Old 15th January 2016, 23:40   #35381  |  Link
6233638
Where did we do the previous discussion about this? In the bug tracker? I don't remember the conclusion of the our previous discussion, so I'm not sure right now if this behaviour is as intended or not.
I had a chance to look this up, and it seems that I was mistaken - the behavior I saw with the "wrong" profile being selected is actually working as intended.
http://bugs.madshi.net/view.php?id=349
The srcHeight/Width behavior was only changed for Zoom Control profiles (since that actually broke things) and not all profiles.
It's not what I would personally prefer, but I think your decision to handle it this way does make sense, so I'll keep using uncroppedSrcHeight/Width for the affected profiles.
Old 16th January 2016, 01:47   #35382  |  Link
Aleksoid1978
Aleksoid1978's Avatar
So basically you're saying that a passive 3D TV when looked at without glasses has lines 1, 3 and 5 for left eye and lines 2, 4 and 6 for right eye? So I would simply render as if it were 2D and the TV wouldn't even have to know that I'm sending 3D, the user would simply put on his glasses and that's all?
Implementing that should be relatively easy.
I think you are right. You can try render as usually 2D picture and alternate lines for the left and right eyes(1 - left, 2 - right, 3 - left, 4 - right and so on.) Passive TV must from such image do 3D in half resolution for height(1080 -> 540).
You can try make test build - and i check it on my TV.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 16th January 2016, 02:54   #35383  |  Link
Oh ok. I guess I didn't understand how passive 3D works. So basically you're saying that a passive 3D TV when looked at without glasses has lines 1, 3 and 5 for left eye and lines 2, 4 and 6 for right eye? So I would simply render as if it were 2D and the TV wouldn't even have to know that I'm sending 3D, the user would simply put on his glasses and that's all?
@Aleksoid1978, would that do the trick for your TV?
this may work but what the TV is subsampling. after that there is nothing worth calling 3D/in the chroma channel.
this issue doesn't exist with top bottom and side by side.
Old 16th January 2016, 06:58   #35384  |  Link
omarank
PC mode, Game mode or Graphics mode, which doesn’t downsample chroma, can be used in the TV. 3D output this way should still be better, rather much better, than after the unnecessary processing done by the TV when its 3D processing engine is active.
Row/ Column Interleaved output is anyway going to be optional in the settings. Passive TV users can always use frame packed 3D output to compare and decide which output method they like the most.
Originally Posted by Ver Greeneyes View Post
Do 4k TVs with passive 3D have polarization filters applied as a coating, alternating between columns? Otherwise, I wonder how glasses would know which lines to show.
Yes, not only just 4K Passive TVs, all Passive 3D TVs have a special coating which, for example in case of Row Interleaved Type, polarizes the light coming from odd lines in one way and from even lines in the opposite way. Passive 3D glasses have corresponding polarization filters which ensure that one eye sees just the odd lines and the other eye sees the even lines only. As the odd lines comprise View 1 and even lines View 2, the user gets 3D vision when they put on the Passive glasses.
omarank is offline   Reply With Quote
Old 16th January 2016, 07:09   #35385  |  Link
apgood
Originally Posted by Manni View Post
Thanks. Did you check with say chapter 2 of Gravity that the depth was correct? For example, when they circle around each other in space, is the depth correct for each of them and the rope/tether?
Haven't converted Gravity to mkv yet but PAN and hobbit unexpected journey. The 3D layers look correct and there are no out of sequence frames or anything like that.
apgood is offline   Reply With Quote
Old 16th January 2016, 07:17   #35386  |  Link
4h4h270
frame drop is from reclock, disabled, everything goes fine.
I have a problem, I always get 1 frame drop every 30+sec, I checked with gpu-z the load is only 40%~50%.
I tried lighter algorithm and raise every quene size, nothing changed.
4h4h270 is offline   Reply With Quote
Old 16th January 2016, 07:55   #35387  |  Link
aufkrawall
Do you have also drops with other renderers? I'd try EVR CP of MPC HC and display rendertime graphs with ctrl + j.
Old 16th January 2016, 08:00   #35388  |  Link
apgood
Sounds good. Try a few different movies. It's possible that the eye swapping depends on the movie. If that's the case, either MakeMKV or LAV need a minor fix/update to solve that issue.
Only got 2 3D movies in mkv (rest still in iso format), but tested them in Mede8er as well and they need the eye swapping setting set there as well, so I suspect it might be something in MakeMKV that I did when I created them.
If I get a chance I'll try creating some more to see (and make sure I'm running the latest version of MakeMKV).
Old 16th January 2016, 08:24   #35389  |  Link
foozoor
Does madVR use image doubling with DVXA image upscaling?
In the OSD, I see chroma > DVXA and image > DVXA.
foozoor is offline   Reply With Quote
Old 16th January 2016, 08:45   #35390  |  Link
mogli
@foozoor
No, it does not.
mogli is offline   Reply With Quote
Old 16th January 2016, 09:25   #35391  |  Link
foozoor
Originally Posted by mogli View Post
@foozoor
No, it does not.
Thanks! What about image enhancement and upscaling refinements?
Old 16th January 2016, 09:46   #35392  |  Link
Manni
Thanks. This is either thanks to Crimson, or because you can swap left/right eye in your projector. I can't do this on my JVC.
I'll try Crimson when I have a chance if no one else confirms AMD working on Catalyst.
Win10 Pro x64 b1903 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 436.48 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 16th January 2016, 11:13   #35393  |  Link
image enhancement yes
upscaling refinement no
Old 16th January 2016, 13:32   #35394  |  Link
sat4all
Hi madshi,
Debanding algo introduce dropping frames no matter what i set on level. I can fix this only by checking: don't rerender frames when fade in/out is detected. (Must be always checked?)
I've tried with my both rigs: main htpc with an amd hd 7950 and intel nuc i5 hsw.
sat4all is offline   Reply With Quote
Old 16th January 2016, 13:45   #35395  |  Link
nussman
Seems like your GPU is to weak for your settings without "don't render frames when fade in/out ..."?
Take a look at the rendering times in the OSD.
nussman is offline   Reply With Quote
Old 16th January 2016, 14:09   #35396  |  Link
XTrojan
Using MPC-HC, Lav 0.66 and I can't get 3D to work Frame-packed or SBS, it simply won't activate nor engage Multiview mode for SBS.
Container is .mkv with MVC 3D stream in it
I noticed you added a nits mode, I know this is something similar to HDR, but what does it do to rec709 movies? I'm not using backlight at max on my TV since rec709 colors get weird above certain nits or strains eyes.
I'm using a JS9000 Tv that should handle most 3D formats.
I'm mostly trying to get Multiview SBS mode to work since framepacked is limited to 1080p23 8bit and all that stuff, Multiview SBS is registered 2D at the PC, it's when it passes to the TV it converts to 3D by merging left+right which is same thing as merging original track + MVC track in framepacked.
XTrojan is offline   Reply With Quote
Old 16th January 2016, 14:32   #35397  |  Link
XTrojan
I did a image edit to explain Full SBS easier.
This image is what the PC reports, the PC always thinks the movie is 2D, the TV will merge these two images into 3D. The PC will thus never be restricted by 3D setting limit such as 1080p23.
http://i.imgur.com/um8Lal8.jpg
Regarding the "mountain effect" on the image, this is the industry standard, the more you stretch the images from eachother (2D and MVC) to each eye the more of a 3D effect you get but also introducing other weird things such as crosstalk. Most TVs have a "3D depth setting" which will basically try to stretch these two images even more in frame-packed or SBS.
also yes, windowed mode doesn't work that well since there's space in the middle and when the TV merges them it becomes buggy, fullscreen is needed to avoid scaling issues.
Either way i can't get Full SBS or Framepacked 3D to work with MadVR as my post above states.
Edit2: When I mean "stretch" it's basically adding distance from both images, 1 image = 1 eye, add too much distance between them and your eyes will become asymmetrical, lol.
Old 16th January 2016, 14:42   #35398  |  Link
Manni
You need a recent nightly of LAV 0.67, 0.66 doesn't support 3D.
Old 16th January 2016, 14:53   #35399  |  Link
Thunderbolt8
bilateral chroma upsampling in madvr, is this actually adaptive bilateral sampling or fixed bilateral sampling?
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 16th January 2016, 15:01   #35400  |  Link
XTrojan
Ahh, i'll try testing it tonight then.
