#21821 | Link | |
0.87.1 works fine on my HTPC, with HD7970 + Catalyst 13.12 -- Win7x64SP1. Just noticed the GPU's deinterlacing time is increased around 100%... [720x480i60] 0.86.10 --> 0.83ms 0.87.1 --> 1.64ms [1440x1080i60] 0.86.10 --> 1.44ms 0.87.1 --> 4.21ms Regarding the Image Doubling function on the above 720x480i60 contents to 1920x1080p60 display mode, even HD7970 is not quick enough to handle 60fps. It needs more than 17ms (Debanding_with_AngleDetect + NNEDI3 2x + Jinc3AR) processing time vs 6.2ms (Debanding_with_AngleDetect + Jinc3AR) |
#21822 | Link | |
flashmozzg,
If it helps madshi, here are the results: When starting playback in windowed mode After switching to full screen mode and get a black screen |
#21823 | Link | |
#21824 | Link | |
![]() When created, the profiles get switched automagically with your auto-select rules or by customizable key shortcuts. Be sure to read the help for auto-select rules scripting. |
#21825 | Link | |
On my system with the 560 Ti, the last driver to have OpenCL error diffusion working is 327.23. Every version after this is total FAIL. Something went very wrong indeed. Nothing in the release notes for 331.40 indicate any changes that would adversely affect OpenCL applications but who knows? Maybe whoever compiled the latest drivers forgot to flip the OpenCL switch. On the plus side, Nvidia does make installing and uninstalling drivers as pain-free as possible, so there's that. ![]() EDIT: I forgot to mention I was using the latest 0.87.1 build of madvr. Also, I'm not 100% sure if this is only a problem that affects Fermi cards and newer so I really have to get my GTS 250 system up and running to find out for sure. I also have a stockpile of drivers going back to 2009, so let the good times roll. ![]() Last edited by PixelH8; 25th January 2014 at 17:32. Reason: missing details |
#21826 | Link | |
.86: Queues all full, no drops, deint=7.3ms .87.1: Render and present queues struggle ~3-4, 50+ drops after 2 min of playback, deint=18.13ms HD6570 Edit: Should add, this is a VC1 video using DXVA2 decode |
#21827 | Link |
Glad it's not just me and not just Intel GPUs!
HTPC Hardware: Intel Celeron G530; nVidia GT 430 HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H |
#21828 | Link | |
![]() I was holding off testing debanding until the final version, and man, does it make a difference. Though low seems to be the only non-destructive setting. What does the "don't analyze gradient angles" option affect? I didn't really see any difference
AMD Phenom II X4 970BE | 12GB DDR3 | nVidia 260GTX | Arch Linux / Windows 10 x64 Pro (w/ calling home shut up) |
#21829 | Link | |
i just checked deint ms too they are high at start but after some time about the same like 86.9.
but while i was testing this is find a new bug introduced in 87.x. when you change the deinterlacer mode with shift + control + alt + t i get - creating Direct3d Device failed (80070005) picture one items it even switch to 8 bit color deep. doesn't matter if film to video or video to film. edit: works fine when change in the tray options strange but doesn't try to change resolution this way. Quote:
#21830 | Link |
OpenCL crashes (bluescreen) on a laptop with radeon 7650 with 13.12 drivers (leshcat drivers v3).
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) |
#21831 | Link | ||||||||||
------- So for all users who have: (1) Stability problems (D3D9 error messages, freezing when switching video files in FSE mode etc). (2) Performance issues with deinterlacing. Please try the various test builds you can find here: http://madshi.net/madVRtestbuilds.rar Every test build reverts one change back to v0.86.11. This way hopefully we can identify which change is reponsible for which problem. |
#21832 | Link | |
Broadband Junkie
#21833 | Link | |
![]() More importantly, I don't think NVIDIA (or quite possibly any other GPU vendor) cares much about such (tiny) compute use-cases.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th January 2014 at 18:41. |
#21834 | Link |
0.87.1 is working great here (speed-wise it seems at least on par with 0.86.11, if not faster, havenīt tested with de-interlacing yet, though).
I found one bug though, which is reproducible every time: 1) enable smooth motion - enable always 2) play a video file 3) enter fullscreen-exclusive 4) leave fullscreen-exclusive and return to windowed mode -> black screen 5) going back to fullscreen-exclusive the picture is back 6) leave fullscreen-exclusive again -> black screen ... GTX580, 331.82 drivers (quadro) @madshi: I donīt know if this is helpful for you, but on the 3dcenter-forum there is a member called Blaire, which seems to be part of the NV BETA Testing-Program and he seems to know a lot of various related (known) issues and he reports directly to them (driver related problems, primarily he reports game issues). He seems to be always up-to-date when it comes to new drivers, too. It seems that when he is reporting bugs directly, they have a very high chance to get fixed ASAP. Thatīs only an observation on my part though, I didnīt actually every have a conversation with him, since I never had serious problems, thankfully. Also, if you tell him that a lot of the madVR users are going to consider switching to AMD in the future, because of the lackluster OpenCL drivers, NV may listen a bit more closely. Seems worth a try, at least. Not your problem if they cannot provide stable drivers for such things, anyway. Last edited by iSunrise; 25th January 2014 at 18:44. |
#21835 | Link |
Anime Otaku
CUDA though works exclusively and only on Nvidia, it's a proprietary interface. OpenCL isn't. Nvidia's attitude is forcing developers to support their own interface so they have to do double the work.
Sent from my Nexus 7 using Tapatalk
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
#21836 | Link |
Some more feedback....OpenCL...HD6570
I've been testing SD video (and interlaced) and film, upscaling to 1080, with the NNEDI Double Luma, 64neurons. I can't use secondary scaling options that use pixel shaders, but DXVA2 scaling works great in this case. I can still see some ringing around hair and people's heads, but it seems to be working very well, using about 25-30% less GPU than Jinc3/AR with SD film. Edit: % perf numbers Last edited by noee; 25th January 2014 at 18:44. |
#21837 | Link | |
BUT! after that 86.9 didn't work too at least the film video mode switching the error is different the player is completely crashing (bug report sending didn't work yet again) to fix this i have to reset all settings. so i try all 6 again but this time i reset them all each time... and type the display modes in each time X-) maybe just an problem with an registry entry? |
#21838 | Link | |
As for nVidia's openCL, I guess I just have to be happy other openCL seems to function properly, i.e. flaccl still being lossless. But that kind of scares me to be honest. Maybe I'll go with AMD for my next GPU this iteration...
#21839 | Link | ||||
@iSunrise, if this issue did not occur in v0.86.11 (please double check), could you please also check the test builds I posted a couple posts above to see if any one of them fixes this problem or not? Thanks. Quote:
