll have to do some research over at the Nvidia CUDA Zone website. Let us know when you find out.
Guest is offline
Old 14th September 2008, 00:17   #92  |  Link
You have to pay extra for that.
[Just kidding. I'm still working on it.]
Guest is offline
Old 14th September 2008, 00:24   #93  |  Link
menlvd
LoL
menlvd is offline
Old 14th September 2008, 00:27   #94  |  Link
Ranguvar
Ranguvar's Avatar
LOL
I have Windows XP Pro SP2 x64, and a GeForce 9600GT 512MB. DGAVCIndexNV worked for a while (with bugs, explained later), until each time I started it, it wouldn't find my video card. I copied the files as mentioned, installed the CUDA driver and toolkit, and rebooted, and now it appears to be working again.
So, bugs.
1.) There is a significant amount of artifacting during playback in the indexer with DS's x264-encoded Touhou sample (here), and especially the lossless Touhou sample (here). I don't know if it's also in the decoded stream through AviSynth+DGAVCDecode.
2.) If I play either of those samples in the indexer, and then quit before stopping playback (with display on) I usually get the errors "cuvidMapVideoFrame: 201" and the same with the number 205, after I exit.
3.) In the lossless sample, if I seek to the middle of the video and then hit Play, the video does not play and no info is reported.
...and now I get the CUDA-compatible D3D device error again. :/
Thanks for your work, neuron2 Can't wait until this works well - it was able to play the non-lossless sample at 147+fps with no CPU usage (display off) before it stopped working. Promising
Ranguvar is offline
Old 14th September 2008, 00:27   #95  |  Link
Let me know how you like the deinterlacer.
http://neuron2.net/dgavcdec/dgavcindexnv100a2.zip
Guest is offline
Old 14th September 2008, 00:29   #96  |  Link
Ranguvar
Ranguvar's Avatar
Is that the only change? If so, I won't test it, as there are critical problems on my system right now with it. But if there's fixes, I shall test and see if it works better.
Great work
Ranguvar is offline
Old 14th September 2008, 00:29   #97  |  Link
MP4 and MKV files are not yet supported, just as with DGAVCIndex.
Guest is offline
Old 14th September 2008, 00:30   #98  |  Link
Ranguvar
Ranguvar's Avatar
I used the demuxed .h264 stream.
Ranguvar is offline
Old 14th September 2008, 00:34   #99  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I would like to see some screenshots (yadif vs NV deiterlacer)
Atak_Snajpera is offline
Old 14th September 2008, 00:35   #100  |  Link
Thanks for giving those to me.
Guest is offline
