18th May 2016, 22:38 | #38061 | Link | |
Win7Ult || RX560/4G || Ryzen 5 |
19th May 2016, 09:38 | #38064 | Link |
QB the Slayer
I also had issues when I went back to an x86 player with madVR crashing, remembered madshi's post, and it fixed it for me as well.
Odd how I didn't need this fix with the x64 player though... QB
19th May 2016, 13:00 | #38065 | Link | |
Settings like image enhancement are the most important for me to start |
19th May 2016, 14:49 | #38066 | Link |
I created a custom resolution on my HTPC (Win 8.1 x64, Nvidia GTX660). It got accepted as 60, although it was for 59.940 (more 59.941 in my case, including clock deviation adjustment).
BUT But apparently madVR, with FSE and DirectX11 path, decides to use the old 59 frequency from standard Nvidia Control Panel. A resolution I have no way of selecting manually, mind. And if I switch to Windowed DX11 or DX9 (both FSE and Windowed), madVR picks the correct resolution/refresh, the custom one I've created (which gives a repeat every 5.55 hours or so). Why the heck are custom resolutions so fricking complicated?!?!? :stare: Using Nvidia I would surely love for a "for dummies" guide to CRU. I've tried using it in the past but I never understand how to. Alternatively, what do I have to lose most from? Switching from DX11 FSE to DX11 Windowed or to DX9 FSE? In both cases I lose 10 bit rendering but what else?
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM Last edited by ashlar42; 19th May 2016 at 15:10. |
19th May 2016, 16:28 | #38069 | Link |
Can you make a screenshot of the error message? What versions of MPC-HC, madVR and XySubFilter are you using exactly (i.e. the numbers, not "latest")?
I have no problems using MPC-HC x64 1.7.10.207, madVR 0.90.19 and XySubFilter 3.1.0.746. |
19th May 2016, 16:58 | #38073 | Link |
we can't see your screen. it needs admin approval so think about uploading is somewhere.
looks like you are loading an old version. maybe you have only update the 32 bit version but you are using a 64 bit player or something like that. |
19th May 2016, 17:07 | #38074 | Link |
I am using MPC v1.7.10 (x86) and when I uninstalled xySubFilter it could not detect it any more so I can only assume it is uninstalling correctly, but when i reinstall it isn't installing the correct version.
Here is the error: http://i.imgur.com/Wn5oB7m.jpg Here is my xysubFilter: http://i.imgur.com/N0PRkiR.png EDIT: I wiped all of my filters, uninstalled the player and rebooted. After reinstalling everything I am no longer having the issue, thank you to everyone for your help. Last edited by Phantasmagorie; 19th May 2016 at 17:17. |
19th May 2016, 17:24 | #38075 | Link |
Posts: n/a
I was never big on subtitles because most of my content was in English, but I recently ripped and watched a foreign film, which came with English (NOT hard-coded) subtitles. I wasn't reading much of anything back when madVR just released subtitles settings because I could care less about them, until now...
I was HOPING madVR could MOVE subtitles to the very bottom black bar (for 21:9 content format, which this foreign film used), but no matter which settings I adjusted, I couldn't move the subtitles anywhere. The subtitles were integrated into the ripped MKV file itself and were not coming from a separate subtitles file. I know the subtitles were not hard-coded because I could turn them off completely... Questions: - Can madVR move non-hard-coded subtitles to the bottom of the screen, where black bar is located in 21:9 film content? - If madVR CAN move the subtitles to the bottom of the screen (on the black bar), then which settings do I need to adjust and which values should I use for those settings? Slightly off-topic side-questions: - Can MPC-HC + LAV Filters + ReClock + madVR play films downloaded from Microsoft Store on Windows 10 Pro x64? - If the above is possible, then where do I find these downloaded Store files and how can I make them run on MPC-HC + LAV Filters + ReClock + madVR? Last edited by XMonarchY; 19th May 2016 at 17:27. |
19th May 2016, 17:29 | #38076 | Link |
How it works may depend on the subtitle, the subtitle format and the renderer. For MPC-HC's internal renderer you would go MPC-HC Options -> Subtitles -> Default Style and un-tick "Position subtitles relative to video frame". For XySubFilter you should go into madVR's "zoom control" and enable moving subtitles to the bottom of the screen.
19th May 2016, 17:34 | #38077 | Link | |
I wish madVR could completely disable the LUT processing instead of setting the LUT linear. In that case even when the LUT is loaded, madVR could read the LUT and apply it internally in high bit depth like it does for Overlay mode. Last edited by omarank; 19th May 2016 at 17:39. |
19th May 2016, 18:13 | #38078 | Link | |||
i will use MPC-HC now. |
19th May 2016, 21:21 | #38079 | Link | |
From the same developer (ccrocker=KeyserSoze17) =>MeediOS - madVR Video Player, but i can't find source |
19th May 2016, 22:14 | #38080 | Link |
Crimson 16.5.2 dramatically decreases madVR performance for me with my 390, I can't even use SuperRes 2 for 1080p -> WQHD Jinc, while with 16.5.1 even SR3 works.
Filled in a bug report, this driver gives also other users quite some problems. |
