27th February 2019, 05:36 | #6762 | Link | |
Broadcast Encoder
I remember that I had this kind of issue when I tried to compile x265 x86 with Visual Studio (I never managed to get 10bit and 12bit builds for x86 out of Visual Studio). I tried now with a longer test, but encoding at 8bit this time, letting x265 calculate the average speed for me and feeding it with a 16bit uncompressed clip: - GCC 8.2 SSE4.2 6.19fps - Wolfberry not SSE4.2 6.14fps - GCC 9 Preview SSE4.2 6.11fps - LigH 6.22fps However, encoding at 8bit and comparing different compilers shows different results, 'cause for 8bit x265 there are manually written intrinsics by x265 developers. The interesting part is with 10bit for which there aren't manually written intrinsics, so it's up to the compiler to optimize the plain C++ code as much as possible, that's why I was testing them with Main10 in my previous test. For the 8bit, apparently, GCC9 is still slower than GCC8, your build without targeting SSE4.2 is somewhere in-between and the one made by LigH is faster than mine for whatever reason. But again, for 8bit there are manually written intrinsics, so I can't really test the effectiveness of compilers. Last edited by FranceBB; 27th February 2019 at 05:40. |
28th February 2019, 10:23 | #6763 | Link |
@katzenjoghurt
In new binaries from http://msystem.waw.pl/x265/ (ver. 3.0_Au+8) zones are working. Now I must do some work for living but at the weekend I should look into this bug closer and prepare proper patch that works with SVT_HEVC too. |
28th February 2019, 17:11 | #6764 | Link |
x265 3.0 Au+8-31ab7e09a3b5 (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.3.0)
New 64-bit GCC 8.3.0, and zone issues should be fixed |
28th February 2019, 19:58 | #6765 | Link | |
Immediately tried it out this morning but had to get to work as well (really quick) and was running out of time to post about it. Thank you, Ma. Last edited by katzenjoghurt; 28th February 2019 at 20:14. |
5th March 2019, 16:31 | #6766 | Link |
x265 v3.0_Au+9-2abd2a1909a4 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
https://bitbucket.org/multicoreware/x265/commits/branch/default |
10th March 2019, 16:59 | #6768 | Link |
x265 v3.0_Au+14-c7e5878bdd31 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
13th March 2019, 14:48 | #6769 | Link |
x265 3.0 Au+14-c7e5878bdd31 (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.3.0)
3 flavours:
AVX2 for normFactor and ssimDistortion |
30th March 2019, 05:50 | #6770 | Link |
SuperVirus
x265.exe 3.0_Au+16-0018ca1ca42f
(GCC 7.4.0, 64-bits, multilib) http://www.mediafire.com/file/gtr4eh...018ca1ca42f.7z |
21st April 2019, 09:13 | #6772 | Link | |
SuperVirus
21st April 2019, 15:40 | #6774 | Link | |
SuperVirus
It is somewhat bloated because of the additional stuff, but I compressed it with upx and now it has a healthy weight. Last edited by filler56789; 21st April 2019 at 16:58. Reason: damn typos :-/ |
25th April 2019, 18:52 | #6775 | Link |
Pig on the wing
How does one get rid of the "onion gradient" artifacts of x265? In the sample images, they are apparent in the character's forehead and also in the purplish stripe near his hair (zoom a bit to see both better). The bitrate of the encodes is ~6900 kbps.
x264 x265, aq-mode 1 x265, aq-mode 2 Some base settings of the x265 encode: Code:
--deblock -2:-1 --no-strong-intra-smoothing --cbqpoffs -3 --crqpoffs -3 --subme 3 --merange 24 --no-sao --no-rect --qcomp 0.7 --rd 6 --rd-refine --aq-mode 1/aq-mode 2 --aq-strength 0.9 --ctu 16 --max-tu-size 8 --qg-size 16 --tu-inter-depth 2 --tu-intra-depth 2 --limit-tu 1 --limit-refs 3 --max-merge 2 --ref 5 --bframes 10
26th April 2019, 16:46 | #6777 | Link | |
A 8x8 max tu is pretty unusual, and those are also big chroma offsets which can suck bits away from luma. What are the goals of these settings, and how tdid you come to them? |
27th April 2019, 10:01 | #6778 | Link |
Pig on the wing
I got you the original clip here. I basically did a very slight MDegrain and then downscaled to 1280x720 using a very sharp Bicubic and fed to the encoders.
https://drive.google.com/open?id=1Qm...9NZavzXFTSkGIr My x265 settings are based on frame-by-frame comparisons that I made several times. A small CTU and TU size look better (least distortion compared to the original image) with 720p encodes. For 1080p, I would use one notch higher values (also based on my tests). The chroma offsets don't change the bitrate much in CRF mode so the difference in 2-pass shouldn't also be big. Besides, x264 already does a similar thing by default. EDIT: does anyone else have problems with topic notifications? I don't get any emails at all from any thread I've subscribed to.
27th April 2019, 10:54 | #6779 | Link | |
Lost my old account :(
x264 2pass @ 5Mbps, veryslow tune film x265 2pass @ 5Mbps, slow, --no-sao --no-strong-intra-smoothing --deblock -1:-1 Last edited by excellentswordfight; 27th April 2019 at 11:00. |
27th April 2019, 18:59 | #6780 | Link | |
Pig on the wing
I did some more testing now that I found those troublesome frames (it seems they evaded me when I pinpointed my go-to settings a long time ago), and using CTU 32 makes the onionize effect go away. I also left max-tu-size and qg-size at their defaults since things looked good.
