Old 20th September 2019, 23:50   #7041  |  Link
Stereodude
Originally Posted by mini-moose View Post
The quotes on solved means they didn't solve it at all?
They made a huge improvement in performance. I don't know why he used the quotes.
Stereodude is offline   Reply With Quote
Old 21st September 2019, 10:56   #7042  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Improvements in Zen2 architecture are huge!
Old 21st September 2019, 14:21   #7043  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Very interesting chart indeed.
Is there another one which includes AVX512 as well?
Broadcast Encoder
Avisynth memes: 1 - 2 - 3
Videotek - Audacity XP
Old 22nd September 2019, 20:02   #7044  |  Link
RanmaCanada
AVX512 is currently Intel only, and is "completely useless" for x265 as it produces way too much heat for the results.
https://forum.doom9.org/showthread.php?t=175476
https://www.reddit.com/r/programming...wn_your_cpu_a/
Old 23rd September 2019, 08:59   #7045  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Boulder View Post
I tested HME some more, and got quite interesting results.
Source 1080p filtered with my standard methods and downsized to 720p, merange 26 and my standard settings in x265. 1000 frames.
umh,umh,umh 2.05 fps / 5313,76 kbps
umh,umh,star 2.24 fps / 5314,31 kbps
umh,star,star 2.00 fps / 5327,91 kbps
star,star,star 2.01 fps / 5316,15 kbps
hex,umh,umh 2.03 fps / 5299,69 kbps
no HME, umh 2.64 fps / 5323,86 kbps
no HME, star 2.79 fps / 5325,69 kbps
I've now upgraded to 3700X and ran a similar test with that. The order of the results is still the same.
Can any of the devs (or anyone else, of course) explain why the combination "umh, umh, star" is clearly the fastest one? Without HME, the star method is clearly faster so I would expect "star, star, star" to be the fastest one with HME.
Old 24th September 2019, 15:56   #7046  |  Link
mini-moose
How is me=3 (star) faster than me=2 (umh)? thought the higher --me is, the slower it's supposed to be, maybe I'm wrong, I'm not expert.
Also, HME, is that a good feature to use?
mini-moose is offline   Reply With Quote
Old 24th September 2019, 16:22   #7047  |  Link
aymanalz
How is me=3 (star) faster than me=2 (uhm)? thought the higher --me is, the slower it's supposed to be, maybe I'm wrong, I'm not expert.
Based on all user reports I have read, star gives comparable or better quality to umh but is equally fast. I'd like to know the truth of this as well - could any knowledgeable person please tell me if this is right?
Is Star a better method than umh in terms of:
1) Quality
2) Speed
3) Quality and speed
I's also like to take this opportunity to point out that there is a dearth of easily understandable documentation for x265. By that, I mean something for dummies like me. There are so many elementary questions that I cannot find answers to, despite all my googling.
aymanalz is offline   Reply With Quote
Old 24th September 2019, 19:25   #7048  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There's something broken in the latest versions, I've now tried two different builds but both have the same problem.
y4m [info]: 1920x1080 fps 24000/1001 i420p16 sar 1:1 unknown frame count
raw [info]: output file: f:\temp\captures\testclip.hevc
Error: fwrite() call failed when writing frame: 4, plane: 0, errno: 32
Output 22 frames in 1.66 seconds (13.23 fps)
This is just by loading the source in a Vapoursynth script and feeding it to x265 with vspipe. Many other clips work just fine.
The clip that causes this one can be found here:
https://drive.google.com/open?id=1AU...FwqqFfOZLgNr4M
x265-3.1+14 works fine.
Old 24th September 2019, 19:26   #7049  |  Link
Boulder
Pig on the wing
Boulder's Avatar
And my question that I posted to the x265 mailing list still has not been approved so I don't know if any dev saw the question regarding the motion search methods.
Old 24th September 2019, 20:27   #7050  |  Link
Selur
Selur's Avatar
did a quick test trying to reproduce this here (did no filtering, just decoded with ffmpeg and piped to x265), for me too uhm was slower than star, but the speeds were similar.
--me star:
"I:\Hybrid\64bit\x265.exe" --preset medium --input - --output-depth 10 --y4m --profile main10 --me star --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --lookahead-slices 0 --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2  --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt709 --output "E:\Temp\19_56_10_6810_02.265"
-> "encoded 2868 frames in 325.41s (8.81 fps), 4606.13 kb/s, Avg QP:23.78"
--me uhm:
"I:\Hybrid\64bit\x265.exe" --preset medium --input - --output-depth 10 --y4m --profile main10 --me umh --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --lookahead-slices 0 --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2  --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt709 --output "E:\Temp\20_03_51_9010_02.265"
-> "encoded 2868 frames in 326.89s (8.77 fps), 4605.07 kb/s, Avg QP:23.78"
I used:
x265 [info]: HEVC encoder version 3.1+20-913823aa15cd
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
on a Ryzen 7 1800X
Ran the calls a second time this time I got:
--me star: "encoded 2868 frames in 320.13s (8.96 fps), 4606.13 kb/s, Avg QP:23.78"
--me umh: "encoded 2868 frames in 322.27s (8.90 fps), 4605.07 kb/s, Avg QP:23.78"
-> So here too, uhm is slower, but not a lot, so this might still be source depended.
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 25th September 2019, 06:39   #7051  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There are some early exits in star which probably don't exist in umh, so that source dependency would make sense. The method is some kind of an adaptation of what's in HM encoder.
https://xevc.wordpress.com/2014/01/2...of-hm-encoder/
Old 25th September 2019, 10:06   #7052  |  Link
markiemarcus
I've seen some gains from using umh instead of star on animated sources. Admittedly slight at 1080p, but definitely visible at 720p and below. On live action I really can't spot the difference.
markiemarcus is offline   Reply With Quote
Old 25th September 2019, 16:51   #7053  |  Link
Barough
Barough's Avatar
x265 v3.2+3-fdd69a766881 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
https://bitbucket.org/multicoreware/x265/commits/branch/default
Old 25th September 2019, 21:14   #7054  |  Link
Natty
Noob
release notes for v3.2
https://bitbucket.org/multicoreware/...leasenotes.rst
Natty is offline   Reply With Quote
Old 26th September 2019, 08:35   #7055  |  Link
LigH
LigH's Avatar
The speed of "far" motion search algorithms depends on the average amount of motion. Some of them can terminate early if the optimum is found close to an intermediate step. Disclaimer: If I understood these algorithms correctly...
New German Gleitz board
Old 26th September 2019, 22:52   #7056  |  Link
Ma
Could you specify your x265 options to reproduce the problem?
Ma is offline   Reply With Quote
Old 27th September 2019, 05:43   #7057  |  Link
Boulder
Pig on the wing
Boulder's Avatar
This is what I've used for that one:
--input - --y4m --input-depth 16 --dither --sar 1:1 --profile main10
--rc-lookahead 120 --min-keyint 5 --keyint 480 --splitrd-skip --colorprim "bt709" --transfer "bt709" --colormatrix "bt709"
--preset slower --rd-refine --subme 4 --ctu 32 --qg-size 16 --limit-refs 1 --limit-tu 3 --bframes 16 --deblock -2:-1 --no-sao
--cbqpoffs -3 --crqpoffs -3 --hme --hme-search umh,umh,star --merange 26 --qcomp 0.7 --max-merge 2 --aq-mode 3 --aq-strength 0.6 --crf 18.5
Old 27th September 2019, 13:25   #7058  |  Link
Selur
Selur's Avatar
does anyone have a current x265 build with stv ?
Old 28th September 2019, 06:36   #7059  |  Link
HolyWu
HolyWu's Avatar
x265 3.2 with SVT-HEVC encoder enabled
x265 [info]: HEVC encoder version 3.2
x265 [info]: build info [Windows][Clang 9.0.0][64 bit] 8bit+10bit+12bit
x265 [info]: (lsmash 2.16.1)
HolyWu is offline   Reply With Quote
Old 28th September 2019, 08:19   #7060  |  Link
Selur
Selur's Avatar
thanks!
