Old 10th October 2018, 19:27   #53101  |  Link
Betroz
Is this for real?
Betroz's Avatar
Originally Posted by mclingo View Post
on my LG EF950 OLED my chain is as follows - AMD GFX 4:4:4 FULL RGB 8 bit - MADVR 0-255 - TV "HIGH" - pretty sure this is correct.
Should be the same for HDR and SDR content.
Yes, but Black Level = Low works well with my Panasonic UB820 bluray player with SDR and HDR content. Not sure why it is different with a PC connected.
My HTPC : i7 6900K @ 4.2 | nVidia GTX 1080Ti | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 10th October 2018, 19:35   #53102  |  Link
SamuriHL
SamuriHL's Avatar
I'm guessing you have the UB820 set to YCbCr Auto, yes? That COULD be part of the difference. Maybe.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
SamuriHL is online now   Reply With Quote
Old 10th October 2018, 19:38   #53103  |  Link
mclingo
your UB820 will be sending a limted signed to your TV where you PC will be sending FULL RGB, hence the difference.
SamuriHL - sorry missed your reply
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 5700 19.11.3 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:ON / MADVR 10bit
Old 10th October 2018, 19:42   #53104  |  Link
brazen1
Because a dedicated player uses YCbCr and a PC uses RGB. YCbCr does not use 0-255. It uses 16-235. This is why smart displays have an 'auto' setting. To detect the input and adjust the output. This 'auto' adjustment defaults to 16-235 on my panel. I think panels are programmed around dedicated players. So are 'devices'. This introduces the havoc we PC users face.
W10 1909 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5 PotPlayer
65JS8500 UHD HDR 3D
Old 10th October 2018, 20:19   #53105  |  Link
SamuriHL
SamuriHL's Avatar
To deal with that issue on your PC, you could set madvr to 16-235 (limited), the GPU to RGB FULL, and the TV to auto. It SHOULD show correctly in that configuration.
Old 10th October 2018, 20:38   #53106  |  Link
why should you even use auto if it doesn't work and just runs at limited.
Originally Posted by blaubart View Post
0-255 - the half sample (0-10%) I see nearly nothing then at ~ 16% I can read the letters.
16-235 - even 2% appears as it should be. Maybe madVR is a bit broken?
if you mean with madVR your end device yes could be.
for what ever reason is looks like needs limited range for HDR.
Ok only if I set to RGB output and then open the TV's picture menu the option "HDMI Black Level - Normal/Low" is switchable. "Normal" means 16-235 and the complete desktop now washed out. Nvidia output limited/full has no more effect cause TV's input is limited.
that'S not how it works.
if set your GPU to full range RGB it will send full range RGB if your end device like it or not.
Old 10th October 2018, 20:56   #53107  |  Link
blaubart
Originally Posted by brazen1 View Post
On a Samsung - what you are using - "Normal" is not 16-235. Low is. Normal is 0-255.
Please open a grayscale and switch between Normal and Low. The darker one is 0-255.
Using RGB it is easy to double the effect (not recommended) - set GPU to RGB "full" and TV to "HDMI Black Level - Low" resulting in "blacker then black" and "whiter than white".
@ all
Unfortunately TV manufacturers give their HDMI levels randomly changing phantasy names. The one that sounds somehow lower, weaker is mostly 0-255. To find out which is which a grayscale is helpful.
Unfortunately2, if everything is set wrong some +/- ticks at TV's brightness/contrast and covered.
Only the differences remain - e.g. if madVR is playing 16-235 at non-HDR (although set to 0-255) and playing real HDR in real 0-255. Yes beat me but to my excuse - the differences are somehow tiny..
blaubart is offline   Reply With Quote
Old 10th October 2018, 20:59   #53108  |  Link
brazen1
I don't. I use RGB - 4:4:4 - 0-256 everything software and hardware.
65JS8500 UHD HDR 3D
Old 10th October 2018, 21:08   #53109  |  Link
blaubart
Ok but it seems to work. The upper/lower digits are cutted. TV playing everything 16-235. Even the desktop (washed out colors) and even madVR playing 0-255 HDR.
Old 10th October 2018, 21:20   #53110  |  Link
brazen1
Have a read.
https://pcmonitors.info/articles/cor...-and-amd-gpus/
65JS8500 UHD HDR 3D
Old 10th October 2018, 21:24   #53111  |  Link
nussman
The darker one should be 16-235 ...
nussman is offline   Reply With Quote
Old 10th October 2018, 21:41   #53112  |  Link
Betroz
Is this for real?
Betroz's Avatar
Under HDMI settings menu :
- 4K(50p/60p) 4:4:4
- Colour Mode : YcbCR (Automatic)
Old 10th October 2018, 21:42   #53113  |  Link
blaubart
Obviously my 'device' does not have this feature which would be the solution. At the moment no money here to buy an other. Hoping for madshi to realize the "16-235 only playing HDR" Button or so..
Old 10th October 2018, 21:45   #53114  |  Link
Betroz
Is this for real?
Betroz's Avatar
I have to rename HDMI 1 to "PC" in my TV port settings, then Black Level can be set to Auto. But in PC mode, I can't enable TruMotion at all, and I need that. So I have to have "HDMI 1" set for that port - and then the Black Level option is only Low or High...
Edit : typos and stuff
Old 10th October 2018, 21:51   #53115  |  Link
zapatista
HI Madshi,
i just replaced my old ati 5770 with a gtx 1060 (3gb) , but i have major dropped frames in madvr when playing video since i installed this card (about 10/sec). this is even with default madvr settings, and using mpc-hc (64 bit).
pc = i7-4770k cpu, 32 gb ram, ssd 500 gb, and new 1060 3gb gfx card on a win7 64 bit system
other video players work fine, eg cyberlink powerdvd, vlc, mplayer without madvr is also ok, etc
i have tried several gfx drivers (latest whql, version on the install dvd, best recommended by other users for similar video card etc..), all no solution. also checked for mb driver & bios updates etc (all are up to date). gfx card has no alternative bios release to try.
i did search for other users w madvr reporting similar problems but the main suggestions (from yourself earlier in this thread for ex) was to turn flux off and not use gpu-z, didnt seem to help in my case
https://ibb.co/eQ0VZU
when i first installed the new 1060 gfx card i thought it was working correctly, even was able to play some 4k HEVC files smoothly(downscaled to my 1080 tv over hdmi) and was really impressed with the quality of the video image (as i was expecting from madvr from my old ati card use in previous yrs), but then further testing with 1080p and 720p files (mp4 and HEVC) over the following days all started to have similar severe dropped frames (tried lots of settings in madvr options, but now even default settings with all enhancements off now cause dropped frames 10/sec approx)
i have reset madvr to defaults, uninstalled and reinstalled mpc-ht etc, sadly no solution found so far. cpu usage stays low @ 30% approx, and gpu load is also low @ approx 30% with only 900 mb of the 3 gb vram used (as reported by gpu-z)
any idea what i should look at ?
zapatista is offline   Reply With Quote
Old 10th October 2018, 22:25   #53116  |  Link
your presentation times are terrible try windows 7 overlay.
Old 10th October 2018, 23:12   #53117  |  Link
blaubart
Here renaming HDMI 1 to "PC" results in completely different (2 instead of 4) Picture modes, Black Level is grayed out and set to Auto. But unfortunately madVR playing HDR still black-ish.
Old 10th October 2018, 23:15   #53118  |  Link
a profile should be able to fix this for you.
Old 10th October 2018, 23:27   #53119  |  Link
famasfilms
Has something changed recently with Windows 10 updates/New nvidia drivers?
None of my HDR movies triggering "HDR on" with my LG OLED
famasfilms is offline   Reply With Quote
Old 10th October 2018, 23:36   #53120  |  Link
SamuriHL
SamuriHL's Avatar
Yes, either roll back to 399 or use FSE with HDR content.
