Old 14th November 2019, 11:15   #57781  |  Link
mclingo
they look different to me, the first one is definately brighter and has a bit more red at low IRE, blacks arent as deep as the second, but this could be a personal preference thing, the second looks more natural to me.
I watched it in HDR and it looked much the same for me to using MADVR, the series is very rogue one easque so muted colours, washed out greys and blacks.
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 580 19.12.2 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:On / MADVR 10bit
Old 14th November 2019, 12:06   #57782  |  Link
Warner306
Originally Posted by jeffk View Post
Is there any trouble with the tone mapping ?
Here the screenshoot of the 1080p SDR version versus the 4K HDR tone mapped to SDR (using "Let MadVR decide" and "Pixelshader", they both have the same result)
1080p SDR :
https://reho.st/view/self/631eef439c...004bf6a411.jpg
4k HDR to SDR (downscaled to 1080 using Jinc)
https://reho.st/view/self/8319a1c769...516a19b141.jpg
Thanks,
You are complaining about the tone mapping quality for a shitty HDR torrent that was captured using an HDMI capture card? Is that not from a newly released Disney+ TV show?
It is your source and not the tone mapping. Check the original stream before complaining about a the quality of a low-grade torrent file on these forums.
Old 14th November 2019, 12:19   #57783  |  Link
wow i except something like this from me but not from you.
Old 14th November 2019, 12:44   #57784  |  Link
jeffk
Well you may do some research because its pure downloaded from the source, not capture
I'll be not deviate to piracy talk but you may check again
I can test with a proper UHD Bluray I own, it will be the same.
And i'm not complaining at all, just reporting something, so madshi can check if the tone mapping is ok are not \_(ツ)_/
jeffk is offline   Reply With Quote
Old 14th November 2019, 13:24   #57785  |  Link
el Filou
el Filou's Avatar
If you're talking about the tone mapping in the latest official release, it hasn't seen changes for more than a year now and frankly is starting to show its age.
Unfortunately the HDR test builds over at AVS Forum are changing constantly so it's difficult to recommend a specific one, but the gains in quality are really amazing.
Originally Posted by Furgiuele View Post
I have a (clock deviation) issue. I use Jriver MC25. When I start watching a movie I have a big clock deviation with a frame drop every second or littlemore, but the cd decreases and frame drop time increases continuously. Then, after one hour, really I won't have any frame dropped and I won't have any stuttering or artifacts.
Are you using JRMC's 'reclocking' feature? I don't know what it's called but I know it has one and this sounds like the situation when ReClock is 'learning' the clock.
If you can't solve your issue by creating a custom refresh rate with CRU, maybe the JRiver forums will help you better.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 14th November 2019, 14:04   #57786  |  Link
Warner306
Can you download Disney+ shows already? That picture looks absolutely terrible. UHD Blu-rays actually look really good when tone mapped. I question the quality of the source.
Old 14th November 2019, 14:13   #57787  |  Link
jeffk
I compressed my screenshot from full sized BMP to JPG, because I didnt find any hoster that accept 6MB+ files...
I was questioning about the "light" and "greyness/darkeness" the quality is fine but yes the compression destroy the quality.
I can upload the BMP but I dont know where.
Old 14th November 2019, 14:13   #57788  |  Link
nevcairiel
Please remember rule #6 and cease discussion of illegally obtained materials.
Old 15th November 2019, 00:31   #57789  |  Link
Furgiuele
Hi.
I solved my issue erasing 2160p23 and 2160p29 in device-display mode. Now Madvr uses p24 or p30 for all movies without any significant clock deviation. I have 1 frame repeat every one ore two days!
Furgiuele is offline   Reply With Quote
Old 15th November 2019, 06:09   #57790  |  Link
Klaus1189
What is now left in the line of displaymodes in madVR? Sounds wrong to me, because you must use 23 for 23.976 and 24 for 24.000 movies/files. Check the files you tested with the 24Hz mode with MediaInfo for framerate.
Old 17th November 2019, 14:40   #57791  |  Link
Bryanhoop
More and more of my sources are using 10-bit encoding. My TV's HDR is absolute crap so I disable HDR completely on the set and in the Windows video output settings. However, this causes a lot of my 10-bit sources to look funny (too dark or an orange tint).
Is there any foolproof way to get my 10-bit sources to just look like a normal 8-bit source?
Bryanhoop is offline   Reply With Quote
Old 17th November 2019, 21:26   #57792  |  Link
mclingo
Ive been having another look at HDR, just dont think my first gen 4k can cut it at all, some stuff looks ok but more SDR than HDR and some stuff looks awful, kind of flat and washed out. MPC-BE does a pretty good SDR conversion though which makes stuff look pretty good, do we know if we'll be getting HDR to SDR conversion back at some point in MADVR?
Old 17th November 2019, 21:53   #57793  |  Link
it was never gone and it is pretty much the main thing madshi works on in the past year.
Old 17th November 2019, 23:17   #57794  |  Link
SamuriHL
SamuriHL's Avatar
The test builds are not for the faint of heart, especially right now, but, the quality of HDR to SDR in the latest test builds is astounding. HSTM (tm) is an amazing dynamic tone mapping algorithm. There's a few users that have posted their settings along with the latest curve parameters. See if any are close to what your display is capable of in SDR and start there if you're willing to accept that it's very much a test build. Most of us are using it to watch movies at this point but it requires more setup than a final build will.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 18th November 2019, 00:50   #57795  |  Link
mclingo
there is no SDR conversion in the latest stablev0.92.17, sure it was there previously, i'll maybe look at the lastest working versions again.
Old 18th November 2019, 01:12   #57796  |  Link
mclingo
i'm still not seeing and actual HDR to SDR conversion option which was definately there before, all I see if tone map HDR options.
https://1drv.ms/u/s!AgvFafeelEBigqsK...SPe_g?e=gwRVIA
However... even on default settings this has made a huger difference to my HDR quallity. My goto test scene is harry potter goblet of fire, the end scene where he's fighting vold, prior to this I could barely see his mum and dad and I couldnt see diggery at all, they are all now perfectly clear.
I'll maybe have a further play with this as I now no longer need to think about converting to SDR.
Old 18th November 2019, 01:22   #57797  |  Link
Manni
The name of the option was changed because people thought, like you did, that it was an HDR to SDR conversion, so that what they were seeing was SDR, not HDR.
HDR Tonemapping makes it clearer that you're still watching HDR, simply that the tonemapping happens in the source (madVR HTPC) rather than in the VP or display/projector.
That change in name happened before the latest public build. Maybe the build you had installed previously was older than that.
In any case, no option was removed in the last public build.
Win10 Pro x64 b1903 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 436.48 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 18th November 2019, 02:25   #57798  |  Link
SamuriHL
SamuriHL's Avatar
Right the "option" for SDR tone mapping is called unchecking "output to HDR" on the HDR tone mapping screen.
Old 18th November 2019, 11:14   #57799  |  Link
mclingo
That did occur to me actually, probably needs an HDR/SDR conversion check box really for clarity.
I tried unchecking that and its stopped everything working for me, I just get a blank black screen.
I've scrapped this for now though anyway as my RX 580 just doesnt have the chops for this, I couldnt get it below 43ms regardless of what settings I used, even if I dropped back to lanczos for all processing.
I'll probably pickup a 5700 in the new year and try again then.
Old 18th November 2019, 12:07   #57800  |  Link
nsnhd
Try changing the *highlight recovery strength* to None as that eats so much performances. RX 580 is similarly powerful as my gtx 1060 6gb and it can not afford this setting on.
nsnhd is offline   Reply With Quote
